Assumptions of the Bell theorem
  • #801
Demystifier
Insights Author
4,695
If there were only a single hydrogen atom there'd be nobody to bother about its state and the meaning of this state.
Of course the probabilities are there when nobody measures. If the measurement is done you don't need any probabilities anymore.
So probabilities of measurement outcomes are only relevant when there are no measurement outcomes? :oldlaugh:
  • Haha
Likes vanhees71
  • #802
210
129
Maybe, there is some misunderstanding.
To my mind, words like "local" or "non-local" are problematic in conjuction with quantum theory. They can over and over again trigger people to think about quantum phenomena with classical ideas (this I meant with "error in thinking").
I see. I never had to teach students, so the problem that my words would trigger ideas that make it harder for them to learn quantum theory never happened to me. For me personally, it was rather the absence of the concept of density matrix that initially prevented me from understanding quantum mechanics (in my QM course at university).
After I learned a similar concept in statistical optics later in my job, I guessed that it was this concept that had been missing for me before. Much later a new job forced me to really learn and understand QM. Today I have the impression that most of classical physics remains valid, and the tricky part is rather to convince others that taking quantum corrections (like exchange effects, quantum surface transmission, channeling contrast, quantum moment conservation) into account is both possible and required for reproducing certain effects seen in experimental data, despite the fact that Monte Carlo simulations seem to be based entirely on classical concepts. A correction for exchange effects or for channeling contrast can feel badly non-local. To convince others, it helps to dig a bit into where the non-locality came from. Typically two or more electrons became indistinguishable for some specific reason. I don't think that the word "non-local" itself ever played a role is such discussions, neither positive nor negative.
Likes vanhees71
  • #803
125
30
The same holds for "reality", which is even harder to define. For me reality is objective, reproducible observability, i.e., what can be tested by experiments.
...for others, have pre-defined values
  • #804
125
30
if the measurement on one 'end' of the system immediately determines the outcome at the other, spatially separated 'end' of the system, this too would imply FTL-nonlocality.
not necessarily.
  • #805
vanhees71
Insights Author
9,885
Sure, in "bread-and-butter physics" dealing with the description of observable phenomena, there's only one meaning of "locality", namely the impossibility to transmit information with any "faster-than-light signal" within any theory which is consistent with any theory within the (special-)relativistic (!!!) spacetime model. In relativistic QFT this is implemented from the very beginning by the microcausality principle for local observables, from which all the fundamental properties derivable from the so realized local relativsitic QFTs follow: unitarity and Poincare invariance of the S-matrix/optical theorem/dispersion relations, relation between spin and statistics (half-integer spin=fermions; integer spin=bosons), CPT symmetry.
What's often confusingly called "non-locality" in the more quantum-foundations inclined community refers to long-ranged correlations between "entangled parts" of a quantum system. It would help tremendously to call this "inseparability" as Einstein did. The trouble seems to be that Einstein's much clearer written paper of 1948 has been mostly ignored in comparison to the unfortunate EPR paper of 1935, and thus the confusing lingo of the EPR paper and the even more confusing answer by Bohr prevailed.
  • #806
Demystifier
Insights Author
4,695
May I ask what's your job? It sounds as if it is not an academic job, so I'm curious what kind of non-academic job requires good understanding of QM. :smile:
Likes vanhees71
  • #807
Lynch101
70
not necessarily.
If two 'ends' are spatially separated and an action performed one one end instantaneously affects the other end, then, by my reasoning, this would imply an FTL causal influence. Is there any alternative?
  • #808
vanhees71
Insights Author
9,885
There are no FTL causal influences within local relativistic QFT. The experimentally confirmed violations of Bell's inequality, consistent with the predictions of local relativistic QFT (usually QED since most experiments are done with entangled photons) are thus still consistent with locality.
  • #809
210
129
If you work in the semiconductor industry, then you have a good chance to encounter tasks where a good understanding of physics is helpful. This physics can also reach into the domain of QM, sometimes more, sometimes less. Let me elaborate on what I wrote in the New Members Introductions Forum:
I am an applied mathematician working in semiconductor manufacturing. This means stuff like optical lithography, ebeam lithography, resist development processes, etching processes, optical metrology, scanning electron beam metrology, and other related physical or chemical processes.
