Balancing Equations
  • Thread starter Barclay
Main Question or Discussion Point
This is a question, not a home work.
The book I'm reading explains how to balance equations step-by step.
UNBALANCED EQUATION IS THIS: C2H6 + O2 = CO2 + H2O
The book gets to this: C2H6 + O2 = 2CO2 + 3H2O
The book says "There are 7 oxygen on the right-hand-side but only 2 on the left". All fine so far.
Then the book says "Oxygen's HAVE to go around in PAIRS so how can you get an odd number (7) of them on the left side".
Then the book goes on to balance the equation: 2C2H6 + 7O2 = 4CO2 + 6H2O
My questions are this:
1. Do Oxygen's HAVE to go around in PAIRS? What if I balanced an equation (any equation) and there were say 7 oxygen on left side and 7 on the right side - would that be incorrect? Would I have to get 14 on both sides (or an even number on both sides)?
2. If the book is correct and "Oxygen's HAVE to go around in PAIRS" then what other elements HAVE to go around in pairs or triplets etc (for the purpose of balancing equations)?
[This is HIGH SCHOOL CHEMISTRY]
Thank you.
Answers and Replies
10,585
Oxygen has to be paired as gas - it is perfectly fine to have 7 oxygen atoms at both sides, as long as some odd number is bound in molecules on both sides.
Your left side just has oxygen as O2, that cannot give an odd number.
Ozone is O3, but you will rarely see that in those questions.
The typical gases apart from noble gases: hydrogen, nitrogen, oxygen, all halogens, and some more exotic gases.
Borek
Mentor
28,473
2,871
To make balancing easier you can use something like [itex]3\frac 1 2 O_2[/itex] to get 7 atoms of oxygen, but after the equation is balanced you should get rid of all fractional coefficients.
In other words: during balancing feel free to use fractions if it makes balancing easier, just remove them as the final step. Properly balanced equation should use a set of the lowest integer coefficients. Doesn't matter how you get there.
I'm not sure what the book means by "oxygen must be paired".
Does it mean there must be an EVEN number of oxygen atoms (in total) on each side of the equation?
PAIRED means an EVEN number yet MFB you say that 7 oxygen is okay on both sides.
Edited bit later:
I've just been looking at a few balanced equations and it seems that each compound that contains oxygen (in a balanced equation) must have an EVEN number of oxygen atoms on each individual molecule. Is that right?
Why must oxygen be paired?
Yes the next step in the book does mention 3 1/2 fraction
10,585
No.
It just means you cannot have 1/2, 3/2 or similar fractions of O2 in the final equation.
No.
Thanks for that BUT can there be single oxygens in the balanced equation?
E.g in the balanced equation:
Can there exist say H2O or does it have to be 2H2O ?
Can there exist say MgO or does it have to be 2MgO ?
Borek
Mentor
28,473
2,871
H2O and MgO are perfectly OK. Pure, gaseous oxygen is made of diatomic molecules, so it is O2. In other compounds it is no longer pure, gaseous oxygen, so it doesn't have to be in pairs.
10,585
Yes.
Just forget the book's comment if it causes so much confusion. There is nothing special about oxygen.
Borek
Mentor
28,473
2,871
As I wrote earlier - the only way book can be confusing is when the comment about "single oxygens" is applied to every oxygen in every compound, and not only to gaseous, elemental oxygen O2.
Related Threads on Balancing Equations
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
