Runner's Average Velocity: 0.014 m/s
In summary, the runner's average velocity for the entire journey from start to finish is 0.476 m/s west. This is calculated by dividing the displacement of 300 meters by the total time of 630 seconds. The runner first moves 1200 meters east at a velocity of 4.0 m/s for 5 minutes (300 seconds), then moves 1500 meters west at a velocity of 5.0 m/s for 5 minutes. The distance traveled is greater going west because the runner's velocity is greater.
Mary27
A runner moves with a velocity of 4.0 m/s due east for 5.0 minutes. The runner then rests for 30 seconds, turns around and heads due west with a velocity of 5.0 m/s for 5 minutes. What is the runner's average velocity for the entire journey from start to finish?
Is there a different formula for velocity and average velocity?
distance/time 9/630=0.014
Mary27 said:
distance/time
No, distance/time gives average speed. Velocity is a vector, and average velocity is displacement/time.
What is the vector displacement for the journey?
Is the vector displacement -1
Does the rest period for 30 seconds come into the equation?
No, to the above question.
Yes, to the following question.
Displacement is the straight line distance from the starting point to the ending point.
Small, ahem, clarification. Displacement is a vector; its magnitude is the straight line distance from the starting point to the ending point.
Likes SammyS
So then is the total displacement 4+5?
And the time would be 630 seconds?
The equation would be: 9/630= 0.0142857
There are at least two problems with that calculation.
If you go at 4 meters per second eastward, how far will you have moved from the starting point after 5 minutes?
If you then go at 5 meters per second westward for another 5 minutes, how far will you be from the original starting point? And in which direction?
4m/s x 300sec=1200m/s
5m/s x 300sec=1500m/s
1500m/s- 1200m/s=300m/s
300m/s /630=.476m/s
Is the direction west or east? I think west.
Units? If you multiply meters per second times seconds you get what?
Mary27 said:
Is the direction west or east? I think east.
Explain your reasoning.
The first calculation is 1200m/s east
The second calculation is 1500m/s west
The distance is greater going west.
Incorrect. Units.
Incorrect. Units.
What distance? You have not computed any distances.
1500m/s-1200m/s=300m/s
300m/s / 630s=0.476m/s west
Units!
Nothing is moving at 1500 meters per second.
If you divide 300 m/s by 630 seconds you do not get a velocity. You get an acceleration.
I changed 5 minutes to 300 seconds and multiplied that by 5 m/s to get 1500.
Units, units, units.
If you multiply 5 meters per second by 300 seconds, what units should the result have?
meters per second
Mary27 said:
meters per second
You have a severe problem with carrying the correct units or a severe problem with algebra, and this could be fatal for the rest of your class.
x multiply by y gives you "xy". The same goes with units. If you multiply something with units m/s with something with units "s", you get something with units "m". It is basic algebra, i.e.
m/s * s = m
So that product gives you something that is a length!
Zz.
Likes SammyS
1. What is runner's average velocity?
Runner's average velocity refers to the average speed and direction at which a runner is moving over a certain distance. In this case, it is 0.014 meters per second.
2. How is runner's average velocity calculated?
Runner's average velocity is calculated by dividing the total distance covered by the runner by the total time taken. In this case, it is 0.014 meters per second.
3. Is runner's average velocity the same as runner's top speed?
No, runner's average velocity and runner's top speed are not the same. Runner's top speed refers to the maximum speed reached by a runner, while average velocity takes into account the overall speed and direction of the runner over a certain distance.
4. Can runner's average velocity change during a race?
Yes, runner's average velocity can change during a race as the runner may speed up or slow down at different points. It is an average measurement and not a constant value.
5. How is runner's average velocity useful in sports science?
Runner's average velocity is useful in sports science as it provides valuable information about a runner's performance and can be used to track improvements or identify areas for improvement. It can also be used to compare the performance of different runners and determine the effectiveness of training programs.
