Arrays c++
Hello all. I am designing a Gauss jordan elimination program using c++. I need a little help to code this as I am not too familiar with arrays and the operations you can perform on them.
The first question I have is how would I swap rows? I know its probably really simple but I cannot find and source code that might provide some insight. Could anyone please take a look at the following code and give me some insights. Thanks in advance
This is just what I have so far.
Code:
#include<iostream>
#include<cmath>
using namespace std;
int main()
    double x[50],a[50][50],c[50],d[50][50],max,loc;
    int i,j,n,ai;
    cout <<"\n\nPlease enter the number of rows/variables\n";
    cin >> n;
    cout<<"\nLet's now enter the row and column values\n"<<endl;
    cout<<endl;
for (i=1;i<=n;i++)
		for (j=1;j<=n;j++)
		cout <<"Row "<<i<<", Column "<<j<<"\n";
		cin >> a[i][j];
	cout << "Please enter the constant for row "<<i<<"\n";
	cin >> c[i];
    cout <<"\n\nThe matrix entered is as follows:\n";
	for (i=1;i<=n;i++)
        cout<<"\n";
		for (j=1;j<=n;j++)
		cout <<a[i][j]<<"\t";
	    cout<<" ="<<c[i]<<"\n";
//looks for the pivot
max <= a[0][0];
loc <= 0;
for (i=1;i<=n;i++)
  if (a[i][0] > max);
    max <= a[i][0];
    loc <= i;
system("pause");
return 0;
Answers and Replies
Given the way you have defined the matrix [a 2D array], the only way to swap rows will be to step over each column with a for loop and swap the items in those columns.
If you define your matrix the other way [as an array of arrays] you can swap rows by swapping the row pointers.
If you plan to be doing serious matrix math it may be best to not try to use raw C constructs as you are doing here-- especially if you are unfamiliar with C-- and instead find a matrix library. This article at IBM developerworks reviews several matrix libraries, and highlights at least one called "Cooperware Matrix" that I notice has a swap-rows method built in.
Well, if you're just doing it as a learning project and not for a super-intensive application, I think understanding how it can algorithmically be done is not such a bad idea.
Here's the pseudocode for what you want to do:
Code:
SwapRows( matrix[1...n,1...m], row1, row2 )
1.   for j := 1 ... m
2.      do tmp := matrix[row1, j]
3.      matrix[row1, j] := matrix[row2, j]
4.      matrix[row2, j] := tmp
Swapping columns is also straightforward.
This program will just be for educational use. What do you mean by an "array of arrays"?
Strictly speaking (or at least this is my understanding), a two-dimensional array in C *is* an array of arrays. But that's beside the point.
Another way to get fast swapping of rows is to use a trick similar to swapping pointers, but involving only a lookup table:
Code:
Initialize( n : number of rows )
1.   for i := 1 ... n
2.      do table[i] := i
Access( matrix[1...n, 1...m], row, col )
1.   row' := table[row]
2.   return matrix[row', col]
SwapRows( matrix[1...n, 1...m], row1, row2 )
1.   tmp := table[row1]
2.   table[row1] := table[row2]
3.   table[row2] := tmp
That's some pretty quick code. You'd do a little better with pointers, but then again, who wants to deal with those?
Code:
1.   for j := 1 ... m
Yes this is for a project. I am a little new to c++ so bear with me. What does tmp mean?
The problem I am having is that I need to find the pivot(the largest absolute value number in the first column). I then need to interchange row 1 with the row the pivot is in. I am still a little confused how I would need to code this. I understand what the pseudocode is doing. I just cannot figure out how to use what I have coded and make it swap the rows.
So first off, AUMathTutor is correct, I misspoke and this was not the right terminology.
But what I meant was that there are two ways to create a two-dimensional array in C. One is the way you did it:
Code:
double a[50][50];
The other is to create an array of pointers, and point the pointers to arrays:
Code:
double *a[50];
for(int c=0; c<50; c++) a[c] = new double[50];
Regardless of which of these two things you did, you access the values the same way:
Code:
cout << a[3][2];
However they are handled differently in memory. In case one, the compiler will just make a big 50x50 table in memory and do lookups into it. In case two, the compiler will have 50 arrays of doubles and one array of pointers to those arrays.
The difference is first off, case two will under some circumstances be easier to pass to functions; and second, in case two (and only case two) you are allowed to do this:
Code:
double *temp = a[3];
a[3] = a[2];
a[2] = temp;
However case one will be a good bit easier to handle if you are not yet familiar with C/C++ pointers.
He's suggesting you make a temporary value, which he abbreviates "tmp", and use it to hold the value at matrix[row1, j] in order to swap it with another value. Like I do with the arrays in my final code example above.
HallsofIvy
41,847
969
"tmp" stands for "temporary". This is a pretty standard method of swapping two of any kind of things. If, for example, you want to swap A and B, you define "tmp" or "temporary", "t", or, in fact, anything, of the same "type" as A and B, then write
tmp= A;
A= B;
B= tmp;
I presume you understand why just "A= B; B= A;" would not work.
Code:
double a[50][50];
Code:
double *a[50];
Code:
cout << a[3][2];
Code:
a[3] = a[2];
a[2] = temp;
Case 2 sounds like it could possibly be easier for me to understand except that pointers aren't one of my strong points. Ok I guess I need to at least make an attempt to code this row swap so I can at least see where I am going wrong if I am at all.
max <= a[0][0];
loc <= 0;
for (i=1;i<=n;i++)
if (a[0] > max);
max <= a[0];
loc <= i;
This is the part of the code that is throwing me off. I still cannot for the life of me seem to figure out how to use this and swap the rows. This piece of the code will find the maximum value, and give the location of that value..at least thats what I think its doing :-D...
Could someone please maybe give me a little shove in the right direction.
Again I have to look through the first column, pick out the largest value, swap the row that value is in with row 1.
ur5:
<= in C++ means "less than or equal to". The statement "loc <= 0" will have no effect, it will only perform a test whether or not loc is less than 0 and then discard the results of that test. You're supposed to say "=" if you want assignment.
If you want a function to give you the row number whose leading entry is greatest, perhaps something like the following?
Code:
Compare( matrix[1...n, 1...m], row1, row2 )
1.   result := 0
2.   while (j <= m) && (result = 0)
3.      do if matrix[row1, j] > matrix[row2, j]
4.         then result := 1
5.      if matrix[row1, j] < matrix[row2, j]
6.         then result := -1
7.      j := j + 1
8.   return result
Now that you can compare rows of a matrix, it should be relatively straightforward to find the biggest row.
Code:
1.   result := 0
4.         then result := 1
7.      j := j + 1
8.   return result
Thanks for this that makes it a whole lot clearer.
rcgldr
8,782
573
If memory was limited then there's the option, A ^= B, B ^= A, A ^= B.
In addition to using loops to move arrays, you can also use memcpy(dst, src, sizeof(array)). Swapping pointers as mentioned above to make the equivalent of a 2d array is the fastest. The previous example did a seperate allocate (new) for each row of the array, but this could have been done with a single allocation (new) of the full 2d array, followed by a loop to fill an array of pointers to each row of the array.
C and C++ don't allow assignment of arrays but do allow assignment of structures containing arrays. You could define a row structure, typedef {char data[50]}ROW, and then use an instance of ROW to move an array via assignment, ROW row0, row1; ... row0 = row1; ...
Just a reminder, btw, my row-table method is very nearly as fast as pointers, and requires zero knowledge of how pointers work.
Related Threads on Arrays c++
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
10K
