Arbitrary function is true when n = 1
  1. Feb 26, 2005 #1
    I cannot understand this method! If you can prove P(m) is true, why bother?? Isn't it enough to only prove P(m)?
  3. Feb 26, 2005 #2
    matt grime
    That's badly phrased, it ought to read IF P(m) is true, then P(m+1) is true. Thus we a priori do not know it is true, merely that if it is true then the successor is true. Now, since P(1) is true, this means that P(2) is true, which in turn implies P(3) and so on.
    Example: Define a sequence a_n by a_1=1, and a_r = a_r +2.
    Now, take the statement P(n):= { the term a_n is even}.
    For this proposition, IF P(m) is true, then P(m+1) is true, so the inductive hypothesis is satisfied, however P(m) is always false.
  4. Feb 26, 2005 #3
    So if, and only if, P(m+1) is true, also P(m) is true. But it don't seem easier to prove P(m+1) then P(m)
  5. Feb 26, 2005 #4
    HallsofIvy
    The point is: You prove: If P(n) is true for SOME SPECIFIC n, then it is true for n+1.
    Saying "P(n) is true for SOME SPECIFIC n" is different from saying "P(n) is true for all n" which is the conclusion.
    Of course, knowing "IF P(n) is true for SOME SPECIFIC n, then it is true for n+1." doesn't help if you don't know P(n) IS true for some specific n. That's why you need to prove P(1) is true.
    It might help to use a different letter for the "specific" n:
    To prove P(n) is true for all n:
    1) Prove P(1) is true
    2) Prove "If P(N) is true (for SOME N) then P(N+1) is true".
    If we've done that we know (by 1) P(1) is true. Then (by 2) P(2) is true. Now (by 2 again) P(3) is true. Now, (by 2 again) P(4) is true...
  6. Feb 26, 2005 #5
    Ahh. I think I see.
    The Power rule when n=1 is true:
    du^n/dx = n * u^n-1 * du/dx = 1 * 1 * du/dx = du/dx
    And also when n=2:
    du^2/dx = 2 * u * du/dx
    Conclusion: du^n/dx = n * u^n-1 * du/dx
    This's hard stuff. :yuck: Perphas it's easier if one has some logic symbols...
  7. Feb 26, 2005 #6
    dextercioby
    Okay,it's not difficult at all.
    [tex] \frac{du^{n}(x)}{dx} =n \ u^{n-1} \frac{du}{dx} [/tex]
    You have chacked the validity for "n=1".Now apply the method of mathematical induction
    1.Suppose that for arbitrary "n" is valid the conclusion:
    [tex] \frac{du^{n}(x)}{dx} =n \ u^{n-1} \frac{du}{dx} [/tex](1)
    Then,knowing (1) to be true,u need to prove that
    [tex] \frac{du^{n+1}(x)}{dx} =(n+1) \ u^{n} \frac{du}{dx} [/tex](2)
    Use product rule (for differentiation) and the fact that:
    [tex] u^{n+1}=u\cdot u^{n} [/tex](3)
    and then simply use (1).The result,(2),will come out very easily.
    Daniel.
  8. Feb 26, 2005 #7
    Ah.
    We want to prove P(n) = [tex]\frac {d(u^n)}{dx}=nu^{n-1} \frac {du}{dx}[/tex]
    P(1)=[tex]\frac{du}{dx}= 1 * u^0 * \frac {du}{dx}[/tex] Thus, P(1) is true.
    Now, assume that P(m) is true: P(m)=[tex]\frac {d(u^m)}{dx}= m * u^{m-1}*\frac{du}{dx}[/tex]
    And then you must prove that P(m) implies P(m+1). This can you do with the power rule, for you're assuming it's correct.
    P(m+1) = [tex]\frac {d(u^{m+1})}{dx} = \frac {d(u^m * u)}{dx} = u * \frac{d(u^m)}{dx} + u^m * \frac{du}{dx} = u * m * u^{m-1} * \frac{du}{dx} + u * \frac{du}{dx} = (m+1)u^m * \frac{du}{dx}[/tex]
    P(1) [itex]\Longrightarrow[/itex] P(2) .... P(1) is indeed true, and thus also P(2).
    P(2) [itex]\Longrightarrow[/itex] P(3)
    And so on...
  9. Feb 26, 2005 #8
    dextercioby
    That's right.You got it...:smile:
    Daniel.
  10. Feb 27, 2005 #9
    matt grime
    The truth of P(m+1) need tell you nothing about P(m).
    And you are missing (at this point, though perhaps later in the thread you get it) the fact that we use the *assumed* truth of P(m) to *deduce* the truth of P(m+1). In the example I gave P(m) is false, for any m, but if we assume it true then P(m+1) is true by deduction:
    if a_m is even then since a_{m+1} = a_m + 2, it must be that a_{m+1} is even. Ie P(m) implies P(m+1). But in the example I gave a_m is odd for all m.
  11. Feb 27, 2005 #10
    dextercioby
    The real trick in this math.induction is obviouls checking the validity for an arbitrary (preferably small,usually "+1") value of the parameter "n"...If you went ahead and proved that P(n)->P(n+1),that values nothing,as P(1) may be false...:wink:
    Daniel.
