Solve Armadillo Problem: Initial & Final Speed, Height
  • Thread starter Johny 5
In summary, an armadillo leaping upward rises 0.544 m in the first 0.2 seconds. Its initial speed is 3.7 m/s and its speed at the height of 0.544 m is 3.32 m/s. It goes a total height of 0.6985 m.
Johny 5
35
When startled, an armadillo will leap upward. Suppose it rises 0.544 m in the first .2 s. (a) What is its initial speed as it leaves the ground? (b) what is its speed at the height of .544 m? (c) How much higher does it go?
/\X = Vot+.5at^2
Vf^2=Vo^2+2a/\x
(a) /\x = .544 m at .2 seconds so
.544 = Vo (0.2) + .5 (-9.8)(.2)^2
.544 = Vo(0.2) - .196
(.544+.196)/(.2) = Vo
Vo = 3.7 m/s
(b) Vf^2 = 3.7^2 + 2(-9.8)(.544)
Vf^2 = 13.69 - 2.67
Vf = sqrt (11.02)
Vf = 3.32 m/s
(c) 0^2 = 3.7^2+s(-9.8)(/\x)
/\x = -3.7^2/-(2*9.8)
/\x = 0.6985 m
is this correct?
Yes, your solution is correct. Great job breaking down each step and using the correct equations! Keep up the good work.
Your solution appears to be correct. However, it would be helpful to include units in your calculations and final answers. Additionally, you may want to include a brief explanation of the equations you used and how they relate to the problem. Overall, good job on solving the armadillo problem!
What is the armadillo problem and why is it important to solve?
The armadillo problem is a physics problem that involves calculating the initial and final speed, as well as the height, of an armadillo after it rolls down a ramp. It is important to solve because it helps us understand the principles of motion and energy conservation, which are essential in many scientific fields.
How do you calculate the initial and final speed of the armadillo?
The initial speed can be calculated using the formula v = d/t, where v is the initial speed, d is the distance traveled, and t is the time taken. The final speed can be calculated using the formula v = u + at, where v is the final speed, u is the initial speed, a is the acceleration, and t is the time taken.
What factors affect the initial and final speed of the armadillo?
The initial speed of the armadillo is affected by the angle of the ramp, the mass of the armadillo, and the force of gravity. The final speed is affected by the same factors, as well as the presence of friction and air resistance.
How do you calculate the height of the ramp in the armadillo problem?
The height of the ramp can be calculated using the formula h = (v^2 - u^2)/2a, where h is the height, v is the final speed, u is the initial speed, and a is the acceleration due to gravity.
What are some real-life applications of solving the armadillo problem?
The principles used in solving the armadillo problem can be applied in various real-life situations, such as calculating the speed and trajectory of a moving object, designing roller coasters and other amusement park rides, and understanding the motion of vehicles and projectiles.
