Average Acceleration Question
In summary: Average AccelerationIn summary, the question asks for the magnitude and direction of the average acceleration of a car that is initially traveling due northwest and then rounds a corner to travel due northeast after 10 seconds. The car is traveling at a constant speed of 20 m/s and the motion diagram for this process should be sketched. It is important to note that both velocity and acceleration are vectors.
possum30540
A car traveling at a constant speed of 20 m/s that is initially traveling due northwest rounds a corner so that after 10 s, the car is traveling due northeast. What are the magnitude and direction of the car's average acceleration during this interval of time? Be sure to sketch a motion diagram for process as well.
acceleration = change in velocity / change in time
Since the car is traveling at a constant speed, I would assume that the acceleration is zero. However, this does not seem right by the content of the question. Could someone please help me get started?
Velocity and acceleration are Vectors.
So ... Change in Velocity / change in time =
You are correct in your initial assumption that the acceleration is zero. Since the car is traveling at a constant speed, there is no change in velocity (speed and direction) over time. This means that the average acceleration during this interval of time is zero.
To further explain this, let's look at the motion diagram for this situation. Initially, the car is traveling in a straight line due northwest at a constant speed of 20 m/s. This can be represented by a horizontal line on the motion diagram, indicating constant velocity. When the car rounds the corner, it changes direction to due northeast. This can be represented by a diagonal line on the motion diagram, also indicating constant velocity. Since there is no change in velocity over time, the acceleration is zero.
In summary, the magnitude of the car's average acceleration during this interval of time is zero and the direction is not applicable. This is because there is no change in velocity, and therefore no acceleration, during this interval of time.
1. What is average acceleration?
Average acceleration is the measure of how much velocity changes over a certain period of time. It is calculated by dividing the change in velocity by the change in time.
2. How is average acceleration different from instantaneous acceleration?
Average acceleration is the average rate of change of velocity over a specific period of time, while instantaneous acceleration is the rate of change of velocity at a specific moment in time.
3. What is the formula for calculating average acceleration?
The formula for average acceleration is: a = Δv/Δt, where a is the average acceleration, Δv is the change in velocity, and Δt is the change in time.
4. How is average acceleration related to Newton's Second Law of Motion?
Newton's Second Law of Motion states that the acceleration of an object is directly proportional to the net force acting on the object and inversely proportional to its mass. This means that the greater the net force, the greater the acceleration, and the smaller the mass, the greater the acceleration. So, average acceleration can be used to calculate the net force acting on an object if the mass is known.
5. What are some real-life examples of average acceleration?
Some real-life examples of average acceleration include a car accelerating from a stop sign, a roller coaster going down a steep drop, a person jumping off a diving board, and a rocket launching into space.
