Archimedes Principle: Find Vol, Bouyant Force & Density of Plank
In summary, the conversation is discussing how to find the volume of a plank, the buoyant force, and the density of the plank. The solution involves using the equation p = m/v, where p is density, m is mass, and v is volume. The conversation also discusses the relationship between density and specific gravity.
amy bowersock
Find: (a) volume of plank (b) bouyant force (c) density of plank
mass plank = 877kg
mass bricks loaded on plank = 2.3 * 74 = 170.2
plank if floating level with surface of lake
p = m/vol
v = l w h
Fb = pfluid x g x volume
How does one calculate volume without known dimensions (only mass is know). It can not be derrived from density equation because density of plank is not given (and it varies a great deal)
Something floats when it's weight equals the weight of the displaced water
So what is the total weight?
How much buoyancy does it need - how much volume of water is displaced?
total mass is mass of plank (877kg) plus mass of bricks loaded on top of plank (170.2kg)
volume of plank and volume of water displaced is unknown. density of plank is unknown.
I assumed that mass of water displaced was equal to total mass of loaded plank (877kg + 170.2 kg = 1047.2 kg) since the plank is floating even with surface of water.
How do I find the density of the plank without knowing it's volume?
How do I find the bouyant force?
How do I vind the volume of the plank without knowing either density or dimensions?
Isn't the density of a material times the volume = weight?
If you know the ratio of volume in terms of a known density, then isn't that going to tell you something about the ratio of their densities and hence the density of the unknown?
Maybe the first 10 minutes of this lecture will help you better understand?
https://www.youtube.com/watch?v=ngABxM7jl0Q
Correct
The volume of the plank underwater is equal to the volume of water displaced.
You know the mass of water displaced and you know the density of water (since it says lake - assume fresh water)
How do I find the buoyant force?
If it is floating then the weight down must equal the buoyant force up.
yes, p = m/v. But in order to solve this equation, one must know two of the variables. In this case, neither the density of the object, nor the volume of the object is known.
I have calculated the volume of water displaced by doing the following:
Weight of fluid = (density of fluid)(volume of fluid)(g)
if weight or mass of fluid displaced is equal to mass of object, then...
1074.2 = mass of both fluid displaced and object, so...
1047.2 = (1000cm^3)( v)(9.81m/s^2)
v = .106.
Then I did the following:
Vobject = Vfluid(p solid / p fluid)
.106 = .106 ( psolid/1000cm^3)
psolid = 1.06m^3
now I can use p = m/v
1.06m^3 = 877kg/v
827kgm^3 = v
But still have to find bouyant force, if the above info is correct. I am not getting what the answer is supposed to be (final answer is given to us)
1000 kg/m³ is density of water.
Your volume is 1.047 m³ isn't it?
1.05 cubic meters is the density of the oak plank. But I have not been able to come up with this figure.
I don't know if I am not converting something properly. My most recent attempt was off by a decimal place (.106 vs 1.06 when answer is 1.05 cubic meters)
The volume quantity I have been able to surmise is 827 kg cubic meters (the given solution by the professor is 835 kg cubic meters.)
The buoyant force I have calculated is no where near what the provided answer is (answer provided is 10300 N). I calculate 10398.6N The difference between my calcuation and the given answer is more than just rounding differences.
Based on my previous post, can you tell where I went wrong with the applications of the formulas?
The volume is 1.047 m³. Not the density.
Density is in units of kg/m³.
Since you know that the volume of the plank and you know the mass is 877, then the density is 877/1.047 isn't it?
Now the buoyant force is also virtually given because they loaded it down to until the water was just level. The total of those bricks and plank is your buoyant force isn't it?
i got a similar problem with fluid dynamics , i got a test later in the week haven't been prepped for it at all just been handed some sheets wondering if anyone could help with an example i have got , as it will help me see what i need to do for future reference
thanks in advance
QUESTION
A cube of 0.25m length sides which has a weight of 50N is immersed in a tank of fluid .
If the specific gravity of teh fluid is 0.8, calculate
a) the density of the cube material
b) the density of the fluid
c) the resultant up-thrust of the cube
ATTEMPTS
w=mg
50=mg
50/0.8 = m
m = 62.5 kg
p=m/v
p=62.5/0.25x0.25x0.25
p=4000 kg/m3
Thats all i can manage i haven't really been taught this yet so any help would be appreciated
You've started on the wrong foot. The specific gravity is .8 and that expresses the ratio of the density of the liquid to that of water.
The gravity you want to determine the mass with is the same old same old 9.8 m/s2.
You have written mass of bricks = 170.2 I am assuming that this is in kg.
Let M=mass of plank,
V = volume of plank,
p_plank = density of plank
p_water = density of water
Forces on the plan plank are
1. Force of gravity = Mg downward
2. Force by weight of bricks = 170.2*g downward
3. Buoyant force V*p_water*g upward
Plank is floating. So net force on it = 0
Therefore M*g + 170.2*g - V*p_water*g = 0
Divide by g,
M + 170.2 - V*p_water = 0
In the above, substitute M=877 kg and p_water=1000 kg/m^3. Then you can find V.
That will give (a)volume of plank
(b)Buoyant force=V*p_water*g
In this, substitute V from (a), p_water=1000 kg/m^3, g = 9.8 m/s^2 and you will find buoyant force
c) Mass is given. You have calculated volume. So you can calculate density.
Ah yeah i see , is the specific gravity of the fluid the relative density of it then? so the density will be 800 i think
trotter said:
As the specific gravity of the fluid the relative density of it then?
Yes specific gravity is the same as relative density (relative to water that is)
It's not used much in metric countries because water has a density of 1g/cc so then density and relative density come out to the same thing (doesn't work quite as well in Kg/m^3)
It's most important use is in beer - the specific gravity depends on the amount of sugar in the original brew and so the strength of the final beer.
1. What is Archimedes' Principle?
Archimedes' Principle states that the buoyant force exerted on an object submerged in a fluid is equal to the weight of the fluid that the object displaces.
2. How do you find the volume of an object using Archimedes' Principle?
The volume of an object can be found by dividing the weight of the object by the density of the fluid it is submerged in. This is because the buoyant force is equal to the weight of the displaced fluid, and the weight of the object is equal to its volume multiplied by its density.
3. How do you calculate the buoyant force using Archimedes' Principle?
The buoyant force can be calculated by multiplying the density of the fluid by the volume of the displaced fluid. This is equal to the weight of the object.
4. How do you determine the density of a plank using Archimedes' Principle?
To determine the density of a plank, you will need to know its weight and volume. Using Archimedes' Principle, you can submerge the plank in a fluid of known density and measure the buoyant force. This will allow you to calculate the volume of the plank, and then the density can be determined by dividing its weight by its volume.
5. What are some real-life applications of Archimedes' Principle?
One example of Archimedes' Principle in action is the floating of ships. The buoyant force of the water allows the ship to float, even though it is much denser than the water. Additionally, this principle is used in the design of submarines, hot air balloons, and even life jackets to ensure that the object has enough buoyant force to stay afloat.
10K
