Is division by zero a logical error in this proof?
  • Thread starter Lizwi
  • Tags
    Numbers
In summary, the mistake is near the end of the proof where the author tries to use square roots that are not positive or negative to prove a point. This fails because if a=b, then multiplying (a-b) both sides doesn't make sense because a-b=0.
Lizwi
40
That's false!, since this logic a + b = t
(a + b)(a - b) = t(a - b)
a^2 - b^2 = ta - tb
a^2 - ta = b^2 - tb
a^2 - ta + (t^2)/4 = b^2 - tb + (t^2)/4
(a - t/2)^2 = (b - t/2)^2
a - t/2 = b - t/2
a = b
gives false results there must be an error in it because we know that two things will never equal 3 things that's impossible. 2 is not 3, you know this. A person who did this proof should have doubted his logic because it produce the obviously false results.
What do you say?
The mistake is near the end:
is correct, but this does not necessarily mean that
a - t/2 = b - t/2
Since a square root can be positive or negative, (a - t/2)^2 = (b - t/2)^2 implies that:
either
(1) a - t/2 = b - t/2
or
(2) a - t/2 = - (b - t/2)
From (2):
a - t/2 = t/2 - b
a + b = t/2 + t/2
a + b = t
We're back where we started!
Since t/2 = (a+b)/2, |a - t/2| = |b - t/2|. Assume a < b, then a - t/2 < 0 and b - t/2 > 0.
If a=b, multiplying (a-b) both sides doesn't make any sense because a-b=0. Because that way any equation could be proven true. Just multiply 0 both sides and say 0=0.
No... If you say that x=Sqrt(b)+c-d, then yes this equation implies that 0*x=0*(Sqrt(b)+c-d) which means that 0=0. The opposite, going from 0=0 to x=Sqrt(b)+c-d involves division by zero, which doesn't make sense.
I think Michael C hit the nail on the head.
Well we both basically mean the same thing.
1. Are all numbers the same?
No, not all numbers are the same. Numbers can have different values and properties, such as being odd or even, positive or negative, rational or irrational, etc.
2. Can different numbers have the same value?
Yes, different numbers can have the same value. For example, both 2 and 3 squared have the value of 9.
3. Are numbers infinite?
Yes, numbers are infinite. There is no limit to the amount of numbers that can be counted or written down.
4. Why do we use different types of numbers?
We use different types of numbers to represent different quantities and values. For example, whole numbers are used to count objects, while decimals are used to represent fractions or parts of a whole.
5. Is there a largest or smallest number?
No, there is no largest or smallest number. Numbers can continue infinitely in both directions, and there is no number that is the absolute largest or smallest.
  • Differential Equations
