• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Area of irregular square
  • Thread starter stglyde
Hi,
How do you solve for the area of irregular square. What's the formula? For example. A square has the following 4 sides:
side a: 11.83 meters
side b: 38.74 meters
side c: 12.00 meters
side d: 36.02 meters
What is the total area? Thanks.
Simon Bridge
17,823
1,637
Well, it is not a square, and you need to know the angles.
I guess it's trying to be a rectangle if a is opposite c, and the angles are as close as possible to right-angles.
Then the shape will cover the maximum possible area for the sides - this what you mean?
Or do you mean any old tetragon?
http://www.mathopenref.com/tetragon.html
The area of an irregular quadrilateral is
[tex]A= \sqrt{(s-a)(s-b)(s-c)(s-d)-abcd\cdot\cos^2{\frac{\alpha +\gamma}{2}}}[/tex]
where a,b,c,d are the sides. s is the semi-perimeter and [itex]\alpha[/itex] and [itex]\gamma[/itex] are any two opposite angles.
Simon Bridge
17,823
1,637
@Blandongstein: awesome first post, welcome to PF.
Unfortunately we are not supplied with any angles ... so more information is needed from stglyde.
I was intrigued by the description as a "irregular square" ... another common formulation is to inscribe the tetragon/quadrilateral inside a circle for example. If we know the constraints on how squashed the shape can be, we can answer the question.
274
I just want to get the approximate area and I think it is easy by simply multiplying 12 x 37 or 444 so I'm satisfied. Thanks for the help.
Simon Bridge
17,823
1,637
There you go you see - not enough information was supplied.
The area must be pretty close to rectangular for that approximation to work.
But if, say, the angle between side a and side b is small, then a better approximation would be for a triangle. See why you got such complicated answers?
Oh well. Good luck.
Related Threads for: Area of irregular square
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
