Archimedes Principle Applied
In summary, the conversation is about finding the tension required in a fishing line to give a lead weight with a volume of 0.69x10^-5 m^3 and a depth of 1.0m an upward acceleration of 1.8m/s^2. The equation used is T=F-mg, with F=ma and D=mv. The author has attempted to solve the problem by first converting density into mass and then using the given volume and measured density to find the mass of the lead weight. However, they are unsure if they have used Archimedes' principle correctly and are open to suggestions. Archimedes' principle states that there is a buoyancy force equal to the weight of water with the
smilingsteph
A lead weight with a volume of 0.69x10^-5 m^3 is lowered on a fishing line into a lake to a depth of 1.0m. What tension is required in the fishing line to give the weight an upward acceleration of 1.8m/s^2?
T=F-mg F=ma D=mv D of lead= 11.34gcm^3
I have tried solving it (first changing density into m, to be compatible with my volume value). Then I found the mass of the lead weight (using the given volume and measured density). But still not sure if I'm going through the proper means to arrive at the tension. Any suggestions?
Where have you used Archimedes' principal that you cite in your title? It tells you that there is an bouyancy force equal to the weight of water with the same volume as the lead weight.
As a scientist, it is important to follow a systematic approach to problem solving. In this case, we can use Archimedes' Principle, which states that the buoyant force acting on an object submerged in a fluid is equal to the weight of the fluid displaced by the object.
First, we can calculate the weight of the lead weight using the formula W = mg, where m is the mass and g is the acceleration due to gravity. We can use the given density of lead (11.34 g/cm^3) to convert the volume (0.69x10^-5 m^3) into mass. This gives us a mass of approximately 0.781 g.
Next, we can calculate the weight of the displaced water using the density of water (1 g/cm^3) and the volume of water displaced by the lead weight (0.69x10^-5 m^3). This gives us a weight of approximately 0.069 N.
Since the lead weight is accelerating upwards with an acceleration of 1.8 m/s^2, we can use the formula F=ma to calculate the force required to give it this acceleration. This gives us a force of 0.0014 N.
According to Archimedes' Principle, this force (0.0014 N) must be equal to the buoyant force acting on the lead weight (0.069 N). Therefore, the tension in the fishing line must be 0.069 N + 0.0014 N = 0.0704 N.
In conclusion, the tension required in the fishing line to give the lead weight an upward acceleration of 1.8 m/s^2 is approximately 0.0704 N.
1. What is Archimedes' Principle?
Archimedes' Principle is a physical law that states that an object partially or fully submerged in a fluid experiences an upward buoyant force equal to the weight of the displaced fluid. This principle is named after the Greek mathematician Archimedes, who first described it in the 3rd century BC.
2. How is Archimedes' Principle applied in real life?
Archimedes' Principle is applied in various areas of science and engineering, including shipbuilding, aircraft design, and the development of submarines and other underwater vehicles. It is also used in everyday objects such as hydrometers, which measure the density of liquids, and hot air balloons, which use the principle to rise in the air.
3. What are the key factors that affect the buoyant force according to Archimedes' Principle?
The buoyant force is affected by the density of the fluid, the volume of the object, and the acceleration due to gravity. The denser the fluid, the greater the buoyant force will be. Similarly, the larger the volume of the object, the greater the buoyant force. The acceleration due to gravity also plays a role, with objects experiencing a stronger buoyant force in denser gravitational fields.
4. How is Archimedes' Principle related to the concept of displacement?
According to Archimedes' Principle, an object submerged in a fluid experiences an upward buoyant force equal to the weight of the fluid it displaces. This means that when an object is placed in a fluid, it will displace an amount of fluid equal to its own volume. This concept is important in shipbuilding, where the displacement of a ship determines its maximum weight capacity.
5. Can Archimedes' Principle be used to explain why some objects float while others sink?
Yes, Archimedes' Principle can be used to explain why some objects float while others sink. If an object's weight is less than the buoyant force acting on it, it will float. On the other hand, if an object's weight is greater than the buoyant force, it will sink. This is why objects with lower densities, such as wood, float while objects with higher densities, such as metal, sink.