My QM tasks are about the interaction of electron beams with matter. At the beginning (February 2013) it was about the energy range 10 keV - 100 keV, i.e. the simulation of electron beam lithography. An understanding of QM was still unimportant here, it was enough to use databases with (differential) scattering cross-sections (for atoms) provided by others, and there were also existing simulators against which I could verify our simulator. (The simulator already existed, only it provided significantly different results than existing simulators. It was my job to find the causes and fix them.)
From the beginning it was clear that we also wanted to be able to simulate scanning electron microscopy (SEM). Internal prototypes, external simulators and code "licensed" from research institutes existed for this as well. But that was a tragedy because each simulator calculated totally different results and there was no chance of differentiating right from wrong. Well, for some simulators you could explain why they were definitely wrong. But it wasn't bad either, because after "directed self assembly" (DSA) went out of fashion again, the end customers' need for the simulation of the SEM also decreased. (And there were and are many other tasks for me.) With DSA, defects can arise under the surface, and the task of the SEM simulation would have been to determine from what depth on which defects (size, material) can still be seen, what the signal-to-noise ratio is, and which SEM settings (energy of the electrons, which type of detectors, ...) would be helpful.
Then a student did his master's thesis with us extending the simulator with charging effects and doing clean room SEM measurements to somewhat verify the stuff. He was really enthusiastic, and then also finished a PhD thesis on related topics later. ... And customers for the simulator also emerged: the manufacturers of the SEM machines.
Likes mattt, Demystifier and vanhees71
  • #810
Lynch101
70
Well yes. The problem is that the disagreement is about philosophy and not about physics. The indication for that is that obviously we still have not a clear agreement on the meaning of the words, particularly locality. For me locality is simply microcausality. For you obviously it has a different meaning. The same holds for "reality", which is even harder to define. For me reality is objective, reproducible observability, i.e., what can be tested by experiments.
With words like 'reality', there is a danger of descending into a philosophical rabbit hole in trying to define the terms with impossible precision. It is possible, however, to avoid such tangents by defining it in contrast to other well defined terms.
For example, with regard to 'the physical reality' referred to in the EPR paper (which Bell took as the basis for his own paper), 'the physical reality' can be defined in contrast to 'the mathematical model' of the physical experimental set-up. So, 'the physical reality' simply refers to the what is happening in the lab.
Is there not also the possibility to interpret it as the impossibility of causal influences propagating FTL? But, as long as FTL causal influences cannot be used for signaling they would not violate relativity. Some might say that it violates the 'spirit' of relativity, but that is a separate matter. (I'm not arguing that it does violate relativity, just that there is another possible interpretation of 'locality'.)
At this stage, you are probably right. The term 'inseparability' might be better because too much time seems to go into discussing the meaning of the word 'non-local'.
From my reading of the literature and from discussions on here about the literature, my reasoning leads me to conclude that there are those who us the term 'non-locality' not simply to refer to the observed correlations, rather about the possible mechanisms which could explain the observed correlations. They seem to be talking about causal influences propagating FTL or, more accurately, instantaneously.
There seems to be others then who use the term 'non-local' to simply refer to the observed correlations themselves.
But, if we do choose to use the term 'inseparability' - where we talk about a single system - we can ask if the system is spatially separated, given that it is measured in spatially separated laboratories. We can then ask if measurement on one 'end' has an instantaneous (or FTL) causal influence on the other, spatially separated 'end'.
By my reasoning, the underlying issue is whether or not there are FTL causal influences, regardless of whether we use the terms 'non-locality' or 'inseparability'.
  • #811
Lynch101
70
I wasn't suggesting that there were. I was simply stating, if we can say that a system is spatially extended and
we can say that measurement on the part of the system in one laboratory has an immediate causal influence on the part of the system in the spatially separated laboratory, then there are, necessarily, FTL causal influences.
This might not apply to realativistic QFT
  • #812
vanhees71
Insights Author
9,885
No, that's the common mistake to confuse causal influences with statistical correlations. The point is that any phenomenon which can be described with relativistic local QFT is consistent with locality, because QFT is a local description.
It's also a mistake to conclude from the 100% correlations between the outcomes of measurments or certain observables on parts of an entangled quantum system to conclude that the measured values must have been predetermined before measurement, because QT is a description where this is not the case and still in full agreement with the observed statistical facts.
