Why Does the Atwood Machine Calculation Yield the Same Tension on Both Sides?
In summary, the conversation discusses a question about a sample problem in the McGraw Hill Physics 12 book, specifically an Atwood machine with two objects connected by a rope over a pulley. The question asks for the acceleration and tension of the masses, and the conversation provides calculations for both using different approaches. The conversation also includes a discussion on the sign convention for forces and how it affects the calculation of tension.
Jaimie
35
Hello,
I have a question about a sample problem in the McGraw Hill Physics 12 book. (p. 38-39). "An Atwood machine is made of two objects connected by a rope that runs over a pulley. The objects on the left (m1) has a mass of 8.5 and the object on the right (m2) has a mass of 17kg. a) What is the acceleration of the masses? b) What is the tension of the rope."
Okay. So my question is for b). I understand that to find the tension I can calculate it using either the left of right sides of the diagram (if I were to sketch this out). The acceleration was calculated at 3.27 m/s^2. Therefore w/ left side:
-Fg1 + FT = ma
FT= m1g + m1a
FT= (8.5)(9.81) + (8.5)(3.27) = 111.18N
If I want to check with the right side of the diagram
-FT + Fg2 = m2a
Fg2 - m2a= FT
(17)(9.81) - (17)(3.27) = FT
111.18N
I know that I should be getting a negative value for the latter calculation. Can someone guide me as to what I am doing wrong. Thank you so much for your help!​
What makes you think you are doing anything wrong?
Did you draw free-body diagrams for part (a)?
The tension force points upwards for both masses, and gravity points down for both of them. You seem to have defined the +ve direction for forces in terms of the direction the rope slides over/turns the pulley.
Since you have used the sign of the force to represent direction, explicitly, in your equations, then the variables themselves represent magnitudes, so they should always be positive. i.e. you write "-Fg1" to show a positive magnitude Fg1 force in the negative direction. Thus, when you write "-FT" in the second relation, that is a positive value of FT in the negative direction... and you solved for the value.
You did nothing wrong. For the right side you chose down to be positive. And you used FT to represent the magnitude of the tension force on the mass (thus the minus sign in front of it). So of course its positive. (And the tension in the rope should be a positive number anyway.)
Looks like Simon beat me to it!​
The example given in the book and was calculated as follows and different to mine:
Fg2+ Ft= m2a
m2g + Ft= m2a ** shouldn't at this point the ft be '-' and m2g be '+' ?*
FT=m2a -m2g
FT= (17)(3.27) - (17)(9.81)
= -111.18N
I don't quite understand how you can get this result as '-', if all forces are assigned their respective force directions. Please advise?
Fg2+ Ft= m2a
Personally, since I know the tension force acts upward, I would have written the tension force as - Ft, which would make Ft positive. Just as you did above.
But here they just called the force Ft and let the equations tell you which way it acts.
FT=m2a -m2g
= -111.18N
So the unknown tension force acts upward, that's why it's negative.
But the tension force was not assigned its correct direction--that's why it turned out negative.
Thank you all for your help!
1. What is an Atwood Machine?
An Atwood Machine is a simple mechanical device consisting of two masses connected by a string or pulley system. It is commonly used in physics experiments to study the principles of motion and mechanics.
2. How does an Atwood Machine work?
The Atwood Machine works on the principle of conservation of energy. The two masses connected by the string or pulley system experience equal and opposite forces, causing them to move in opposite directions. This creates a tension in the string, which can be used to calculate the acceleration of the masses.
3. What are the key variables in an Atwood Machine problem?
The key variables in an Atwood Machine problem are the masses of the two objects, the length of the string, and the acceleration of the system. Other factors such as friction may also need to be considered depending on the specific problem.
4. How do you solve an Atwood Machine problem?
To solve an Atwood Machine problem, you will need to use the equations of motion, Newton's laws of motion, and the principle of conservation of energy. Start by identifying the known and unknown variables in the problem, and then use the appropriate equations to solve for the unknowns.
5. What are some common applications of Atwood Machines?
Atwood Machines have many practical applications in engineering and science. They are commonly used in elevators, cranes, and other lifting systems. They are also used to study the principles of mechanics and motion in physics experiments.
