Gluons: Particles or Not? Evidence for their Particle Nature
In summary, gluons were originally proposed as a way to explain the Pauli exclusion principle and the color addition of quarks in baryons. They were later confirmed through experiments such as deep inelastic scattering and electron-positron collisions, which showed evidence of their existence. While gluons are considered particles, they also have attributes such as virtual particles and can interact with each other, making them a unique aspect of quantum mechanics.
friend
1,452
What evidence is there that gluons are even particles? They were originally proposed to supply an extra quantum number to comply with the Pauli exclusion principle. So gluons are supposed to carry a color-anticolor charge in order that the quarks in baryons would add up to the color white.
But if gluons are particles, then they spend some time traveling between quarks. And during that time between quarks, the color addition of quarks is not white. This is a bit like asking if electrons in a Helium atom must have opposite spins (Pauli exclusion principle), then what tells one electron what spin the other electron has?
Friend, one of the least endearing traits of your posts is your conclusion that since you don';t understand something, everybody else is doing it wrong.
Of course gluons are particles.
Likes AndrewGRQTF and weirdoguy
I'm not at all suggesting that others are doing it wrong. I'm simply trying to understand how we can be so sure gluons are particles as opposed to some other interpretation. Why mere questions should put you on the defensive is beyond me. As I understand it, gluons only occur in baryons which are very small. And they are massless and so travel at the speed of light for very short distances. I don't understand how we could possibly distinguish gluons as a particle from some other instantaneous process. Would glueballs prove they are particles? Or maybe it is necessary for gluons to interact with other gluons in order to obtain correct QCD results. Wouldn't that prove that they are something other than some relationship between quarks?
There are some pedagogical/historical papers around if you google for it (e.g. gluon discovery).
Here's an example of what comes up: https://arxiv.org/abs/1409.4232
So the story goes like this, once we collided electrons to protons at high energies (deep inelastic scattering), so that the electron could probe interactions with the proton constituents. What we saw was that the electrons interacted (via photons) with the "partons" (valance and sea quark particles which can interact with photons). Those measurements suggested that the partons carried about half of the momentum of the proton (suggesting the existence of neutral partons which could not interact via photons). At the same time and for many years, QCD as a theory (which predicted the gluons) was doing a good job in giving predictions or explaining what we saw in strong interactions (e.g. the prediction of charm quark followed by the discovery of charmonium mesons).
The discovery point of the gluon came with the electron-positron collisions, [itex]e^+e^- \to q\bar{q}g[/itex] (gluon-"Bremsstrahlung" process) which suggests 3 jets (a few of which were observed subsequently in several independent experiments) in the final state in the right kinematical region.
During that time, without any profound evidence (just suggestions), the debate of whether gluons existed or not was a reasonable one, and many people wouldn't or would believe in its existence. Today though it is ridiculous to question their existence.
Likes Klystron and fresh_42
Why did you choose that thread title then?
You can't apply intuition from classical mechanics in quantum mechanics. As you see it leads to conclusions that don't make sense.
The overall baryon is color-neutral at all times, it doesn't make sense to ask which color a given quark has at a given point in time - you can't even distinguish them.
No, they are in all hadrons.
That's like asking if a second moon of Earth would prove Earth has gravity. I guess it would but it is also completely unnecessary to look for it for that reason.
While true (there is gluon-gluon coupling) this is completely unrelated to your other questions.
ChrisVer said:
Brehmstrahlung
Bremsstrahlung
Likes Klystron
mfb said:
Bremsstrahlung
thanks! corrected it... I hate that word...
Likes Klystron
mfb said:
While true (there is gluon-gluon coupling) .
OK. Is the perturbation method of QFT unique to particles? I assume gluons interactions are calculated perturbatively.
That question doesn't make sense.
At high energies: Yes. At low energies that doesn't work as the coupling is too strong.
You know, in QFT where Feynman diagrams are used to help compute terms in the perturbative expansion for scattering amplitudes. But Feynman diagrams are a description of how "particles" interact, right. So QFT → perturbative expansion → Feynman diagrams → particles and only particles, right?
I'm thinking if ever Feynman diagrams can be used, then it proves we are talking about only particles. So if QCD used Feynman diagrams, then it must be referring to particles? But then why would glueballs not be more evident?
Not everything can be described as scattering process, and not all scattering processes can be calculated with perturbation theory.
Internal lines are virtual particles, they are not real (otherwise they wouldn't be called virtual).
To learn physics you need to start with the basics. Your questions are way ahead of your knowledge, that makes threads like this so problematic and relatively useless. The questions are based on misconceptions, and even in cases where they have a proper answer you would need much more background knowledge to understand that answer properly.
Likes Klystron and weirdoguy
Don't be afraid to venture a guess as to what real things these equations are actually talking about? I'm trying to get at the underlying ontology of it all. Why this math and not some other? I have a pretty good start, but I'm stuck at gluons. I'm trying to understand if they exist on their own or if they are only relationships between quarks . With electrons it's easy because we can observe their effects. But it seems we must rely on interpretations of math for quarks and gluons. If the same math holds (perturbation expansion) for quarks and gluon as for electrons, then it seem the math is pointing to particles. The trouble seems to be that we can write a wave function for an electron (for a particle moving), but we can't seem to write a wave function for quarks and gluons. So I'm not so sure about what they are, so I'm asking for help.
Incorrect. Maybe you can't.
Likes weirdoguy and websterling
Okay. Enough. If one of the physicists wishes to add reading material at an appropriate level to the thread please let me or another mentor know so that can happen. Because:
This thread content does not really seem PF quality. Thread locked.
Likes Nugatory and weirdoguy
1. What are gluons?
Gluons are particles that mediate the strong nuclear force, which is responsible for holding the nucleus of an atom together. They are considered to be the fundamental particles that make up protons and neutrons.
2. How were gluons discovered?
Gluons were first theorized in the 1960s by physicists Murray Gell-Mann and George Zweig, who were working on developing the quark model. The existence of gluons was later confirmed in the 1970s through experiments at particle accelerators.
3. Are gluons considered to be particles?
Yes, gluons are considered to be particles, specifically elementary particles. This means that they cannot be broken down into smaller components and are considered to be the building blocks of matter.
4. How do gluons interact with other particles?
Gluons interact with other particles through the strong nuclear force, which is one of the four fundamental forces of nature. This force is responsible for holding quarks together to form protons and neutrons, and also for holding these particles together to form atomic nuclei.
5. Are gluons affected by the Higgs field?
Yes, gluons are affected by the Higgs field, just like all other particles. The Higgs field is responsible for giving particles their mass, and gluons are no exception. Without the Higgs field, gluons would be massless and the strong nuclear force would not exist.
  • High Energy, Nuclear, Particle Physics
  • Beyond the Standard Models
  • Quantum Physics
