Possible webpage title: Finding the Area Between Curves Using Integrals
In summary, to find the area between the curves y = f(x) and y = 2f(x) from x = a to x = b, we can use the formula \int_a^b{dx(f(x))} where f(x) is the dominant function. This simplifies to just the integral of f(x) from x = a to x = b.
LadiesMan
96
Suppose the area of the region between the graph of a positive continuous function f and the x-axis from x = a to x = b is 4 square units. Find the area between the area between the curves y = f(x) and y = 2f(x) from x = a to x = b.
Attempt:
Since 2 f(x) is greater than f(x) we can call it g(x) and that will be the dominant function.
[tex]\int (g(x) - f(x)) dx[/tex]
It becomes...
[tex]G(x) - F(x)[/tex]
What do I do next?
Thanks
You said g(x)=2f(x), so what can you say about the relation between G(x) and F(x) ..?
Note that you want to consider definite integrals
[tex]
\int_a^b{dx(g(x)-f(x))}
[/tex]
Can you simplify g(x)-f(x)..?
umm yeah i guess that took me off course.
so then how would i do it?
Uhm,
g(x)-f(x) = 2f(x)-f(x) =...?
Umm that equals f(x)
very good, so
[tex]\int_a^b{dx(g(x)-f(x))}=\int_a^b{dx(2f(x)-f(x))}=\int_a^b{dx(f(x))}=...=?[/tex]
What is the definition of "Area Under Curves"?
The area under a curve is the total area bounded by the curve on a graph and the x-axis. It represents the integral of the function that defines the curve over a specific interval. In other words, it is the sum of all infinitely small rectangles that make up the curve.
How is the area under a curve calculated?
The area under a curve is calculated using integration, which is a mathematical process of finding the antiderivative of a function. This antiderivative is then evaluated at the upper and lower limits of the given interval to determine the total area under the curve.
What is the significance of the area under a curve?
The area under a curve has many applications in mathematics, science, and engineering. It is used to find the displacement, velocity, and acceleration of an object in physics, the probability of an event in statistics, and the total value of a function in economics. It also helps in visualizing and understanding the behavior of a function.
What is the relationship between the area under a curve and the definite integral?
The area under a curve is equal to the value of the definite integral of the function that defines the curve. The definite integral is a numerical value that represents the signed area under the curve and can be calculated using integration.
How can the area under a curve be approximated?
The area under a curve can be approximated using different methods such as Riemann sums, trapezoidal rule, and Simpson's rule. These methods divide the area into smaller shapes (rectangles, trapezoids, or parabolas) and calculate their individual areas, which are then summed to approximate the total area under the curve.
