Area of the Region Inside the Curve.
In summary, the person is asking for help understanding parametric functions and is stuck because he does not understand how to solve for x in a situation where there is a "y^2-2y) situation. He suggests solving for x instead and writes down the equation for the circle. Then he solves for y and finds that it is -2, 1, and 3. He thanks the person for their help and states that he still needs more.
khatche4
Would it be possible if I could get help getting started? I don't have any work yet, but I am really trying to figure it out..
Problem:
Determine the area of the region inside the curve x^2+y^2-2y=0 and outside y(x^2+4)=5.
It has a graph and I'll upload a picture if needed. Basically? It's the area under the top of the circle but above the curve.
We have been discussing parametric, but I can't wrap my head around it because he didn't explain it all too well. Obviously it is symmetric about the y-axis. Other than that, I just need help getting started...
Since the circle is the upper bound the the other curve is the lower bound, you will be finding the difference of the integral of the circle and that of the curve bounded by their intersections on the left and right, namely [tex]\int^{b}_{a}[(x^{2}+y^{2}-2y)-(y(x^{2}+4))]dx[/tex], where a is their intersection on the left and b is their intersection on the right. I haven't down any calculation for them yet so you will need to find out the a and b. :)
So, I will set, for example, [tex]\sqrt{2y-y^2}[/tex]=[tex]\sqrt{\frac{5}{y}-4}[/tex]?
Then solve it from there, to find a and b?
I suggest you solving for x instead, since the x values are what you need for a and b. Try to rewrite the equations in terms of x, and then set then equal and solve for x. You should be getting two distinct values, which the lower one will be a and the other one be b.
How would you solve for x when in the equation for the circle we're given "y^2-2y"? I know I should know this, but I don't... :(
Point a and b are the points of intersections of the two equations you are given.
I know that, I just don't know how to solve for x in the situation where there is a "y^2-2y) situation...
Then you may wish to solve for y first, and then plug the values of y into either equations to get two separate x values. :)
**I totally meant in terms of x... Wow. That was silly.
([tex]\frac{5}{x^2+4}[/tex])2-2([tex]\frac{5}{x^2+4}[/tex]=-x2
which then gives me
I have ([tex]\frac{5}{x^2+4}[/tex])2-([tex]\frac{10}{x^2+4}[/tex])=-x2
But when I graphed it, I don't really think that's right...
which then gives me
For this question, solving for x directly is quite complicated; on the other hand, solve for y is relatively easier. Try solving for y then plug the values of y into either equation to get x, that will make things a whole lot easier.. :D
I already tried that, and then it wasn't easily factored... So that's when I got stuck.
First you write it as 0=y^3-2y^2-4y+5, then you do a bit of trial and error and find that (x-1) is a factor by doing long division, which leaves you (y-1)(y^2-y-5), then I'm sure you know what to do to find the root in (y^2-y-5). ;)
Oh my gosh... I'm dumb as a box of rocks. That totally makes sense.
So, I get y=-2, 1, and 3... But I'll be using -2 and 3, correct? And it is y, right? Hah.
I really appreciate your help.. I'm still going to need some more, I'm sure... But I seriously do appreciate it.
Ok, so, now I'm trying to figure out the integral.
Going from:
with a=-2 and b=3
[tex]\int[/tex]((x^2+y^2-2y)-(y(x^2+4))dx
obviously I have to solve for y still, correct?
That's why I'm confused, because when solving for y... The circle has a y^2-2y and how would I solve for y in that case?
The circle's equations in terms of x are y=1+sqrt(1-x^2) and y=1-sqrt(1-x^2). Good luck! :)
Thank you VERY much! I think that will definitely help... I'll post my answer (if I get it done) on here. Thanks!
One more question, I think...
Because a half circle is involved, will I use [tex]\frac{\pi r^2}{2}[/tex] for the equation of the circle?
If that half involved is centered in the origin vertically, then yes for this question once the r is known (in which case it is). :)
When I use:
[tex]\int[/tex][(1+[tex]\sqrt{1-x^2}[/tex])-([tex]\frac{5}{x^2+4}[/tex]]^2 dx
a=-2 and b=3
(my professor is letting us use our calculator)
When I put it in, it tells me that it's an unreal answer? (And I know we aren't supposed to get them).
It seems like the a=-2 is giving a negative value under the first square root expression..Hmmm. 8|
I have to finish my homework at the moment, and I'll come back with my calculation tomorrow morning, hopefully. (hope your homework isn't due tomorrow as well..D:)
Yeah. It's due in the morning... Thanks for your help, though. It wasn't the -2, though, because I changed it to check...
1. What does "area of the region inside the curve" mean?
The area of the region inside the curve refers to the amount of space enclosed by a curve or a set of curves on a graph. This is commonly calculated using mathematical methods such as integration.
2. How is the area of the region inside the curve calculated?
The area of the region inside the curve is typically calculated using integration, a mathematical method that involves finding the sum of infinitely small rectangles under the curve. The more precise the integration, the more accurate the area calculation will be.
3. Why is it important to calculate the area of the region inside the curve?
Calculating the area of the region inside the curve is important in many scientific fields, including physics, engineering, and economics. It allows us to understand the relationship between variables represented by the curve and can help in making predictions and analyzing data.
4. Can the area of the region inside the curve be negative?
No, the area of the region inside the curve cannot be negative. This is because the area is a measure of the space enclosed by the curve, and space cannot have a negative value.
5. What factors can affect the accuracy of the area calculation?
The accuracy of the area calculation can be affected by various factors, including the precision of the integration, the number of data points used, and the complexity of the curve. Using more precise methods and increasing the number of data points can improve the accuracy of the calculation.
