How can forces on a disc be balanced at different angles around a circle?
In summary: You can also think of it as that point around which the disc would balance if there were no external forces.The disc is sitting on top of a marble in the center of a circle. There are no external forces acting on the disc.Now I apply four forces, all at 90 degrees apart, to the disc. This balances the disc.Then I add a force at 45 degrees, and the disc tips up at 315 degrees. This is because the force at 315 degrees is greater than the force at 45 degrees.
mechdesignron
This seems like it would be pretty simple and I apologize if this is in the wrong area, here goes.
Picture a flat disc. It is supported by a pin or marble in the center. There are no forces acting on it.
Now at 0 deg, I apply a force F (all forces are a distance equal from the center), resulting in a force -F at 180 deg. Simple enough.
Then if I apply an equal force N at 180 deg, the disc becomes flat again, or balanced.
If I apply another N force to the 90 deg position, my disc again goes out of balance, tipping up at 270 deg. I think this becomes out of balance equal to when I placed the first force on the disc because the first two forces with the marble, creates a line and a fulcrum.
So now I place 4 forces 90 deg apart, and it is balanced. Then add another force at 45 deg. This would cause the disc to want to raise at the 315 deg but I would think that it would not have the same effect as the first force.
I am looking for a formula or algorithm that I can input forces around a circle at different angles and calculate the out of balance force and angle.
Any information and help would be appreciated.
Ron
Apply a force F in what direction?
Not simple to me. Why should applying a force at one point result in a force at another point?
Ron
Think of the marble as a single point fulcrum. The disc is sitting on top of it along the X plane. All the forces are directed down (negative Y direction). Applying a force on the edge of the disc will result in the other end of the disc to act in the opposite direction, like a teeter-totter. If you push on one end of the teeter totter, you get a force on the other end. But I'm working with a disc. Hopefully this makes things clearer.
Your forces create torques around the center. You want the sum of them to be zero.
http://en.wikipedia.org/wiki/Torque
As it stands, your question is too vague for a definite answer.
I think you should try to restate your original question, making clear whether or not the disc is actually in equilibrium and whether it has mass (moment of inertia).
When you say that there is an equal and opposite force on the other side of rim, this will only happen if there is something for that point to push against - and I don't think your model includes this. Without one, all that will happen is that the disc will tip and continue to tip (accelerating).
If you are talking about the equilibrium situation then there are many combinations of forces around the disc (downwards, I assume) that will produce equilibrium. Problems about Moments are usually confined to two dimensional bodies but it is quite possible to solve for a 3D situation, like your disc. You just need to split the problem into two axes at 90° across the disc and work out moments about each axis.
Ok, let's try this. I have a number of springs in a circle applying force on a disc. The disc is in balance as long as I have the springs equally spaced. I want to try to maintain an equal balance of force all the way around. There would never be a situation where there would only be one spring but there would be cases where I may want to place an odd number of springs around the disc. If I were to use only 1 spring on one side and the spring applied a force of 50 pounds or Newtons, the disk would be out of balance (by force applied) by 50 to its direct opposite. Now picture a situation with say 4 springs each applying 50 Force (same distance from center) at places 0 deg, 110 deg, 210 deg, & 285 deg. They are unequally spaced causing an unbalance of force of some amount at some angle.
I tried to create a spreadsheet where I split the disc down an axis and calculated the force applied to one side versus the force applied to the other side. Picture the disc split into left and right sides. But that doesn't work because you can have all your forces on the top of each half and the results show a balanced disc.
I speculate I may need to find the forces using polar vectors and sum them somehow.
You could also look at this problem as taking a 2" thick steel disc and drilling holes around a bolt circle. The mass removed would cause an imbalance of gravitational force.
Why speculate, if have been given the answer already? You have to balance the torques (moments) around the center. You don't need polar vectors, just normal Cartesian vectors.
1. What are balance forces on a disc?
Balance forces on a disc refer to the equal and opposite forces acting on a disc, causing it to remain in a state of equilibrium and not accelerate in any direction.
2. How do balance forces affect the motion of a disc?
Balance forces on a disc have no effect on its motion as they cancel each other out, resulting in a net force of zero. This allows the disc to remain stationary or maintain a constant velocity.
3. What are some examples of balance forces on a disc?
Some examples of balance forces on a disc include a disc sitting on a flat surface, a disc spinning at a constant speed, or a disc hanging from a string at rest.
4. How do balance forces differ from unbalanced forces on a disc?
Balance forces on a disc have an equal magnitude and opposite direction, resulting in no net force. On the other hand, unbalanced forces have a net force and can cause a change in the disc's motion.
5. What happens if there are no balance forces on a disc?
If there are no balance forces on a disc, it will experience a net force and accelerate in the direction of the unbalanced force. This can cause the disc to move, change direction, or change speed.
  • Classical Physics
  • Classical Physics
  • Other Physics Topics
  • Mechanics
