Homework Help: Arithmetic Sequence
  1. Jan 2, 2012 #1
    V0=4
    [tex]V_{n+1}=\sqrt{V_{n}^{2}+2n+3}[/tex]
    2. Relevant equations
    Show that Un is an arithmetic sequence.
    3. The attempt at a solution
    I counted Vn and i found that it equals:
    [tex]V_{n}=\sqrt{(Vn+2)^{2}+2}[/tex]
    what is there to do after this?
  3. Jan 2, 2012 #2
    SammyS
    Staff Emeritus
    What is Un? Is that a typo, or is Un = (Vn)2 ?
  4. Jan 2, 2012 #3
    No there is no Un at all.
  5. Jan 2, 2012 #4
    SammyS
    Staff Emeritus
    That looks like a Un to me.
    BTW: How do you count Vn ?
  6. Jan 4, 2012 #5
    Sorry it's show that Vn is arithmetic
  7. Jan 4, 2012 #6
    Curious3141
    Well, it clearly can't be, because [itex]V_0 = 4[/itex], [itex]V_1 = \sqrt{19}[/itex] and [itex]V_2 = \sqrt{24}[/itex] and [itex]V_2 - V_1 \neq V_1 - V_0[/itex] establishing that there is no common difference.
  8. Jan 4, 2012 #7
    sorry V0=1
    V0=1 V1=√6 V2=√11 V3=√16
    I found that Un=1+√(1+5n)
    And i know that arithmetic series are written as Un=Up+nr
    so: Up=1 and r=5 therefore you get: Un=1+√(1+5n)
    is that all I have to do?
  9. Jan 4, 2012 #8
    Curious3141
    What is [itex]U_n[/itex]? You've only defined what [itex]V_n[/itex] is so far. :grumpy:
  10. Jan 4, 2012 #9
    Curious3141
    By asking what [itex]U_n[/itex] is, I don't mean just quote a formula which you've derived. Please define exactly what [itex]U_n[/itex] is supposed to represent.
    It might be better if you reproduced the exact question in its original form, word for word.
  11. Jan 4, 2012 #10
    well the general form of an arithmetic series is :
    Un=Up+nr and in my case Un is Vn and Up is V0 and r is 5 so i get:
    [tex]V_{n}=1+\sqrt{1+5n}[/tex]
  12. Jan 4, 2012 #11
    Curious3141
    OK, it's all clearer now. Part of the confusion lay in the fact that you had miscalculated the terms for [itex]V_n[/itex] repeatedly.
    Forget about trying to fit things into a particular form for now. Let's start by looking at some values of [itex]V_n[/itex], correctly computed.
    Please recalculate [itex]V_1, V_2, V_3[/itex] and [itex]V_4[/itex] very carefully, and you'll see a much simpler pattern emerging. We'll take it from there.
  13. Jan 4, 2012 #12
    Curious3141
    After you do that, you will need to find a closed form expression for [itex]V_n[/itex] (the one you previously derived is clearly wrong), then formally prove it with mathematical induction. Once that's done, it'll become immediately apparent that [itex]V_n[/itex] is the general term of an arithmetic progression (in fact, one of the simplest and most well-known arithmetic progressions).
  14. Jan 4, 2012 #13
    alright i'll count them right now.
  15. Jan 4, 2012 #14
    i keep getting V0=1 V1=√6 V2=√11 V3=√16
    idk what is wrong?
  16. Jan 4, 2012 #15
    Curious3141
    V0 = 1 (given)
    V1 = sqrt(1 + 2*0 + 3) = sqrt (4) = ?
    Once you get V1 wrong, the rest will be wrong too, so restart from here.
    You were probably doing sqrt(1+2*1 + 3), but remember the index for the initial term is zero.
  17. Jan 4, 2012 #16
    Wow I didn't pay attention to that sorry:
    V0=1 V1=2 V2=3 V3=4 and so one
    so the general difference is 1
  18. Jan 4, 2012 #17
    Yes I didn't pay attention to that.
  19. Jan 4, 2012 #18
    Vn in terms of n is Vn=1+n
  20. Jan 4, 2012 #19
    To check I did Vn+1-Vn=2+n-1-2=1
    so the common difference is 1.
    do i also have to so Vn+2-Vn+1?
  21. Jan 4, 2012 #20
    Curious3141
    No need. You've now got an expression for [itex]V_n[/itex]. You need to prove it.
    Two ways.
    First is a direct proof, which might proceed like so:
    [tex]V_{n}^2 = V_{n-1}^2 + 2(n-1) + 3[/tex]
    [tex]V_{n-1}^2 = V_{n-2}^2 + 2(n-2) + 3[/tex]
    [tex]V_1^2 = V_0^2 + 2(0) + 3[/tex]
    then successively substituting the equation below into the one above until one gets:
    [tex]V_{n}^2 = V_0^2 + 2(\frac{1}{2})(n-1)(n) + 3n[/tex]
    which can be simplified to:
    [tex]V_{n}^2 = {(n+1)}^2[/tex]
    [tex]V_{n} = n+1[/tex]
    Fairly simple. But I would recommend the second method, mathematical induction. Try and do this as an exercise, and post your results here.
