What is the net charge and why does it matter?
  • Context: Undergrad
  • Thread starter Thread starter CURIE WILLEY
    Atoms Neutral
The discussion revolves around the concept of electric charge, specifically focusing on the definition of neutral particles and the implications of net charge in atomic systems. Participants explore the nature of electric fields in relation to charged and neutral particles, as well as the behavior of atoms in classical and quantum contexts.
  • Some participants define a neutral particle as one with no electric charge, while others specify it must have no net electric charge.
  • There is a discussion about whether an atom can be considered neutral despite the separation of its charged components (protons and electrons), with some arguing that this separation implies a non-neutral state.
  • One participant suggests that if an atom has a net charge of zero, it should not have an electric field around it, while others challenge this view by citing examples such as dipoles, which can have zero net charge but still possess an electric field.
  • Some participants emphasize the importance of distinguishing between classical and quantum mechanical descriptions of atomic structure, noting that the electron's position is not fixed in a quantum model.
  • There is a contention regarding the implications of having a net charge of zero and whether it necessarily leads to the absence of an electric field, with participants providing differing interpretations and examples.
Participants do not reach a consensus on the relationship between net charge and the presence of an electric field. Multiple competing views remain regarding the definitions and implications of neutrality in particles and atomic systems.
Some participants' arguments depend on classical interpretations of particles and fields, while others invoke quantum mechanics, leading to potential misunderstandings based on differing foundational assumptions.
  • #31
CURIE WILLEY said:
As posted previously, definition of charge says, Electric charge is the physical property of matter that causes it to experience a force when close to other electrically charged matter.
This discussion is all about definitions and I suppose that it's important that we get the definitions right. Different sources are likely to define charge in slightly different ways with some definitions being more detailed than others.
Your definition above is not necessarily a good definition but keeping closely to it I think it can be improved as follows:
Electric charge is the physical property of "certain particles" that causes "those particles" to experience a force when close to other electrically charged "particles".
I know the definition needs improving but the point I'm trying to make is that it's better to think of charge not as a property of matter (or atoms whatever) but as a property of certain particles within that matter.
  • #32
Far too much so, I think. The 'definitions' thing gets in the way of understanding all too often. If one's interpretation of a definition leads to a paradox then the thing to do is to re-examine the definition rather than to obsess about the apparent paradox. Science is greater than the limited definitions that people try to impose on its parts.
  • #33
sophiecentaur said:
In that case, you are using your own definition of net charge. That definition will not take you anywhere useful and your problems are only just beginning.
No, Sir. I am not using my own definition.
What is charge?
Electric charge is the physical property of matter that causes it to experience a force when close to other electrically charged matter.(This definition has been extracted from wikipedia)
Do you agree this?
Then, if the particle has electric charge, there is an electric field around it.
Do you agree this?
What is a Neutral particle?
In physics, a neutral particle is a particle with no electric charge. (This definition has been extacted from wikipedia)
Do you agree this?
So, a particle will be neutral, if it has no electric charge.
Do you agree this?
In other words, a particle will be neutral, if it has no electric charge, then it implies that it has no field around it.
Do you agree this?
  • #34
A dipole is not a particle, so you will, of course, get nonsense out of an argument that assumes it is.
I know that definitions can give you a warm, secure feeling because you can get exam marks by quoting them but that particular definition -
is not well thought out. (It's only from Wiki and I wouldn't want to fly in an aeroplane that had been designed only on the information found in Wiki) It actually says nothing useful at all because it is a circular definition, using 'charge' in both cause and effect. It is not a serious definition at all; it is wide open and not fit for taking further into the subject, at any rate.
What are your motives here? Are you on a crusade to discredit all EM theory or do you want to understand it better? If you want to understand it better then don't waste time hanging onto statements that are not well founded. Use a proper textbook and do it the mainstream way. You call people "sir" but you are not giving them, or the subject the respect that word should imply. Do you really think you are right?
  • #35
Yes, you are.
CURIE WILLEY said:
What is charge?
That one is ok, but not really a good wording.
Ok, but not exhaustive.
This is at best sloppy wording. At worst it is plain wrong. A neutral particle has no NET electric charge. There can be as many charges inside it as you want to. Having no net charge does by no means imply that there is no charge at all inside. Please: NEVER think that wikipedia is a good source for thorough science.
Yes, it will be neutral if there are no charges inside, but this is not a necessary condition for neutrality. For a particle being neutral, it is sufficient that net charge is zero. In that case there will be charges inside which create fields. The superposition of all of these fields will just cancel if you place all the charges at the same position, but this is not a prerequisite for neutrality.
No, this conclusion is not warranted at all.
  • #36
Nugatory said:
You are overlooking a subtlety in the definitions. Electric charge is a property of the matter that makes up a system, whereas net charge is a property of the system. It is possible for a zero-net-charge system to be assembled out of pieces of matter that are charged, and depending on the arrangement of charges within the system, there may be a non-zero electric field around the system.
