Which mean is larger when using algebraic expressions, A. M. or R. M. S.?
In summary, the root mean square (R.M.S.) is defined as sqrt{(a^2 + b^2)/2} and the arithmetic mean (A.M.) is given by (a + b)/2. When given specific values of a = 1 and b = 2, it is determined that R.M.S. > A.M. This process can also be applied to algebraic expressions, such as a = x and b = 1/x. It can be proven that in general, R.M.S. ≥ A.M. and equality occurs when a = b. To prove this, we can start by squaring both sides of the equation and using factoring and the property of taking square roots.
mathdad
1,283
Given two positive numbers a and b, we define the root mean square as follows:
R. M. S. = sqrt{(a^2 + b^2)/2}
The arithmetic mean is given by (a + b)/2.
Given a = 1 and b = 2, which is larger, A. M. or R. M. S. ?
A. M. = sqrt{1•2}
A. M. = sqrt{2}
R. M. S. = sqrt{(1^2 + 2^2)/2}
R. M. S. = sqrt{5/2}
Conclusion:
R. M. S. > A. M.
Question:
Can the same process be done if a and b represent two algebraic expressions?
Say a = x and b = 1/x, which is larger, A. M. or R. M. S. ?
Mathematics news on Phys.org
Can you prove that in general RMS ≥ AM? When does equality occur?
R. M. S. = sqrt{(a^2 + b^2)/2} > or = (a + b)/2.
Should I begin by squaring both sides?
Yes, that's how I'd begin to get rid of the radical...:D
I will play with this question on my next day off. Thank you very much.
[sqrt{(a^2 + b^2)/2}]^2 ≥ [(a + b)/2]^2.
(a^2 + b^2)/2 ≥ (a + b)^2/4
4 • (a^2 + b^2)/2 ≥ (a + b)^2/4 • 4
2(a^2 + b^2) ≥ (a + b)^2
2a^2 + 2b^2 ≥ (a^2 + 2ab + b^2)
2a^2 - a^2 + 2b^2 - b^2 - 2ab ≥ 0
a^2 + b^2 - 2ab ≥ 0
Where do I go from here?
a^2 + b^2 - 2ab ≥ 0
Try factoring the LHS...:D
The LHS becomes (a - b)^2 ≥ 0.
Do I proceed by taking the square root on both sides?
You could, but it's not necessary. If you do, recall:
\(\displaystyle \sqrt{x^2}=|x|\)
Am I done with the prove?
You have:
\(\displaystyle (a-b)^2\ge0\)
Given that a - b is a real number, this must be true, and so we are done with the proof. :D
Great. I will return to the quadratic inequality questions tomorrow as we travel through the David Cohen book. It is truly one of the most challenging precalculus books out there. I will text 5 questions through PM in 15 minutes.
I would rather you post the questions in the forums rather than sending them by PM, as per our rules. :D
The questions are not math questions. Check your PM.
1. What is arithmetic mean?
The arithmetic mean is the average of a set of numbers. It is calculated by adding all the numbers in the set and then dividing the sum by the total number of numbers in the set.
2. How is arithmetic mean useful in statistics?
Arithmetic mean is a commonly used measure of central tendency in statistics. It is helpful in summarizing a large set of data into a single value, making it easier to analyze and compare data sets.
3. What is the formula for calculating arithmetic mean?
The formula for arithmetic mean is:
Mean = (Sum of all numbers in the set) / (Total number of numbers in the set)
4. What is root mean square?
Root mean square (RMS) is a mathematical measure of the magnitude of a set of numbers. It is calculated by taking the square root of the arithmetic mean of the squared values in the set.
5. How is root mean square different from arithmetic mean?
Root mean square takes into account the magnitude of each number in the set, whereas arithmetic mean does not. This makes it helpful in representing the overall trend or variability in a set of data.
  • General Math
  • General Math
