Why is the area of an ellipse negative?
The result is$$\int_{0}^{2\pi} y(t) x'(t) - x(t) y'(t) dt$$The negative sign is because the direction of the parametrization is opposite to what is required for the theorem.
bigplanet401
104
Use the parametric equations of an ellipse, x = f(t)= a cos t and y = g(t) = b sin t, 0 <= t <= 2 pi, to find the area that it encloses.
Integral for parametric equations.
[tex]
A = \int_0^{2 \pi} g(t) f^\prime(t) \; dt
= \int_0^{2 \pi} -ab sin^2 t \; dt
= \frac{-ab}{2} \int_0^{2 \pi} (1 - cos 2t) \; dt
= \frac{-ab}{2} (t - \frac{1}{2} sin 2t ) \vert_0^{2 \pi}
= -\pi a b
[/tex]
But why the negative sign??
[tex]
= -\pi a b
[/tex]
I think the reason is because you are essentially integrating in the reverse direction. To make things simple, let's look at just the area in the first quadrant, using thin vertical slices. That area (a quarter of the ellipse) is given by this integral : ##\int_0^a y dx##. Here x will range from 0 to a.
When you replaced y and dx (and change limits of integration) you got ##\int_0^{\pi/2} -ab sin^2 t \; dt## (adjusting what you wrote to get only a quarter of the area).
As t ranges between 0 and ##\pi/2##, the point on the ellipse moves from (a, 0) to (0, b), so x is moving from right to left along the x-axis (i.e., from x = a to x = 0), which will give you the opposite in sign as compared to when x moves from left to right.
The parametric equations can be used in combination with the reverse implication of Green's theorem:
$$\frac{1}{2} \oint_C x dy - y dx$$
Find ##dx## and ##dy##, then apply the parametrization.
1. What is the formula for finding the area of an ellipse?
The formula for finding the area of an ellipse is πab, where a and b are the lengths of the semi-major and semi-minor axes, respectively.
2. How do I find the lengths of the semi-major and semi-minor axes?
The semi-major axis is the longest distance from the center of the ellipse to its edge, and the semi-minor axis is the shortest distance from the center to the edge. To find these lengths, you can measure them directly if you have a physical ellipse, or use the equation c2 = a2 - b2, where c is the distance from the center to any point on the ellipse and a and b are the lengths of the semi-major and semi-minor axes, respectively.
3. Can I use this formula for any ellipse?
Yes, the formula πab can be used for any ellipse, regardless of its size or shape.
4. How accurate is this formula for calculating the area of an ellipse?
This formula is an approximation and will give you a fairly accurate result. However, for more precise calculations, you can use numerical integration or other advanced mathematical techniques.
5. Can I use this formula to find the area of an ellipse in three-dimensional space?
No, this formula only applies to ellipses in two-dimensional space. In three-dimensional space, you would need to use a different formula to calculate the surface area of an ellipsoid.