Thank you for the reply Sir.
Isn't system also made up of matter?
Then, how does it make difference in saying charge is a property of matter and net charge as a property of system.
I think both are one and same. The difference is one is made of single particle, so the word charge is associated with it. And the other is made of many particle, so the word net charge. If I am wrong, correct me, Sir.
  • #37
CURIE WILLEY said:
What is electric charge?
So, if the particle has electric charge, there is an electric field around it.
Yes, but then you go on to conclude that if there is a field, then there is "a" charge producing it.
That is just faulty logic.
If A, then B does not imply that if B, then A.
I think this logical fallacy is at the root of your concern.
So what is producing the dipole field? A collection of charges, which happens to sum to zero net charge.
  • #38
DrClaude said:
This statement is completely wrong. If you want to progress, you'll have to accept that you are wrong, and try to understand why.
Take a system made up of ##n## point charges ##q_i## located at positions ##\mathbf{r}_i##. The net charge of the system, as ZapperZ pointed out, is
Q = \sum_i q_i,
whereas the electric dipole moment is
\mathbf{p}(\mathbf{r}) = \sum_i q_i (\mathbf{r}_i - \mathbf{r}).
Clearly, you can have ##Q=0## while ##|\mathbf{p}| \neq 0##. Indeed, take two charges with ##q_1 = -q_2##, with ##\mathbf{r}_1 \neq \mathbf{r}_2##, and this is exactly what you get.
Even if the configuration of charges is such that the net charge and dipole moment are zero, you can still have non-zero higher moments, such as the quadrupole.
Do you agree this dipole equation?
##E=\frac{1}{4\pi\epsilon}.\frac{p\sqrt{3\cos^2\theta+1}}{r^3}##
Do you agree that electric field around the dipole exists if and only if distance between the charges is zero (i.e p=2aq, 2a is the distance between charges.)?
Note that dipole is not a particle, it is a system of two particles. When distance becomes zero, field will be zero, so net charge (not sum of charges) will be zero. When distance between charges is not zero, net charge will not be zero, but still sum of charges will be zero.
In your above calculation, sum of charges is always zero. But net charge will be zero if and only if distance between charges is zero i.e according to you, when##\mathbf{r}_1 = \mathbf{r}_2## . This is the reason why I am disagreeing your calculation.
Whether I must be wrong or the other case. I can't run without accepting the reality. I think we have a difference in understanding the concept of net charge.
According to me, sum of the charges will always be zero. But, net charge will be zero if and only if distance between the charge is zero. I think there is a distinction between net charge and sum of charge.
Do you agree this, Sir?
If you explain this, I think I will get my misunderstanding off or we would get some conclusion.
Anyway, sorry for not being under discussion from here on wards as I am preparing for exams tomorrow. I will be active by tomorrow. Thank you for giving your precious time.
  • #39
$$E=\frac{1}{4\pi\epsilon}.\frac{p\sqrt{3\cos^2\theta+1}}{r^3}$$
OK.
You have that backwards. That field exists if the distance between the charges is non-zero.
No. The net charge, which is just the sum of the charges, will be zero for all distances.
How in the world do you deduce this?
That's for sure.
That's nonsense. Net charge means the sum of the charges. Nothing more.
  • #40
CURIE WILLEY said:
As posted previously, definition of charge says, Electric charge is the physical property of matter that causes it to experience a force when close to other electrically charged matter. If we say dipole has no net charge, it can't experience any force, if we keep it near electrically charged matter. I hope, dipole (if distance between charges is not zero) experiences force when kept near charged matter. So, I disagree the statement of dipole having zero net charge. Correct me, if I am wrong Sir.
I should agree your statement also. There is one positive and one negative charge. If we add, we get zero. But, it contradicts the definition of electric charge according to my explanation above. If you say I am wrong, you are indirectly proving definition of charge as incorrect (If my explanation above is agreed by you). In order to make the definition of charge not getting violated and even the rule of algebra, I think we can add or subtract charges if and only if the distance between them is zero. Correct me if I am wrong, Sir.
I should say charge is the fundamental properties of 'some sub-atomic particles' not of matter so a decision if a body is having charge or not, is established by analysing the sub-atomic particles it contains.
Since charge is the property of some sub-atomic particles( due to which it exerts force on other sub-atomic particle(s) carrying same property) and is not the property of matter(in bulk), some sub-atomic particles have this property they are called electrically charged and those sub-atomic particles which lack this property are called neutral. So it is only the sub-atomic particles which have charges. And this property of them is so fundamental that you can not snatch it(property) from them or transfer it to some,different body. Remember charge can neither be created not it can be dystroyed. We can not add(or inculcate) properties of charge in any sub-atomic particle.
