Fortran Arithmetic Issue in FORTRAN
  1. Oct 28, 2015 #1
    Good day,
    I'm working with a FORTRAN program that has the line:
    EDEN=EDEN+(STVS**2)/(N(J)-1)
    I would like to check if N(J)-1 is equal to zero. If so make N(J)-1=1.0
    The following doesn't work:
    IF ((N(J)-1).EQ.0.0) THEN
    N(J)-1=1.0
    END IF
    I'm using gfortran and am getting unclassified statement at 1. The 1 is pointing to the beginning of the line N(J)-1=1.0
  3. Oct 28, 2015 #2
    SteamKing
    Staff Emeritus
    It would probably be better coding to do
    IF ((N(J)-1).EQ.0) THEN
    N(J)-1=1
    END IF
    Make sure N is declared as an INTEGER array, otherwise the compiler won't know how to handle N(J).
  4. Oct 28, 2015 #3
    Hesch
    N(J) = 2
    END IF
    I'm not familiar with FORTRAN, but I don't think you may do calculations to the left of the equality ( = ) in: N(J)-1 = 1
    That' s why you get an error.
  5. Oct 28, 2015 #4
    SteamKing
    Staff Emeritus
    Good catch. I missed that. :frown:
  6. Oct 28, 2015 #5
    Thanks for this.
    N(J) = 2
    END IF
    Worked perfect.
  7. Oct 28, 2015 #6
    Hi SteamKing....I tried your solution but got the same error. However, Hesch's code worked. Thanks so much for helping.
  8. Oct 28, 2015 #7
    Mark44
    Staff: Mentor
    As Hesch said, you can't assign a value to an expression such as N(J) - 1.
  9. Oct 28, 2015 #8
    Yes, it is good to be careful with denominators. But, N(J) may be needed on its own later on and should probably be left unmodified, maybe something like this?
    Code (Fortran):
    den = N(J) - 1
    if (den .eq. 0) den = 1
    EDEN = EDEN + STVS**2/den
