Analyzing Local Behavior at x→0+ of y'+xy=1/x^3
In summary, the conversation discussed finding the first three terms in the local behavior as x approaches 0+ of the solutions of the differential equation y'+xy=1/x^3. The method of dominance was initially attempted, but it was realized that the series expansion method could be used instead. The conversation ended with a request for advice on how to proceed with the series expansion.
meenums34
Asked to find first three terms in the local behavior as x→0+of the solutions of
y′+xy=1/x^3
This was taken by bender and orszag book
Working :
I tried to use method of dominance but later realized that we can find using the series expansion. But I am not sure how to proceed. Please advise how to proceed with it.
Write y as [tex]\sum a_nx^n[/tex] where n runs over all integers, both negative and positive. Then [tex]y'= \sum na_nx^{n-1}[/tex] and [tex]xy= \sum a_nx^{n+1}[/tex].
The equation becomes [tex]\sum na_nx^{n-1}+ \sum a_nx^{n+1}= x^{-3}[/tex].
In the first sum let j= n-1 so that we have [tex]\sum (j+1)a_{j+1}x^j[/tex].
In the second sum let j= n+ 1 so that we have [tex]\sum a_{j-1}x^j[/tex].
Now the equation is [tex]\sum (j+1)a_{j+1}x^j+ \sum a_{j-1}x^j= \sum ((j+1)a_{j+1}+ a_{j- 1})x^j= x^{-3}[/tex].
Since power series expansion is unique, we have the (infinite) set of equations
[tex](j+1)a_{j+1}+ a_{j-1}= 0[/tex] for all j except j= -3 and
[tex](-3+ 1)a_{-3+ 1}+ a_{-3-1}= -2a_{-2}+ a_{-4}= 1[/tex].
1. What is the purpose of analyzing the local behavior at x→0+ of y'+xy=1/x^3?
The purpose of analyzing the local behavior at x→0+ of y'+xy=1/x^3 is to understand how the function behaves in the limit as x approaches 0 from the positive side. This can help in determining the nature of the function and its behavior near the point x=0.
2. How do you analyze the local behavior at x→0+ of y'+xy=1/x^3?
To analyze the local behavior at x→0+ of y'+xy=1/x^3, you can use techniques such as taking the limit of the function as x approaches 0, finding the derivative of the function, and graphing the function to observe its behavior near x=0.
3. What type of function is y'+xy=1/x^3?
The function y'+xy=1/x^3 is a first-order linear differential equation. This means that it can be expressed in the form of y'+P(x)y=Q(x), where P(x) and Q(x) are continuous functions.
4. What does the behavior at x→0+ of y'+xy=1/x^3 tell us about the function?
The behavior at x→0+ of y'+xy=1/x^3 can tell us about the nature of the function near the point x=0. It can help us determine if the function is continuous, differentiable, or has a vertical asymptote at x=0. It can also provide insight into the behavior of the function at other points near x=0.
5. Can the local behavior at x→0+ of y'+xy=1/x^3 be used to find the solution to the equation?
Yes, the local behavior at x→0+ of y'+xy=1/x^3 can be used to find the solution to the equation. By analyzing the behavior and making observations, we can make predictions about the solution and use techniques such as separation of variables or integrating factors to solve the equation and verify our predictions.
  • Differential Equations
