Average volume gained each day
Try inputting 1.18 × 10−5 and see if that works. In summary, the average volume gained each day by a child with a birth mass of 3.3 kg and a birth rate of 1.2×10−2 kg/d is approximately 1.18×10^-5 m^3. There may be a discrepancy in the answer due to the use of significant figures.
frog210293
If the child's birth mass is 3.3 kg, birth rate =1.2×10−2 kg/d (baby gains that amount each day) A child is born after 39 weeks in its mother's womb.
Assuming the fetal density is 1020 kg/m^3, what is the average volume gained each day?
V=m/d
V=(1.2*10^-2)/1020
V=1.76*10^-5 which is incorrect??
Hell frog210293,
Welcome to Physics Forums!
frog210293 said:
V=(1.2*10^-2)/1020
Redo your calculation. (1.2 x 10-2 [kg d-1])/(1020 [kg1 m-3]) ≠ 1.76 x 10-5 [m3 d-1].
ohh woops i redid it with the brackets and came up with 1.18*10^-5 but this is still wrong?
That's about the answer that I got.
Are you supposed to give your answer in m3 per day, or do you need to convert to some other units like liters per day (or cubic centimeters per day)?
Also, there are two ways to do the problem. You could trust the given mass rate of 1.2 × 10−2 kg/d, or you could recalculate a more precise version given that the birth mass was 3.3 kg, and the time elapsed was 39 weeks. (You get almost the same rate of 1.2 × 10−2 kg/d, but with more significant figures.)
Maybe the program is counting it wrong because you are not using the correct number of significant digits, maybe? I'm not sure.
I would like to point out that the given information is insufficient to accurately calculate the average volume gained each day. The formula V=m/d is correct, but the given birth rate of 1.2×10−2 kg/d is not enough to determine the mass (m) gained each day. Additionally, the fetal density of 1020 kg/m^3 is not a relevant factor in this calculation. To accurately determine the average volume gained each day, we would need to know the specific growth rate of the child's body mass, which can vary greatly from individual to individual. Without this information, it is not possible to accurately calculate the average volume gained each day.
1. What is the definition of "average volume gained each day"?
The average volume gained each day refers to the average amount of volume or space that is added to a substance, object, or area on a daily basis. This measurement is typically used in scientific studies to track changes over time.
2. How is "average volume gained each day" calculated?
The calculation for average volume gained each day involves dividing the total volume gained over a certain period of time by the number of days in that period. This gives an average rate of volume gain per day.
3. What are some examples of substances or objects that may have an "average volume gained each day"?
Some examples of substances or objects that may have an average volume gained each day include plants growing in soil, water levels in a lake, or the size of a tumor in a medical study.
4. How is "average volume gained each day" different from "total volume gained"?
While average volume gained each day takes into account the rate of volume gain over time, total volume gained only looks at the overall change in volume without considering the time factor. Average volume gained each day can provide more insight into the rate of change and potential trends.
5. How can "average volume gained each day" be used in scientific research?
Average volume gained each day can be used in scientific research to track changes and patterns over time, analyze the effectiveness of certain treatments or interventions, and make predictions about future outcomes. It can also be used to compare different substances or objects and their rates of volume gain.
