Are these capacitors blown?
  1. Jun 30, 2013 #1
    Q_Goest
    My daughter's TV won't turn on. Seems like the power panel. I'm not much of an electronics person but after looking around the net it seems capacitors are often to blame. Everything I've seen though shows a bulge in the capacitor with the potential of there being some loss of fluid inside that might appear as brown or black stuff.
    Attached is a picture of the 2 suspect capacitors. They're not bulging out but they both have black spots on the top. They look a bit like someone just marked them with a black drop of paint but none of the other capacitors have this black dot.
    Do you think these capacitors are blown?
  3. Jun 30, 2013 #2
    sophiecentaur
    2017 Award
    Did they always have the black spots on them? Was someone highly prescient, way back in the life of the TV? haha. What's the background to this? TV just stopped working?
    Many DVMs have a Capacitor measuring facitly these days so you could take them out and test them. You could be lucky and be able to change them (watch the polarity for the replacements). They are cheap enough. But, for two components to go, you would probably be looking at some other, common cause. You are right about Capacitors being the weak link.
    If you aren't into electronics circuits, fault repairing will probably be a bit beyond you (a really good way to spoil your day - I have been there too. If you can dis the outputs and look for DC outputs of 12V and 5V etc., without the receiver circuitry load, then that will tell you about the PSU. You could possibly get a new one - but you could probably get 'a local man' to look at it for not much money. New TVs are laughably cheap nowadays (the basic ones). If you really love your daughter, you could buy her a flashy big new one - or just tell her to do more homework for entertainment in her room, if you are a stingy ol' sod like me.
  4. Jun 30, 2013 #3
    Borek
    Staff: Mentor
    They don't look like swollen to me, and these black points look like just some mark, not a leak.
    Not that I am sure of anything.
  5. Jun 30, 2013 #4
    Integral
    Staff Emeritus
    I have repaired TVs by inspection and bulged caps are a good thing to replace. I can't tell if those the pic are bulged. It does not take much though. My last repair the caps were barely bulged, but replacing them did the trick.
    Modern circuit boards use lead free solder which requires a hotter soldering iron then the common hobbyist iron. What I did was to melt regular solder on top of the lead free this enabled me to remove the lead free and remove the caps. I replaced with regular solder.
  6. Jun 30, 2013 #5
    These could be examples of the notorious "capacitor plague" capacitors .These were poor quality capacitors most of which, I think, were manufactured in Taiwan They used inferior quality electrolyte which caused early failure. Try googling for details.
    Is it a Samsung TV? Some models have problems with cheap capacitors.
  7. Jun 30, 2013 #6
    Q_Goest
    It started with the TV shutting off randomly. After a while it would get worse and the TV would turn on at random. Kinda spooky I suppose if you're sleeping and the TV comes on all of a sudden in the middle of the night! Apparently that happened a few times, so my daughter exorcised the demon by unplugging it. Thank god for conservation of energy.
    Finally, the TV just gave up altogether and it wouldn't come on. So regardless of whether you tried the remote or the power switch on the side of the TV, it didn't do anything. From my limited experience, I'm thinking it's the power board.
    I figure I have nothing to lose by experimenting a bit. If I can't fix the power board, I could buy a new one if they're cheap enough or just get a new TV. It's not a large TV and no, she's not getting a big one! lol She'll be a sophomore in college next year so she doesn't need more distractions.
  8. Jun 30, 2013 #7
    Q_Goest
    Thanks for the feedback everyone. Yea, it's a Samsung. The capacitor says "Sam Young" on the side (made in S. Korea). A quick search found this from a message board:
    http://hardforum.com/showthread.php?t=1576580
    So I decided these must be the culprits and removed them. It was pretty easy with a copper wicking wire I saw a guy use on YouTube. Only took a few minutes. I ordered some new ones and will put them in and see how it goes. I'm just wondering if the 10 others on the board shouldn't be replaced as well but it's easy enough to take apart. I'll leave them for now I suppose.
  9. Jun 30, 2013 #8
    Q_Goest
    Oh - one more thing. Can these be tested? I put a ohm meter on them and the resistance slowly rises. Shorting it out brought the resistance back down and measuring resistance slowly brings it up. I'm thinking that might be normal though. Any ideas?
  10. Jun 30, 2013 #9
    NascentOxygen
    Staff: Mentor
    Sounds normal.
    Caps look fine to me. But the cans can hide a multitude of problems. Go ahead and replace them. While you're closely scrutinizing the board, look for a dodgy solder joint somewhere, that also could be the cause of the trouble, or a poor connection on a connector. Luck plays a large part in identifying faults!
    Good luck! :smile:
  11. Jun 30, 2013 #10
    Q_Goest
    Both cap's seem to be good... <sigh> I read the instructions in my Fluke meter book and realized it has a capacitor tester and they both checked out within 10%.
    After carefully scrutinizing every solder joint on the board I'm coming up empty. I'll replace the caps now that I have 2 coming in but I'm not holding out hope.
    Is there any way to test cap's without removing them from the board? I assume not. :(
    Any suggestions would be great!
  12. Jun 30, 2013 #11
    jim hardy
    Not a sure-fire one size fits all test...
    What you can do for line frequency filter capacitors in power supplies is this -
    measure the voltage across capacitor with meter set to DC volts, write down the number.
    measure the voltage with meter set to AC, write down the number.
    The AC voltage across the cap should be maybe 10% of the DC value, not 25% or 50%.
    That's on the line side of the switcher where you're working with 5 or 60 (or 100 or 120) hz.
    On other side of switcher where you're dealing with tens or hundreds of khz you can try similar readings, but many DMM's aren't very good on high frequency AC measurements. Check your Fluke manual for its AC frequency response.
    Basic premise is this - the function of those filter capacitors is to remove AC from the DC supply. Symptom when they fail is there's lots of AC in your DC supply, and the DC reads about 1/3 low.. That's because when cap is failed open circuit, DC voltage dips clear to zero twice per line cycle.
    That sounds normal. The cap is being charged by the current from your ohmmeter. Lower ohm scale should charge it more quickly. So let it charge, then switch your meter to DCVolts and watch it discharge. You should see a time constant of RXC where R is input resistance of your Fluke (from manual - probably ten megohms).
    old jim
  13. Jul 1, 2013 #12
    sophiecentaur
    2017 Award
    Apart from the relative probability factor, what makes you suspect the Capacitors? Have you checked all the voltages emerging from the PSU? Does your Fluke have a frequency measuring setting? You can see whether your switcher is actually oscillating. You are looking for a value in excess of 20kHz. Is the board actually getting full mains volts on it?
    Sorry for what may be obvious points to you but fault finding is an esoteric field and requires a particular approach.
    Have you tried a search on the model you have? There may be a repair forum that 'knows' about your specific problem with your particular PSU. I have had some great success with Fridge Freezers, dish washers and smart phones , using help from a youTube movie. I never would have managed to replace the phone's screen without seeing it on youTube.
  14. Jul 1, 2013 #13
    Also pretty common for TV's to lose a MOV in the incoming power connection - or even a fuse... I am sure there is a lablel in the TV that says - no user serviceable part inside - generally good advice.
    If you can find a local repair shop - they will generally give a basic analysis - maybe $25? Or a local vocational school with electronics class would be happy to give it a go.
