Dustinsfl
- 2,281
- 5
How can I add a couple arrows on this line?
Code:
\draw (3.14,-3.14) -- (3.14,3.14
dwsmith said:How can I add a couple arrows on this line?
Code:\draw (3.14,-3.14) -- (3.14,3.14
\draw [<->](3.14,-3.14) -- (3.14,3.14);
Sudharaka said:This will do I guess,
Code:\draw [<->](3.14,-3.14) -- (3.14,3.14);
dwsmith said:I am looking for something like this.Code:^ | ^ |
\draw [->>](3.14,-3.14) -- (3.14,3.14);
Sudharaka said:There is a drawing editor called Ipe extensible drawing editor which can be used to include figures in LaTeX documents. I am using this for a long time now and I find it quite handy. Since I saw a couple of threads made by you regarding drawing figures in LaTeX, thought you might be interested in this. :)
The codedwsmith said:[->>] produced the arrow heads right behind each other. Is there a way to put arrows at 1/3 intervals on the line?
\usetikzlibrary{decorations.markings}
\begin{tikzpicture}
\draw[decoration={
markings,% switch on markings
mark=at position .66 with {\arrow{>}},
mark=at position 1 with {\arrow{>}}},
postaction={decorate}] (0,0) -- (0,1);
\end{tikzpicture}
dwsmith said:So I downloaded 7.0.1 but it says I need the 7.0.0 directories. Where do I get those at? How do I set it up once I have everything?
Sudharaka said:Please unzip the zip file you have downloaded and read the read-me file in it. There you will find that you need a file called, ipe-7.0.0-dependencies-win.zip. That can be downloaded http://fr.sourceforge.jp/projects/sfnet_ipe7/downloads/ipe/ipe-7.0.0-dependencies-win.zip/. Proceed as the read-me file instructs.
dwsmith said:Where do I save the files? How do I tell Winedt to interact with it?
To add an arrow to a line in LaTeX, you can use the \overrightarrow or \overleftarrow commands. These commands require the use of the "amsmath" package, which can be included in your document's preamble.
Yes, you can customize the appearance of the arrow by using the \xrightarrow or \xleftarrow commands. These commands allow you to specify the length, width, and style of the arrow, as well as the text that should be placed above or below the arrow.
To add multiple arrows to a line in LaTeX, you can use the \overleftrightarrow or \overbrace commands. These commands allow you to place arrows on both sides of the line, or add a brace with an arrow above or below the line.
Yes, you can add a curved arrow to a line in LaTeX by using the \curvearrowright or \curvearrowleft commands. These commands allow you to specify the curvature of the arrow and the text that should be placed above or below it.
Yes, there are several other packages and commands that can be used to add arrows to a line in LaTeX, such as the "tikz-cd" package and the \xmapsto command. These options may offer more advanced customization options, but may also require more knowledge of LaTeX.
