Arithmetic of Series: Why $\sum_{k=1}^{n} k- \sum_{k=1}^{n} (k-1) \neq 1$
In summary, the conversation discusses the concept of summation and the difference between two series. The conversation explains that the sum of consecutive integers starting with 1 can be calculated using the formula \frac{1}{2}n(n+1) where n is the last member of the sequence. The conversation also mentions that the difference between the two series will always be 'n'. Finally, it is clarified that subtraction between series is allowed, but it is important to remember the correct formula for the sum of consecutive integers.
steven187
176
hello all
a simple question how come
[tex]\sum_{k=1}^{n} k- \sum_{k=1}^{n} (k-1) \not= 1[/tex]
even though i know if you expand it out you would get n, isn't there an arithmetic property of series that relates to this?
thanxs
The sum of the consecutive sequence of integers starting with 1 is
[tex] \frac{1}{2}n(n+1) [/tex] where n is the last (and largest) member of the sequence.
so from here we can see that the set of any consecutive set of integers has the sum given by
[tex] \frac{1}{2}n_1(n_1+1) - \frac{1}{2}n_2(n_2+1) [/tex], combining:
[tex] \frac{1}{2}(n_1^2 + n_1 - n_2^2 - n_2) [/tex]
The difference of your two series lies in the fact that the first element of the second series is just 0 whereas the first series has 1. The difference between the two sums will always be 'n', which can be shown by realizing that in the above expression the relationship between n1 and n2 is just [itex] n_2 = n_1 - 1 [/tex].
hello there
see i know how to do it through this method
[tex]\sum_{k=1}^{n} k- \sum_{k=1}^{n} (k-1) = \frac{n(n+1)}{2}-\frac{n(n-1)}{2}=n[/tex]
but what i want to know is why can't we do this step?
[tex]\sum_{k=1}^{n} k- \sum_{k=1}^{n} (k-1)= \sum_{k=1}^{n} k-k+1= \sum_{k=1}^{n} 1=1[/tex]
is it that we are not allowed to do subtraction between 2 series, if not are there any cases when we can?
thanxs
Of course you can do subtraction between series. But [itex]\sum_{k=1}^n1=n[/itex] and not 1.
hello there
thanxs for that, i should have remembered something simple like that
1. What is arithmetic of series?
The arithmetic of series is a branch of mathematics that deals with the study of mathematical series, which are sequences of numbers that follow a specific pattern or rule. It involves the analysis and manipulation of these series to determine their properties and behavior.
2. Why is the sum of consecutive numbers different from 1?
The sum of consecutive numbers, also known as an arithmetic series, is different from 1 because it follows a specific formula: n(n+1)/2, where n is the number of terms in the series. This formula can be derived from the rule that the difference between consecutive terms in an arithmetic series is constant. Therefore, the sum will always be greater than 1, except for the first term when n=1, where the sum will be equal to 1.
3. How is the sum of consecutive numbers calculated?
The sum of consecutive numbers, or an arithmetic series, can be calculated using the formula: n(n+1)/2, where n is the number of terms in the series. For example, the sum of the first 5 consecutive numbers would be: 5(5+1)/2 = 15.
4. What is the difference between an arithmetic series and a geometric series?
An arithmetic series is a sequence of numbers where each term is obtained by adding a constant value to the previous term. A geometric series, on the other hand, is a sequence of numbers where each term is obtained by multiplying the previous term by a constant value. In an arithmetic series, the difference between consecutive terms is constant, while in a geometric series, the ratio between consecutive terms is constant.
5. How is the sum of an infinite arithmetic series calculated?
The sum of an infinite arithmetic series can be calculated using the formula: a/(1-r), where a is the first term in the series and r is the common difference between consecutive terms. However, this formula only works if the absolute value of r is less than 1. If the absolute value of r is greater than or equal to 1, the series will not converge and the sum cannot be calculated.
  • Linear and Abstract Algebra
