1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Average acceleration
  1. Feb 19, 2008 #1
    A 45.0 g Super Ball traveling at 30.0 m/s bounces off a brick wall and rebounds at 21m/s. A high-speed camera records this event. If the ball is in contact with the wall for 3.0ms, what is the magnitude of the average acceleration of the ball during this time interval? (It should be positive)
    2. Relevant equations
    1ms=10^-3s
    average acceleration=final velocity-initial velocity/time interval
    3. The attempt at a solution
    21-30/3-0=-3ms
    1ms(10^-3s/-3ms)=-.00033
    but this can't be right because it's negative, right?
    Thank you very much
  3. Feb 19, 2008 #2
    PhanthomJay
    The negative is OK, but your magnitude is incorrect. You must watch your plus and minus signs in your designations of the initial and final velocities...they are in different directions. Also, if you end up with a negative for the acceleration, you should interpret its meaning.
  4. Feb 19, 2008 #3
    I am not sure if you have gotten to impulse, but if you have, then you can solve with those equations. Recall that linear momentum J equals the change in impulse - J=mv2-mv1
    Also remember that J=Favg*T
    You'll have solved for J, and you already know that T=3 ms, so you should be able to find your average force during this period of time. Your average force should equal mass times your average acceleration.
    F=ma
    a=Favg/m
    That's how I would solve it. Let me know if that helps.
  5. Feb 19, 2008 #4
    Thank you very much
  6. Feb 20, 2008 #5
    Does this look correct?
    I know that the average acceleration=velocity/time
    So couldn't I do the following?
    Average acceleration=-21-30/3-0
    = -17
    In order to find the magnitude, I would need to put this in scientific notation, right?
    -1.7 X 10^1
    The magnitude would be 1, right?
    Thank you very much
  7. Feb 20, 2008 #6
    PhanthomJay
    You have got to be consistent with your units. The average acceleration is the change in velocity over the change in time. Velocity is given in meters per second; you should therfore first convert 3 milliseconds to seconds, before doing the division. What will be the units of the acceleration?
    Magnitude means 'how much', it does not refer to the scientific notation exponent; it just means "how much is the acceleration?" You don't necessarily have to convert to scientific notation, although it sometimes makes the result clearer by avoiding a lot of zeros.
  8. Feb 20, 2008 #7
    Thank you very much
    Does this look right?
    -21-30/.003-0= -17000
    1000ms=1s
    3ms=.003
    But it says that it should be positive
    Thank you
  9. Feb 20, 2008 #8
    PhanthomJay
    math is good, but what are the units of the acceleration? The magnitude of the acceleration is 17,000 (____) (fill in the blank with the correct units; if the velocity is in m/s and the time is in seconds, what are the units of the acceleration?).
  10. Feb 20, 2008 #9
    Thank you very much
    Regards
  11. Feb 20, 2008 #10
    PhanthomJay
    You are welcome. Oh, by the way, you got a negative value because you assumed the initial velocity of the ball was positive to the right, and its final velocity was negative to the left, thus it's change in velocity was Vf-Vi= -21-30= -51m/s , where the minus sign means that the velocity change, and hence the acceleration, is to the left. The magnitude of the acceleration is just the absolute value ,or a positive number, of 17000m/s^2. The negative indicates the direction.
Have something to add?
Similar Discussions: Average acceleration
  1. Average acceleration (Replies: 7)
  2. Average Acceleration (Replies: 2)
  3. Average acceleration (Replies: 1)
  4. Average acceleration. (Replies: 12)
  5. Average acceleration (Replies: 4)
Loading...
