- #1
nuby
- 336
- 0
If an atom with more protons have tighter electron orbitals than atoms with fewer protons, why doesn't the "atomic radius" decrease up the periodic table? Instead it increases, why is this?
Atomic radius is the distance from the center of an atom's nucleus to its outermost electron shell. As you move across the periodic table from left to right, the atomic radius decreases. This is because as you move across a period, the number of protons in the nucleus increases, resulting in a stronger pull on the outermost electrons, making the atom smaller.
Atomic radius increases as you move down a group due to the addition of new electron shells. Each new shell is further from the nucleus than the previous one, resulting in an increase in atomic radius.
Elements with a larger atomic radius tend to be more reactive because their outermost electrons are further from the nucleus, making them easier to remove or share with other atoms. This is why elements on the left side of the periodic table, which have larger atomic radius, tend to be more reactive than elements on the right side.
No, atomic radius generally decreases as you move across a period. However, there are some exceptions to this trend, such as the noble gases which have a full outer electron shell and therefore have a larger atomic radius than the elements in the same period.
Other factors that can affect atomic radius include the charge of the nucleus (elements with more protons will have a smaller atomic radius), the number of electrons in the outermost shell (more electrons result in a larger atomic radius), and the presence of electron shielding (which can decrease the effective nuclear charge experienced by outer electrons, resulting in a larger atomic radius).
