Homework Help: Area of Parallelogram
  1. Jun 13, 2017 #1
    Find the area of Parallelogram ABCD where AD=4 and CD=6 and angle ABC=125 degrees, tell whether the area is greater than 24 or not?
    2. Relevant equations
    Area of Parallelogram = length * breadth
    3. The attempt at a solution
    Sol: 4 * 6 = 24
    but answer is wrong.
    Some body please guide me.
    Zulfi.
  3. Jun 13, 2017 #2
    jedishrfu
    Staff: Mentor
  4. Jun 13, 2017 #3
    Hi,
    Thanks for your response. This means that i have to first convert the parallelogram into a rectangle and then apply the formula of area of rectangle. Thanks.
    Zulfi.
  5. Jun 13, 2017 #4
    SammyS
    Staff Emeritus
    You gave the following formula.:
    Area of Parallelogram = length × breadth​
    What is the definition of the breadth of a parallelogram ?
  6. Jun 13, 2017 #5
    Mark44
    Staff: Mentor
    No.
    You have to find the distance between sides BC and AD. Drop a vertical line from point C and form a right triangle with CD as its hypotenuse. A little bit of right triangle trig will give you the altitude of this triangle, which you can use to find the area of the parallelogram.
  7. Jun 13, 2017 #6
    Without calculating you can tell whether area is more than or less than 24.
  8. Jun 16, 2017 #7
    Hi,
    Thanks for your help. I found the solution for this prob. I can draw a perpendicular from point C in downward direction & join D to this line. Let the joining point be E. Now area of parallelogram = AD * CE. But CE is less than 6. So area is less than 24.
    Zulfi.
  9. Jun 16, 2017 #8
  10. Jun 16, 2017 #9
    Ray Vickson
    What part do you not understand? The web page shows you exactly what ##b## and ##h## are, and it gives the area formula as ##A = b h##. What could be simpler?
  11. Jun 17, 2017 #10
    Hi,
    I am talking about this sort of alteration as shown in the attached figure and pointed to me by Mark44:
    This is mentioned in the solution of the question also. Examples on the web page do not do this. For instance in Example 1, area should be less than 63 units squares if we modify the figure using technique mentioned in the solution and by Mark44. Kindly see the image in reply#11.
    Zulfi.
  12. Jun 20, 2017 #11
    Hi,
    I am able to understand this. Area = b * h (i.e. height). To find the height i have to construct a triangle from the parallelogram. The height of the triangle would be the value of h to be used in the formula. In the link (i.e. math tutorial web site) they are provided the height h so they are using it directly in the formula.
    Thanks.
    Zulfi.
Have something to add?
Draft saved Draft deleted
