B+ In physics
isukatphysics69
453
Worked really hard this semester in physics 1 and got a B+. So i worked as hard as i could and my mental capacity has proven to only be capable of a B+ at full throttle in a challenging course. i put my other classes on the back burner for physics and i end up with a B+. Not sure how i feel about this
Answers and Replies
Choppy
Education Advisor
Insights Author
4,795
2,061
You might want to take some time and reflect on this experience. Were there any big lessons that you learned looking back over the year? Did you have any breakthrough moments?
You can't define yourself by a single grade. The B+ is how it all shook out this time around. Is it likely that's going to repeat itself, or do you feel as though you've learned some things that will help you in your next set of courses?
Likes isukatphysics69
256bits
1,734
Was it the math? the concepts?
Sometimes letting it stew for a few months and it all comes together better.
( As long as one doesn't forget everything after the exam :H , which though is easy to pick up again with a simple refresher of leafing through the books, so all is not lost )
newjerseyrunner
1,535
637
I would look at what caused you to get the B+. Look back at your graded papers and find what got marked down. Did you have trouble with the overall concept or just a particular part. I was certainly no straight A student. I understood the concepts fine, but I had difficulty with terminology. I'm still not sure I could describe some of the more advanced programming techniques even though I use them every day.
symbolipoint
Education Advisor
1,573
Why worry about this B+ grade? This was not like struggling between D and C grade for a course. Are you just worried that the next Physics courses might be tougher to get B grade too or that the grades will be lower? You really do not know until you do one or two more of them.
Review can be a good thing.
Vanadium 50
Staff Emeritus
Education Advisor
2021 Award
29,204
14,462
A B+? The horror!
If you look at all the threads in this section, you will find someone who got a B once! O horror, horror, horror! Tongue nor heart cannot conceive nor name thee!
InfiniteEntity
OP, don't fret it. I worked hard for my high-school physics exam and prepared for the exam 2 months prior to it's commencement. I got a D.
symbolipoint
Education Advisor
1,573
Depending on if O.P. is at high school or at college/university, the importance of letter grade would be very different.
InfiniteEntity
Can you explain the difference please? I fail to recognize any since they both use the same grading system for the most part.
jamalkoiyess
217
The problem can be in the test taking.
had the same experience, even a worse one. Hard work for an 86 then I dropped a course and worked double and ended up with a 40. I just forget half the material in the exam
Another problem might be because you thought you worked hard but actually didn't. Happened to me too. Spent a week on material that required a day. Turned out I wasted half the time without knowing! Since then I set time for extreme focus work and then fool around for the rest of the day. Thus freeing more time and having better grades.
Suggested for: B+ In physics
  • Last Post
  • Last Post
  • Last Post
