Homework Help: Areas between Curves problem
  1. Feb 27, 2014 #1
    Let a > 0 be a fixed real number. Define A to be the area bounded between y=x2,y=2x2, and y=a2. Define B to be the area between y = x2, y = f(x), and x = a where f(x) is an unknown function.
    a) Show that if f(0) = 0, f(x) ≤ x2, and A = B then
    int 0-->a2 [y1/2-(y/2)1/2] dy = int 0--> a [x2 - f(x)] dx
    b) Find f(x) under the conditions above are true for all a > 0
    2. Relevant equations
    I guess the equations for the lines, y=x2, y=2x2, y=a2
    and y=x2, y=f(x), and x=a
    3. The attempt at a solution
    The first thing I did was try to find the area A.
    A= int 0-->a2 [y1/2-(y/2)1/2] dy
    A= (2/3)y3/2 - (1/sqrt2)(2/3)y3/2| eval. 0 and a2
    A= (2/3)a3 - (1/sqrt2)(2/3)a3
    A= a3((2/3) - (1/sqrt2)(2/3))
    a= (2/3)a3(1- (1/sqrt2))
    Then I tried to find the area B, but this is where I got confused.
    B= int 0--> a [x2 - f(x)] dx
    B= [(1/3)x3|eval. 0-->a] - [int 0-->a [f(x)]]
    I don't see how I can go any farther, because I don't think I can integrate an unknown f(x). Am I going about this the wrong way?
  3. Feb 27, 2014 #2
    Simon Bridge
    The relation does not require you to interpret the unknown f(x).
    Take another look at what you have to show.
    If A=B then the relation drops out. The trick is to verify the other two conditions.
  4. Feb 27, 2014 #3
    Are the other conditions f(0)=0 and f(x)≤x2? I don't understand how to verify those, would it have to do with the graph of the region? Since A=B and for A, both of the curves have a point at (0,0) so B must have two points there also?
    And how should I go about part b, do I just solve for f(x)?
  5. Feb 27, 2014 #4
    Simon Bridge
    Yes.
    Yes.
    No.
    A=B just means the areas are the same - the graphs do not have to have points in common for that to happen.
    i.e. what would happen to the RHS if f(x) > x^2
    You should make sure you understand part (a) first, but basically you can separate out the integral in f(x) and use your understanding of the properties of integrals.
Have something to add?
Draft saved Draft deleted
Loading...
