Archimedes Law
  1. Jan 17, 2016 #1
    A person (with mass 60.0 kg) is located on a volume of ice, floating on the water. Calculate the smallest volume of the ice so that the person would remain above the water ( ice density = 917kg / m3)
    2. Relevant equations
    F= m xg
    Archimedes F = density x V xg
    3. The attempt at a solution
    If the object is floating then we know that F(g) = F(a)
    therefore
    m xg = d x V x g
    g cancels out
    m = d x v
    60kg= d (ice) x V
    V= 60kg / 917 kg/m3
    V = 0.065 m 3
    But the answer should be 0.72 m3
    Thank you :)
  3. Jan 17, 2016 #2
    TSny
    2017 Award
    Should the force of gravity include the weight of the ice as well as the person?
    Also, are you sure you want to use the density of ice when finding the buoyant force?
  4. Jan 17, 2016 #3
    You have to use density of water ???
  5. Jan 17, 2016 #4
    TSny
    2017 Award
    Can you state Archimedes' principle in words?
  6. Jan 17, 2016 #5
    Its a principle that states that a body immersed in a fluid is buoyed up by the force which is equal to the weight of displaced fluid
  7. Jan 17, 2016 #6
    TSny
    2017 Award
    OK. What type of fluid is being displaced?
  8. Jan 17, 2016 #7
    Water ?
  9. Jan 17, 2016 #8
    TSny
    2017 Award
    Yes. But instead of typing "water ?", you should type "water!":smile:
  10. Jan 17, 2016 #9
    Ok water!
  11. Jan 17, 2016 #10
    TSny
    2017 Award
    Good. So, how would you calculate the weight of the fluid displaced?
  12. Jan 17, 2016 #11
    W= rho x V x g
  13. Jan 17, 2016 #12
    TSny
    2017 Award
    OK. What density would you use here?
  14. Jan 17, 2016 #13
    1000 kg/ m3
  15. Jan 17, 2016 #14
    TSny
    2017 Award
    Yes (water). And what volume V should be used to find the weight of the fluid displaced?
  16. Jan 17, 2016 #15
    0.0654 m3
  17. Jan 17, 2016 #16
    TSny
    2017 Award
    I wasn't clear. When calculating the weight of fluid displaced, should you use the volume of the ice, the volume of the person, or the total volume of both?
  18. Jan 17, 2016 #17
    Total volume of both
  19. Jan 17, 2016 #18
    TSny
    2017 Award
    We don't want the person to get wet.
  20. Jan 17, 2016 #19
    The volume of ice then
  21. Jan 17, 2016 #20
    TSny
    2017 Award
    Right. So you have that the buoyant force acting upward on the system is ρwater Vice g.
    How does this force relate to the weights of the person and the ice?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Archimedes Law
  1. Archimedes principle (Replies: 10)
  2. Archimedes Principle (Replies: 12)
Loading...
