Determining c in Quadratic Function Turning Point
In summary: My apologies. In summary, the graph's turning point of a quadratic function f(x)=ax^2+bx+c is over the X-axis. If the coordinate of the turning point is (p, q) and a > 0, the correct statement is ...
Monoxdifly
MHB
284
The graph's turning point of a quadratic function \(\displaystyle f(x)=ax^2+bx+c\) is over the X-axis. If the coordinate of the turning point is (p, q) and a > 0, the correct statement is ...
A. c is less than zero
B. c is more than zero
C. q is less than zero
D. q equals zero
Since the point (p, q) is over the X-axis that means q is more than zero, so the options C and D are out of question. What should I do to determine if c is positive or negative? I'm stuck on this. Thanks.
Mathematics news on Phys.org
hint ...
what does the sign of the discriminant say about a quadratic’s roots?
If it's positive, it has two real roots. Okay, so D > 0.
D > 0
\(\displaystyle b^2-4ac>0\)
\(\displaystyle b^2>4ac\)
\(\displaystyle 4ac<b^2\)
\(\displaystyle c<\frac{b^2}{4a}\)
A square number must be positive, so \(\displaystyle b^2\) is positive. Since a > 0 then 4a > 0, so \(\displaystyle \frac{b^2}{4a}\) is still positive.
There's still a possibility that c is either negative or positive. What should I do next?
you were given $a>0$ which means the graph of the resulting parabola opens upward.
you were also given that the vertex of the parabola, $(p,q)$ was over the x-axis, hence $q > 0$.
If $q > 0$, the parabola has no x-intercepts ... the given quadratic has no real roots $\implies b^2-4ac <0$
"Over the x-axis" seems to me a strange way of saying "above the x-axis".
I took it to be one of the three possibilities ... over, on, or under. 🤷🏼‍♂️
@skeeter:
Ah, I see. Thanks for your help.
@Country Boy:
Sorry, I didn't know the proper term so I came up with what I had in mind at best, without realizing that the simple "above" is already the proper term.
1. What is the formula for determining the turning point of a quadratic function?
The formula for determining the turning point of a quadratic function is (-b/2a, c-b^2/4a), where a, b, and c are coefficients in the general form of a quadratic function f(x) = ax^2 + bx + c.
2. How do you find the value of c in a quadratic function turning point?
The value of c in a quadratic function turning point can be found by substituting the x-coordinate of the turning point into the original quadratic function. This will give you the y-coordinate, which is the value of c.
3. Can you determine the turning point of a quadratic function without knowing the value of c?
Yes, it is possible to determine the turning point of a quadratic function without knowing the value of c. This can be done by using the formula -b/2a to find the x-coordinate of the turning point, and then substituting this value into the original function to find the y-coordinate.
4. What does the turning point of a quadratic function represent?
The turning point of a quadratic function represents the vertex of the parabola. It is the highest or lowest point on the curve, depending on whether the function opens upward or downward.
5. Can a quadratic function have more than one turning point?
No, a quadratic function can only have one turning point, which is the vertex of the parabola. This is because a quadratic function is a second-degree polynomial, meaning it can only have one maximum or minimum value.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
