Aquarium fish tank: Glass material alternatives
In summary, PET can be used as a clear alternative to glass for Aquarium fish tanks, but care must be taken to avoid harmful effects to the fish. The tanks should be round with a capacity of at least 1,000 gallons and should have flat faces to avoid issues with blow moulding. There will be a large demand for these tanks, with a projected production of 10,000 tanks.
prashantakerkar
43
Can there be alternative materials for Aquarium fish tank instead of glass?
Example : Stainless steel, Aluminium Plastic, Concrete etc
If yes, which materials can be evaluated?
Do you need the walls to be transparent?
Thanks.
Both options can be evaluated.
Thanks & Regards,
Prashant S Akerkar
What options are you referring to? Please try to write more than five words in your posts.
Thanks.
Both options to be evaluated for constructing Aquarium fish tank as a alternative to Glass material.
1 Transparent material
2 Non Transparent material
Thanks & Regards,
Prashant S Akerkar
I don't understand what you want. Can a non-glass material be used as a fist tank? Of course. I have a bucket in my shed that I can use as a fish tank. This is such a trivial question that I can't fathom why it even needed to be asked, so I have to assume that there's more to this question than you're telling us. Please elaborate on your question. Are you making a large fish tank with specific structural requirements, or are you just wanting to put some fish in a tank on your shelf at home? Or something else? Without knowing more details we can't help you.
Likes prashantakerkar
As a former professional fish raiser (for research purposes), I have seen fish containers made out of;
wood
metal
concrete
fiberglass
glass
numerous plastics
liners with any of a number of support materials to hold it up
clay lined holes in the ground
The thing is that to be successful, you have to have things sized properly for the fish and you should check you materials for toxic effects on the fish (some can be corrected).
This can be done with a bioassay, which depending upon your intended use could be quick or time consuming.
In my numerous bioassay tests, I have found about 1/3 of of rubber and plastic materials had strong negative effects on embryonic and larval zebrafish. These effects can vary between materials that are the "same" but made by different manufacturers. They can also vary from lot to lot.
To avoid the bioassay, use standard materials from reputable sources that are intended for your use (aquarium or aquaculture suppliers).
Likes berkeman, prashantakerkar, Tom.G and 1 other person
PET is clear, cheap and is blow moulded to make clear water bottles, if they do not have flat faces. Can you use a round tank like a big water cooler bottle?
What capacity and what shape should the tanks be?
How many thousand tanks will you be building?
What are the most common materials used for aquarium fish tanks besides glass?
The most common materials used for aquarium fish tanks besides glass are acrylic, polycarbonate, and fiberglass. These materials are known for their strength and durability.
What are the advantages of using acrylic for an aquarium fish tank?
Acrylic is lighter and stronger than glass, making it less prone to cracking or breaking. It also has better insulation properties, keeping the water temperature more stable. Acrylic tanks also offer a clearer and distortion-free view of the fish inside.
Are there any drawbacks to using polycarbonate for an aquarium fish tank?
One drawback of polycarbonate is that it is not as clear as glass or acrylic, which can affect the visibility of the fish inside. It is also more prone to scratching, which can impact the aesthetic appeal of the tank.
Can fiberglass be used for large aquarium fish tanks?
Yes, fiberglass can be used for large aquarium fish tanks. It is a lightweight and durable material that can withstand heavy water pressure. However, it is not as transparent as glass or acrylic, so it may not be suitable for tanks where visibility is important.
Is it safe to use alternative materials for an aquarium fish tank?
Yes, as long as the material is specifically designed for aquarium use and is non-toxic to fish. It is important to research and purchase high-quality materials to ensure the safety and well-being of the fish living in the tank.
  • Materials and Chemical Engineering
  • General Discussion
  • Mechanical Engineering