What most you can do is to transfer these particles(along with there properties of charge) into other body so that it also starts showing electrical interaction. And we start saying that the body is 'charged'. But here the word 'charged' is used in a sense that it is tonned(or filled) with sub-atomic particles( which are actually the particles for which the definition of charge is applicable). And if a body is tonned with such particles(that is we 'charged' it with what is called charge doesn't mean this body falls in the cateogory of charge because charge is exclusively the properties of sub-atomuc particles. If you carefully look at the definition of electric charge you will,yourself find that it is the properties of sub-atomic paeticles only. See it and read carefully what is said, you will get your answer.
I will add: TRUE OR FALSE
1). A neutral sub-atomic particle can have electric field. FALSE
2). A neutral object can't have electric field. FALSE
  • #41
Double negatives are too much like hard work.
I think the problem that ovais has been having is not knowing what the simple word "net" means.
  • #42
I think you meant CURIE WILLEY, not ovais.
  • #43
Yes, I did mean CURIE WILLEY. Sorry, ovais.
This thread is what we get when one person is determined to hang onto the literal meaning of one badly worded phrase at all costs, rather than trying to get to the intended meaning of it. If CURIE WILLEY spent as much time reading around this as he / she has spent arguing, then he / she would have a reasonable understanding of it all by now.
  • #44
Doc Al said:
You have redefined the meaning of 'zero net charge'. You think it means "there is no field"; all it really means is that the total charge is zero.
You seem to think that something with zero net charge is equivalent to something with no charges at all and thus no fields. Not so.
Wrong.
Since you are so confused about what "net" means, I wonder what you think of an object that experiences a net force of zero. Do you think that that implies there are no forces acting on it?
According to you, if the system is neutral, still there can be electric field around it. Isn't it,sir?
According to me, if the system is neutral, there exists no electric field around it.
According to coulombs law, force between the charges is given by the equation
##F=\frac{1}{4∏ε}.\frac{q_1q_2}{r^2}##
If ##q_2## has net charge zero, it can't exert force on other charge according to me, because it has no electric field around it.
If ##q_2## has net charge zero, it can exert force on other charge (##q_1##) according to you. So, force in the above equation should be non-zero according to you. But, in the equation if you substitute ##q_2=0## F =0, it is not non-zero. This concludes that there will be no field around a neutral object.
Coulombs law is only applicable for point charges, the reason I know is that, if charges is not assumed to be points, charge distribution will not be uniform. In the above case I have assumed to be system of two charges to be ##q_2##. Then, we need to assume that charge has uniformly distributed over ##q_2##, then we have overcome problem of point charge. Now, I hope my explanation holds good. If it is wrong. Pardon me, sir. And please explain how it is wrong. Moreover, in problems of coulombs law, we will have ##q_2## to be more than charge of electron, indicating it is applicable for system of charges (if charge distribution is uniform).
  • #45
According to everyone else who posted here besides you, too.
You are wrong here. That has already been pointed out.
This has nothing to do with applying Coulomb's law. Substituting ##q_2=0## means that you have no charges at all. For a system with no NET charges, you need to apply Coulomb's law for every single charge inside your system which makes up the net charge of zero. It only takes 5 minutes of time to do the math yourself for a simple dipole and you will see that a vanishing force for systems containing more than one charge is actually the exception because the distances from each point charge inside your system to every point outside your system differ slightly. That will happen only if all the charges are precisely at the same position. Just go and do the math. It is trivial.
No, it is not good. It simply does not describe an atom or a dipole or anything interesting, jst charges placed at the same position. This does not describe anything that happens in reality. And by the way you can apply Coulomb's law for inhomogeneous charge distributions. There is no problem with that.
  • #46
Substituting q2=0 means that you have no charges at all
Thank you for the reply, Sir. In my explanation, I have considered q2 as system of charges. Thus, q2=0 means net charge as zero. In coulombs law equation, for using q2 as system of charges I have given explanation below that post. For that, I didn't understand your reasoning for disagreeing it. For inhomogeneous charges we consider integration. If I am wrong, pardon me and explain Sir.
  • #47
No. It does NOT mean that. You can ONLY enter the net charge of the system as q2 if they all are exactly at the same position. This is not happening in any real system. To apply the law correctly, you need to apply the law for every single charge in your system. If you have a positive and a negative charge in your system, you apply the law once with -e for q2 for the negative charge and once with +e for q2 for the positive charge. Then you sum up the two forces you get for every position. This will only give you zero net force if the two charges are at exactly the same position. Otherwise the force will not be zero at every position.
  • #48
@ CURIE WILLEY
I have +1 Couomb on one hand and I have -1 Coulomb in the other hand. By 'your definition', what is my net charge?
(I have very strong arms.)
