Rudinhoob
- 33
...outside integrated circuits?
Can OpAmp's replace them?
Do you have figures for your assertion? I tend to view such proclamations with skepticism.Rudinhoob said:But their usage is in decrease. The number of transistors in todays circuits is much less than from 80s. The same with vacuum tubes.
Even if it is true that their usage is declining, they'd still have enough advantages that would make it bizarre to say they're dead.
Rudinhoob said:I'm not saying they are 100% dead like vacuum tubes, I mean their use is so limited outside the ICs.
Rudinhoob said:Audio amplifiers?
I am intrigued. My first thought was displays for televisions and computer monitors, then realized that no, evacuated tubes are no longer used to make them either.berkeman said:There is a much more important application... think BIG TUBES!
Rudinhoob said:I'm now thinking some military applications where vacuum tubes are not damaged by strong electromagnetic waves? What about communication transmitter/receivers?
My friend who plays the guitar in a metal band once told me that tube amps were preferred by almost everyone in his circles. Dumbfounded, I looked it up, and it turns out (IIRC) that tubes have a strong distorting third harmonic which "sounds good". Realizing that my exquisite rational skills couldn't probe into the domain of taste, I had to let it go, but I couldn't help thinking that his beloved tube amp did a little more than advertised (i.e., it's not simply amplification).berkeman said:[...] one can certainly debate whether using vacuum tubes helps the audio quality (some argue that it does, others don't think so).
gnurf said:My friend who plays the guitar in a metal band once told me that tube amps were preferred by almost everyone in his circles. Dumbfounded, I looked it up, and it turns out (IIRC) that tubes have a strong distorting third harmonic which "sounds good". Realizing that my exquisite rational skills couldn't probe into the domain of taste, I had to let it go, but I couldn't help thinking that his beloved tube amp did a little more than advertised (i.e., it's not simply amplification).
berkeman said:... one can certainly debate whether using vacuum tubes helps the audio quality (some argue that it does, others don't think so).
jim hardy said:One of the better reports i recall demonstrated the differing harmonic content of tube vs solidstate pre-amplifiers when over-driven into distortion. Which is how the musicians participating in the study used them, to surprise of the investigators..
Solidstate amps tend to provide more symmetric clipping than tubes because of the latter's cutoff and saturation behavior. Solidstate amps tend to be feedback controlled so they'll drive right to the power supply rails instead of approaching them in a gradual, nonlinear fashion.
They clip both top and bottom peaks alike, and it begins suddenly.
Recall from your Fourier that odd harmonics affect both peaks symmetrically, even ones don't.
The investigators' Fourier analyzer showed the tube amp output when overdriven to contain more even numbered harmonic content, as a result of asymmetric clipping, than did the solidstate amp with its symmetric clipping..
So, to a musician's ear they produce different "overtones".
pretty dumb investigators if they didn't know that guitarists were using their guitar amps for distortion.
there is also some reactive components in a tube amp. transformers (with hysteresis) and coupling capacitance...
jim hardy said:Thanks for your clarifications and vocabulary additions ..
another trait of inductors is their tendency to maintain current(Lenz), and a power pentode is rather a constant current device. So a tube amp likely is more of a current source(high impedance) than a voltage source(low impedance)... that's why the precaution never let a tube amp operate into open circit it'll wreck the output transformer's insulation...
Amplifiers tend to be tested with resistive load so voltage and current have same shape..
But a speaker has inductance and inertia - it's really a motor-
and a motor responds different to a high impedance current source than it does to a low impedance voltage source. I've never seen a mathematical analysis , but amplifier impedance is a term in speaker enclosure design...
Rudinhoob said:...outside integrated circuits?
Musicians - even those who invent 'new' music all tend to be quaint old fashioned things when it comes to their amplifiers. The Valve Sound is preferred yet it is the most Un-Hifi you could ever imagine. It is common for a band to use old fashioned amps which are played into microphones and that signal goes to the massive (solid state) amplification of a stadium.gnurf said:My friend who plays the guitar in a metal band once told me that tube amps were preferred by almost everyone in his circles. Dumbfounded, I looked it up, and it turns out (IIRC) that tubes have a strong distorting third harmonic which "sounds good". Realizing that my exquisite rational skills couldn't probe into the domain of taste, I had to let it go, but I couldn't help thinking that his beloved tube amp did a little more than advertised (i.e., it's not simply amplification).
Yes, discrete transistors are still widely used in modern technology. While integrated circuits have become more prevalent, discrete transistors are still used in various applications such as power amplifiers, switching circuits, and voltage regulators.
Some people believe that discrete transistors are becoming obsolete because integrated circuits have become more advanced and can now perform the functions that discrete transistors used to be used for. Additionally, integrated circuits are smaller, more efficient, and cheaper to produce, making them more attractive to use in electronic devices.
Discrete transistors have several advantages over integrated circuits. They can handle higher voltages and currents, making them suitable for power applications. They also have a simpler design and are easier to troubleshoot and repair. Additionally, discrete transistors have a longer lifespan compared to integrated circuits, which can be susceptible to damage from heat and other factors.
Yes, there are still some applications where discrete transistors are the preferred choice. These include high-power and high-frequency applications, as well as specialized circuits that require specific performance characteristics that cannot be achieved with integrated circuits.
It is unlikely that discrete transistors will become completely obsolete. While integrated circuits are more prevalent, there will always be a need for discrete transistors in certain applications. Additionally, advancements in technology may lead to new and improved versions of discrete transistors that could make them even more relevant in the future.
