Calculating Average Power for a 1500kg Car Going from 0 to 90km/h in 5s
In summary, the problem involved finding the average power required for a 1500kg car to go from zero to 90km/h in 5.0 seconds. Using the equations P=Fv and Vf^2-Vi^2=2aS, a final average power of 93750w or 125.7 hp was calculated with the help of finding the acceleration and displacement.
bob24
A 1500kg car can go from zero to 90km/h in 5.0 seconds. What is the average power required to do this?
I tried with P=Fv, I don't really know what else to use(
First I converted the 90km/h to m/s and got 25m/s/
Then I did F=mg with m=1500 and g=9.81m/s^2
Then I used the equation P=Fv
P=Fv
P=14175 x 25m/s
P=354375W
ANSWER: 93750w OR 125.7 hp.
Any help would be greatly appreciated.
Thanks
bob24 said:
3. The attempt at a solution
OK
You can't use g hare. Find the acceleration. And then the displacement.
OK
Ok I got acceleration=5m/s^2, and then I did Vf^2-Vi^2=2aS and got 62.5 meters for S.
So do I do
F=ma
F=1500 x 5
F=7500 N?
Now average power =ForceX average velocity
Excellent. Thank you very much!
1. What is an "Average Power Problem"?
An average power problem is a type of physics problem that involves calculating the average power of an object or system over a given period of time. This is typically done by finding the rate at which energy is transferred or transformed within the system.
2. How is average power different from instantaneous power?
Average power is the average rate at which energy is being transferred or transformed over a period of time, while instantaneous power is the rate at which energy is being transferred or transformed at a specific moment in time. Average power takes into account the entire time period, while instantaneous power only considers a single moment.
3. What are some common examples of average power problems?
Some common examples of average power problems include calculating the average power output of an engine, finding the average power consumption of an electrical appliance, and determining the average power generated by a wind turbine over a certain period of time.
4. What are the units for average power?
The units for average power are watts (W) or joules per second (J/s). These units represent the rate at which energy is transferred or transformed over a given period of time.
5. How can I solve an average power problem?
To solve an average power problem, you will need to know the amount of energy transferred or transformed over a given period of time, as well as the time it took for the energy transfer or transformation to occur. Once you have this information, you can use the formula P = E/t, where P is the average power, E is the energy, and t is the time period.
