What is the water level above the orifice as time goes to infinity?
In summary, the conversation discusses a tank with a square cross-section and a water orifice, with water flowing in and out at certain rates. The goal is to show that the water level will eventually approach the value (25/24)^2 ft above the orifice, which is achieved by examining the differential equation at y = (25/24)^2 and finding that it is zero, indicating a maximum point. Alternatively, the discharge rate at y = 25/24 can be shown to equal the influx of water, and a differential equation can be set up to show that y = 25/24 is the solution.
process91
106
A tank with vertical sides has a square cross-section of area 4 ft2. Water is leaving the tank through an orifice of area 5/3 in2. Water also flows into the tank at the rate of 100 in3/s. Show that the water level approaches the value (25/24)2 ft above the orifice.
Rate of discharge of volume through the orifice is [itex]4.8A_0 \sqrt{y}[/itex] cubic feet per second, where [itex]A_0[/itex] = size of orifice in square feet
[tex]\dfrac{dV}{dt}=100/12^3-4.8A_0 \sqrt{y}[/tex]
Also, [itex]V(y)=\int_0^y 4 du[/itex] so
[tex]\dfrac{dV}{dy}=4[/tex]
By the chain rule, [itex]\dfrac{dV}{dt}=\dfrac{dV}{dy} \dfrac{dy}{dt}[/itex] so
[tex]100/12^3-4.8A_0 \sqrt{y} = 4 \dfrac{dy}{dt}[/tex]
The problem right before this was the same except water was not being added at all, and that was an easily solvable differential equation. I am stuck on this, and when I got the answer from WolframAlpha it did not look encouraging that I was on the right track.
I think, perhaps, the solution is not to actually solve the differential equation, but rather to do something like this:
Instead of trying to solve my differential equation, I just examine it at y=(25/24)^2, and see that it is zero. Examining the second derivative, we find that it is always negative so this is a maximum of y. For y less than this, the derivative is positive and above this value the derivative is negative. Hence no matter what value of y the problem starts with, as t increases it will approach (25/24)^2.
Does that seem valid?
You can demonstrate the discharge rate at y = 25/24 equals the mass influx so the level won't rise anymore.
Also you could write a DE for the rate of volume of water increase in the tank.
Atank * (dV/dt) = 100/12**3 - 4.8 * A0 * (y**2)** .5
Set dV/dt to zero and solve for y. You should get 25/24.
What is an applied differential equation?
An applied differential equation is a mathematical equation that describes the relationship between a quantity and its rate of change. It is used to model and analyze real-world phenomena in various fields, including physics, engineering, and biology.
What are the applications of differential equations?
Differential equations have a wide range of applications in various fields, such as physics, engineering, economics, biology, and chemistry. They are used to model and predict the behavior of systems and processes in these fields.
What are the different types of differential equations?
There are several types of differential equations, including ordinary differential equations (ODEs), partial differential equations (PDEs), and stochastic differential equations (SDEs). ODEs involve only one independent variable, while PDEs involve multiple independent variables. SDEs also involve randomness in addition to differential equations.
What is the difference between an ordinary and a partial differential equation?
The main difference between an ordinary differential equation (ODE) and a partial differential equation (PDE) is the number of independent variables. ODEs involve only one independent variable, while PDEs involve multiple independent variables. This means that PDEs are more complex and require different methods for solving them compared to ODEs.
How are differential equations solved?
Differential equations can be solved using various methods, including analytical methods and numerical methods. Analytical methods involve finding a closed-form solution using mathematical techniques, while numerical methods involve using algorithms to approximate the solution. The choice of method depends on the type of differential equation and the complexity of the problem.
  • Math Proof Training and Practice
