Solving Arctan Problem: y'=\frac{1}{1-(lnx)^{-2}}
  • Thread starter UrbanXrisis
In summary, we discussed the derivatives of y=tan^{-1}(\frac{1}{ln(x)}) and y'=\frac{1}{1-(lnx)^{-2}}. It was determined that the derivative of \frac{1}{ln(x)} must be taken into account, and it can be calculated using the derivative of a division or the derivative of (\ln(x))^{-1}. We also found that (tan^{-1} (f(x)))' = \frac{f'(x)}{1+(f(x))^2}. Finally, we made a minor correction to the derivative formula, resulting in y'=\frac{1}{-x\ln(x)^{2}-x}.
UrbanXrisis
1,196
[tex]y=tan^{-1}\left(\frac{1}{ln(x)}\right)[/tex]
[tex]y'=\frac{1}{1-\left(\frac{1}{ln(x)}\right)^2}[/tex]
[tex]y'=\frac{1}{1-(lnx)^{-2}}[/tex]
is this correct?
do I have to take into account the derivative of [itex]\frac{1}{ln(x)}[/itex]?
if I do, what is the derivative of [itex]\frac{1}{ln(x)}[/itex]?
Yes, you need to take into account the derivative of [itex] \frac{1}{\ln(x)} [/itex].
You could either do the derivative of a division or do the derivative of [itex] (\ln(x))^{-1} [/itex].
[tex]y'=\frac{1}{1-(lnx)^{-2}}*\frac{1}{x(lnx^2)}[/tex]
[tex]y'=\frac{1}{x(lnx^2)-x}}[/tex]
is that it?
is that it?
Little changes...
[tex]y'=\frac{1}{1+(lnx)^{-2}}*\frac{-1}{x(\ln(x))^{2}}[/tex]
Something else i noticed
[tex] (tan^{-1} (f(x)))' = \frac{f'(x)}{1+(f(x))^2} [/tex]
can that become [tex]y'=\frac{1}{-x(lnx^2)+x}}[/tex]?
Stop putting the square next to the x like that, use parentheses.
sorry, didn't notice that
[tex]y'=\frac{1}{-x(lnx)^2+x}}[/tex]
that's what I meant
Sure, except for the sign problem.
[tex]y'=\frac{1}{-x\ln(x)^{2}-x}[/tex]
1. What is arctan and how is it related to this problem?
Arctan, also known as inverse tangent, is a mathematical function that is the inverse of the tangent function. It is used to find the angle in a right triangle based on the ratio of its sides. The problem provided involves solving for the derivative of a function involving arctan.
2. What does the given equation represent?
The given equation is a differential equation, specifically a first-order ordinary differential equation. It represents the rate of change of a function y with respect to a variable x, where the rate of change is equal to 1 divided by 1 minus the natural logarithm of x squared. This equation can be used to find the slope of the tangent line to the curve of the function at any given point.
3. How do you solve this type of differential equation?
To solve this type of differential equation, we can use the method of separation of variables. This involves isolating the variables on opposite sides of the equation and integrating both sides. In this case, we can rewrite the equation as y'(1-(lnx)^2) = 1 and then integrate both sides, leading to the solution y = ln|lnx| + C.
4. Can this problem be solved using other methods?
Yes, there are other methods that can be used to solve this problem, such as the method of substitution or the method of integrating factors. However, the method of separation of variables is often the most straightforward and efficient method for solving first-order differential equations.
5. How can this problem be applied in real-life situations?
This problem can be applied in various real-life situations, such as in physics and engineering. For example, it can be used to calculate the velocity of an object moving along a curved path or the temperature change in a cooling system. It can also be used in financial modeling to determine the rate of change of investments or interest rates.
