• Support PF! Buy your school textbooks, materials and every day products Here!
Artificial Gravity
  • Thread starter Momentum09
"Artificial Gravity"
A space station in the form of a large wheel, 333m in diameter, rotates to provide an "artificial gravity" of 9m/s^2 for people located on the outer rim. Find the rotational frequency of the wheel that will produce this effect. Answer in units of rpm [revolutions per minute]
w = 2pi/T , Frequency = 1/T
I first equated the normal force with the centripetal force, which is mg = mv^2/r. Cancelling out the m, I got gr = v^2. After I solved for V, I plugged it into the w = 2pi/T equation to find T, then 1/T. To convert the answer to rpm, I multiplied what I got for F by 60 and divided by 2pi. However I kept getting the wrong answer. Can someone please help? Thank you!
Answers and Replies
hage567
1,509
How did you relate v to w when finding T in this step?
Be sure to keep track of the units to make sure things make sense.
What answer did you get?
I got 3.487429162 rpm
I also know that w = 2 x pi x frequency
hage567
1,509
Yes, but remember that v is linear velocity, and w is angular velocity. They are not interchangeable. Do you know the relation between those two quantities?
I know that w = v/r
hage567
1,509
So what do you get if you make use of that? You found what v is, and ultimately what you want to find is w (in rev/min).
You're initial approach is OK, it's just the long way around. But you still need to use v=rw.
oh! I got it now! Thank you so much!
hage567
1,509
You're welcome. :smile:
Related Threads for: Artificial Gravity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
