appykid
- 2
How do I find the quantity of active ingredient in a commercial ASA tablet, using titration and NaHO? I think that I'm supposed to use ethanol too.
Titration is a laboratory technique used to determine the concentration of a substance in a solution by reacting it with a known volume and concentration of another substance.
Titration is used for ASA (acetylsalicylic acid) tablets to determine the exact concentration of the active ingredient, as well as to check for impurities and ensure quality control in the manufacturing process.
NaOH (sodium hydroxide) is used as a standardized base solution to react with the ASA in the tablet, while ethanol is used as a solvent to dissolve the ASA and aid in the reaction.
The ASA tablet is first dissolved in ethanol and then a few drops of phenolphthalein indicator are added. The standardized NaOH solution is then slowly added to the solution until a color change occurs, indicating the endpoint of the reaction. The volume of NaOH used is then used to calculate the concentration of ASA in the tablet.
The accuracy of titrating ASA tablets can be affected by factors such as incorrect measurements, impurities in the ASA tablet, and human error in determining the color change endpoint. It is important to carefully follow the procedure and use precise measurements to ensure accurate results.
