Homework Help: Astrophysic problem set
  1. Oct 29, 2008 #1
    Vertical equation for motion:
    [tex]\frac{d^2z}{dt^2} +v^2 = 0[/tex]
    which corresponds to a simple harmonic oscillator, with an angular frequency [tex]v = \sqrt{4 \pi G \rho}[/tex]. The solution of the diff eq can be written as [tex]z(t) = Asin(vt+\phi_0)[/tex]
    where z(t) is the vertical position of a test particle, A is the amplitude of its motion, and [tex]\phi_0[/tex] is its initial phase.
    Given z(t), write out the expression for the vertical velocity.
    2. Relevant equations
    3. The attempt at a solution
    Since z(t) is the vertical position, the derivative of z(t) with respect to t would be the velocity? Correct?
    And the vertical velocity expression would be [tex]\frac{dz}{dt} = Acos(vt+\phi_0) * v[/tex]? Is this correct?
  3. Oct 29, 2008 #2
    Redbelly98
    Staff Emeritus
    Yes, that's correct.
    Just as an aside, most people and most textbooks use ω for angular velocity, so instead of "vt" those terms would be ωt.
    Also, I think the original equation is
    [tex]
    \frac{d^2z}{dt^2} +v^2z = 0
    [/tex]
  4. Oct 29, 2008 #3
    Yes your correct about the original equation...also not sure why they used v for the angular velocity.