It was Bell's great merit to have found a way to scientifically decide between this assumption ("local deterministic hidden-variable model") and "Q(F)T".
  • #813
Lynch101
70
@Demystifier is 3D space an assumption of the Bell Theorem?
  • #814
Demystifier
Insights Author
4,695
I would say no, but it may depend on what do you mean by "space" which can have a different number of dimensions. If you mean "space" in the sense in which space in string theory is 9-dimensional, then the number of dimensions doesn't matter.
Likes vanhees71
  • #815
Lynch101
70
Without ascribing any ontological properties to 'space' I simply mean that the experimental set-up is assumed to be modeled using 3 dimensions, as represented graphically using XYZ axes, and that it is/should be possible to represent everything from the experimental set-up with respect to these axes.
  • #816
Demystifier
Insights Author
4,695
Yes, that's an assumption of the Bell theorem. Why do you ask, do you see a way out of this assumption?
  • #817
Lynch101
70
I thought there might be, but based on the replies in another thread I am reconsidering.
  • #818
Lynch101
70
@Demystifier Do these statement all apply to Bohmian Mechanics?
  • #819
Demystifier
Insights Author
4,695
I cannot tell because the question is too vague. How exactly would you restate his claims by using the expression "Bohmian mechanics" (BM)?
Note also that "local" in the standard QFT context does not have the same meaning as "local" in the Bohmian context. In the former sense, BM is local as much as standard QFT. BM is nonlocal in the latter sense, but the latter sense is a non-sense from the standard QFT point of view.
Likes vanhees71
  • #820
Lynch101
70
I cannot tell because the question is too vague. How exactly would you restate his claims by using the expression "Bohmian mechanics"?
Do particles not have predetermined values in Bohmian Mechanics and does it not rely on FTL causal influences?
  • #821
Demystifier
Insights Author
4,695
Values immediately after measurement may differ from values immediately before measurement, in that sense they are not predetermined. But values after measurement are determined by values (of all variables of the universe) before measurement, in that sense they are predetermined and involve FTL causal influences.
Likes gentzen
  • #822
Lynch101
70
Thank you, I was just trying to make sense of Vanhees's comment above about it being a 'common mistake to confuse causal influences with statistical correlations' with regard to the use of the term 'non-local'.
  • #824
Lynch101
70
But some physicists are referring to FTL causal influences, when they use the term 'non-local', would you agree?
Are there interpretations which do conclude this? Demystifier has clarified that the values prior to measurement could be different but they would still be single, well-defined values. Are you saying that this is a 'common mistake'?
Violations of Bell's inequality don't decide in favour of QFT though, does it? The various interpretations which do rely on FTL causal influences and pre-determined particle positons are not ruled out by Bell's Theorem but would, according to your position, be incompatible with QFT given their employment of FTL causality.
Or would you say that because that FTL causality cannot be used for signaling that it doesn't contradict QFT?
  • #825
vanhees71
Insights Author
9,885
I use the words "local" and "non-local" only in one proper mathematical meaning, i.e., that local observables in relativistic QFTs commute with the Hamilton density when their space-time arguments are space-like separated, i.e., ##[\hat{O}(x),\hat{\mathcal{H}}(y)]=0## for ##(x-y) \cdot (x-y)<0## (west-coast convention, i.e., ##\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,-1)##. Thus there cannot be any causal connections between space-like separated events.
For me an observable in Q(F)T has a predetermined value if and only if the system is prepared in a state such that the probability for measuring one of the possible values with 100% probability. Otherwise the value is indetermined before measurement and the state preparation only implies a certain probability for finding each of its possible values and nothing else. In which state the system is after the measurement depends on the construction of the measurement device, i.e., the specific interaction between the measured system and the measurement device. Since these interactions are just usual interactions described by local relativistic QFT there's no faster-than-light causal effect by a local measurement at one place and another space-like separated local measurement at another place. If the two space-like separated local measurements refer to entangled parts of a quantum system, then the observed correlations are not mutually caused by the local measurements but are due to the preparation of the system in the entangled state before any of the two measurements where done. By construction there is no contradiction between relativistic spacetime causality constraints and local relativistic QFT.
To confuse long-ranged correlations and inseparability of entangled systems with causal interactions at a distance is only misleading and contradicts the very foundational construction of local relativistic QFT.
Related Threads on Assumptions of the Bell theorem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