  • #49
Coulomb's law is not applicable to an arbitrary system with uniform charge distribution. You have to use point charges and if you do that the electric field will not be generally zero. Therefore your reasoning is wrong and objects with zero net charge may generate electrical fields.
  • #50
sophiecentaur said:
@ CURIE WILLEY
Thank you for the reply, Sir. Please behave well. I may be wrong anywhere, explain why I am wrong. Instead don't use rude language (hate speech).
  • #51
CURIE WILLEY said:
Thank you for the reply, Sir. Please behave well. I may be wrong anywhere, explain why I am wrong. Instead don't use rude language.
What "rude language"? Are you offended by the Inverted Commas?
I am asking a very short and straightforward question. If you can't answer it then you need to rethink your ideas.
  • #52
Why don't you just answer the question? No one's being rude. (And your error has been explained several times over!)
  • #53
@DOC AL. Thank you for the reply, Sir. If we have +1 charge in one hand and -1 charge in the other hand, net charge will not be zero (as distance of separation is not zero). In that case, according to me, we need to calculate the electric field created by that dipole at any point, which is at distance r from the center of dipole (we can calculate this from the equation I have given at the begining). By substituting the obtained values of r and E in the electric field produced by a charge equation, we get q value (i.e net charge).
Here, I am not arguing myself to be correct. I am just clarifying my doubts. If I have not behaved well anywhere, pardon me. I will be replying until I get satisfactory result. You may be correct, but I may not be getting your ideas. I hope you will answer me, until I get clarified. Thank you.
  • #54
OK, that is your problem. Charge is not a function of position. You are still hanging in on to that statement you started the thread with, which is incorrect. Saying you read it on Wiki, is no justification for it. You will need to let that go, I'm afraid. or launch down your own road towards a different version of Physics. PF will not be following you there.
You are trying to apply blind logic to a faulty premise. You need a more reasonable approach or you will get nowhere.
  • #55
That does not matter. Draw a circle around your system and count all the charges inside. The number you get is your net charge and here it is zero. The position or separation does NOT matter. This is your very own definition nobody else uses. You cannot expect people to help you if you make up your own language.
  • #56
Wrong. A system of charge may or may not have an electric field around it. As said charge is the exclusive property of (certain) sub-atomic particles not a property of matter in bulk. Charge is such a fundamental property that you can not remove or add this property to anything, what you can only do is to transfer the charge to it other bodies and we say it is charged or toned with or filled with charge. The body just have charge(sub-atomic) particles but itself doesn't become charge(or a collection of charge) as the definition of charge fits only for (certain) sub-atomic particles(like electron and proton).
CURIE WILLEY said:
Accrding to coulombs law, force between the charges is given by the equation
Coulombs law is valid only for point charges not for group of charges.
  • #57
I must add here, as sophiecentaur Sir noted, we can see that for different value of r, we get different value of net charge. For the observer at infinity, net charge of the system will be zero. For the observer near the system the net charge will be maximum.
  • #58
Wrong. I guessed here the key problem is your wrong understanding about the fundamental of charge. Charge not the property of matter(in bulk) it is the property of(certain)sub-atomic particles(like,electron, proton etc). Charge is not a substance rather it is property of certain sub-atomic particles just as mass is the property of any matter charge is also a property. You can add mass to a body what you only can do is to add matter(having property of mass) so that they get weighed. But by doing this you can not call matter as mass matter and mass is different. And definition of mass should not be applied to matter in any case.
Yes offcourse, but for this it must be a particle(or better I call a sub-atomic particle like electron).
  • #59
sophiecentaur said:
OK, that is your problem. Charge is not a function of position.You are still hanging in on to that statement you started the thread with, which is incorrect. Saying you read it on Wiki, is no justification for it. You will need to let that go, I'm afraid. or launch down your own road towards a different version of Physics. PF will not be following you there.
Thank you for replying and being cooperative, Sir. As the discussion has followed, definition (charge or neutral particle) of wiki has been said to be wrong. If correct definition is provided, it will be greatly appreciable. This decides whether I am launching a new road towards a different version of Physics or not, or PF will be following me or not.
I will try to bring brightness where there is blind logic, please provide info on where there is blind logic.
  • #60
CURIE WILLEY said:
According to me, sum of the charges will always be zero. But, net charge will be zero if and only if distance between the charge is zero. I think there is a distinction between net charge and sum of charge. [/B]
If you think there is a distinction(which you have created by your own and offcourse you can, but society of science has already made these two terms alike and probably they are not going to change for you) then read Gauss Law which talks about net charge enclosed by a body. And it says the flux linked by Gaussian surface is proportional to the NET CHARGE contained in it. And in the calculations to find net charge you just need to take algebraic SUM OF THE CHARGES, distance between them does not affect the net charge.
  • · Replies 17 ·
  • · Replies 19 ·
9K
