Atomic absorption spectrum
unscientific
1,734
The following photon wavelengths are observed in absorption at room temperature from an ionized atomic gas with a single electron orbiting the nucleus: λ=
13:5 nm, 11:4 nm, 10:8 nm. Use this data to determine the effective Rydberg constant
and the nuclear charge.
I know that energy is emitted/absorbed when electron transits between different energy levels.
Thing is, I don't even know what the n=1 energy is, to find the rydberg constant. I can't tell what the energy levels are just from the photons absorbed, as they could be between any two levels.
Answers and Replies
13,019
Don't give up before you even started.
Did you convert the wavelength values to photon energies?
Which patterns do you expect in the energy spectrum?
unscientific
1,734
I expect, the gaps between energy levels to become smaller as you go higher up..
unscientific
1,734
13.5nm -> 92.1 eV
11.4nm -> 109.0 eV
10.8nm -> 115.1 eV
So
n=1 is 92.1 eV
n=2 is 109.0 eV
n=3 is 115.5 eV
Then what is the point of giving us the other 2 absorption wavelengths?
13,019
So
n=1 is 92.1 eV
n=2 is 109.0 eV
n=3 is 115.5 eV
Photon energies are not the energies of states!
Which photon energies (not electron energy states) do you get for a hydrogen atom? Which ratios do you have between those values? Do you see a similarity to your problem?
unscientific
1,734
For Hydrogen:
E1 = -13.6 eV
E2 = -3.4 eV
E3 = -1.51 eV
E4 = -0.850 eV
Based on the wavelengths given, 92.1eV, 109eV, 115.5eV are differences in energy between En and E1.
The ratio of first energy level between the gas and hydrogen = Z2, where Z is the proton number of the gas.
unscientific
1,734
Ok using the relation ΔE = (1- 1/n2)
First emission:
92.1 = E1(3/4)
Second emission:
109 = E1(8/9)
Third Emission:
115.5 = E1(15/16)
These ratios match, so somehow these are the emissions from the second, third and fourth energy levels.
E1 = (13.6)Z2
Solving, Z = 3 (Lithium) and E1 = 122.4eV, R = (13.6eV)/hc = 1.09*107
13,019
That is correct.
I think the factor of 9 is missing here, and the last value should have units.
Suggested for: Atomic absorption spectrum
