Balancing Chemical equations
  • Thread starter alingy1
alingy1
325
"The reaction of ethane gas (C2H6) with chlorine gas produces C2H5Cl as its main product (along with HCl). In addition, the reaction invariably produces a variety of other minor products, including C2H4Cl2, C2H3Cl3, and others. Naturally, the pro- duction of these minor products reduces the yield of the main product. Calculate the percent yield of C2H5Cl if the reaction of 300. g of ethane with 650. g of chlorine produced 490. g of C2H5Cl." (Zumdahl, Chemistry, 2013)
Balancing and math principles.
Ok, I have the answer in the solution manual. It gives out 82.9%.
But, the thing I do not understand about the way they do the problem is this:
They use the formula C2H6+ Cl2-> C2H5Cl+ HCl
However, that's not what is really happening. There are other products formed.
I thought of this formula (which is missing ''the other'' products):
C2H6+ Cl2-> C2H5Cl+ HCl +C2H4Cl2+C2H3Cl3 + others
I found different ways of balancing this last formula if I ignore the others.
Why does the first equation give the right answer? Won't the other molecules intervene in the calculations?
Answers and Replies
chemisttree
692
No, they don't. You can't be certain the other products were produced anyway. The other "products" COULD be unreacted starting material!
alingy1
325
But, there still may be other products. I don't understand how those cannot have an impact on the reaction balancing.
Borek
Mentor
29,096
3,707
Theoretical yield assumes only one product.
Note that in this particular case you can't uniquely balance reaction with several products. Each of these:
2C2H6 + 3Cl2 -> C2H5Cl + C2H4Cl2 + 3HCl
50C2H6 + 67Cl2 -> 33C2H5Cl + 17C2H4Cl2 + 67HCl
1028C2H6 + 1119Cl2 -> 937C2H5Cl + 91C2H4Cl2 + 1119HCl
is balanced OK. Which one of these is the correct one?
alingy1
325
All of them could be correct i guess. Hmm, you are intriguing me here. Theoretical yield applies only when there is one product? What about the HCl?
Borek
Mentor
29,096
3,707
Sorry, lousy wording, one main product. HCl doesn't matter, as its amount is related to the main product - you don't need more ethane to produce HCl.
Suggested for: Balancing Chemical equations
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
