Area of a Circle: Solving the Equation
  • I
  • Thread starter Vector1962
  • Tags
    Area Circle
In summary: A}{4} = r \int_0^{\pi/2} \cos^2 t \mathrm{d} t = r \int_0^{\pi/2} \dfrac{1 + \cos 2t}{2} \mathrm{d} t = \dfrac{r \pi}{4} #### \displaystyle A = r^2 \pi ##You know that the area of a circle is ##\pi r^2##, so what's the problem?
Vector1962
61
TL;DR Summary
area of a circle in terms of Y if center of circle is at (0 , r) --> A=f(y)
i can write the equation of circle easy enough, x^2+(y-r)^2=r^2. i get A=r^2/2 * asin((y-r)/r) + (y-r)/2 * sqrt(r^2 - (y-r)^2) through integration (using change of variable). Letting u = (y-r) and u^2=(y-r)^2, du= dy. Here's the rub... it's not right... :-) Appreciate and thanks in advance for any pointers... it's been a long time since I've done anything like this.
Mathematics news on Phys.org
Vector1962 said:
Summary: area of a circle in terms of Y if center of circle is at (0 , r) --> A=f(y)
I'm not sure I know what you are doing. Normally, you would calculate the area of half or a quarter of the circle using ##x^2 + (y - r)^2 = r^2##. If you try to do the whole circle, then ##y## is not a single-valued function of ##x##.
Likes malawi_glenn
I agree with @PeroK's comment. Seeing only your result, but not the integral you used, it's hard to say why your result is wrong.
Here is a start for you
## x^2 + (y-r)^2 = r^2 ##
##u = y-r##
## \displaystyle \dfrac{A}{4} = \int_0^r \sqrt{r^2 - x^2}\mathrm{d} x
= r \int_0^r \sqrt{1 - x^2/r^2}\mathrm{d} x##
##x= r \sin t##, ##x = 0 ##gives ##t = 0##, ##x = r## gives ##t = \pi / 2 ##
##\mathrm{d}x = r \cos t \mathrm{d}t ##
## \displaystyle \dfrac{A}{4} = r\int_0^{\pi/2} \sqrt{1 - \sin^2t} \cos t \mathrm{d} t
1. What is the formula for finding the area of a circle?
The formula for finding the area of a circle is A = πr², where A is the area and r is the radius of the circle.
2. How do you solve for the area of a circle?
To solve for the area of a circle, plug the given radius value into the formula A = πr² and calculate the result using the value of π (pi) as 3.14 or a more accurate value if needed.
3. Can you find the area of a circle without knowing the radius?
No, the radius is a necessary component in the formula for finding the area of a circle. If the radius is not given, it cannot be solved for.
4. How do you convert the diameter to the radius in the area of a circle formula?
To convert the diameter to the radius, divide the diameter by 2. The resulting value will be the radius, which can then be used in the formula A = πr² to find the area of the circle.
5. Is there a shortcut or easier way to find the area of a circle?
Yes, there is a shortcut formula for finding the area of a circle when the diameter is known. The formula is A = (π/4) x D², where A is the area and D is the diameter of the circle.
  • General Math
  • Calculus
  • General Math
  • Calculus
