Homework Help: Ball and Box Collision.
  1. Jul 8, 2012 #1
    A ball with mass 2.5 kg is moving in outer space with a velocity of 6.0 m/s horizontally, and a box of mass 4.5 kg is moving with a velocity of 4.0 m/s at a angle of 120 degrees from the horizontal. the two collide and stick together. Find the final velocity of the pair.
    2. Relevant equations
    Px = Pix = Pfx
    MaVa + MbVb = Vf(Ma+Mb)
    3. The attempt at a solution
    My first question is whether or not, we take into account the angular velocity of the ball. With that said, I started off the solution using the above formula for x and y.
    In the X:
    MaVax + MbVbx = Vf(Ma+Mb)
    with Vbx = 4 cos 120, this came out to .85ms-1, is this correct?
  3. Jul 8, 2012 #2
    cepheid
    Staff Emeritus
    Welcome to PF,
    This is a 2D problem. You need to consider consv. of momentum in both the x and y directions. The problem asks for the final velocity of the objects, not just for the x-component of their final velocity.
    EDIT: I haven't checked your arithmetic, but your method for the x-direction looks correct.
    EDIT 2: What makes you think the ball has any angular velocity? In any case, this is not relevant to the problem.
  4. Jul 8, 2012 #3
    Thanks for the welcome, and I understand what you are saying. I didn't do the Y part because I wanted to make sure I was doing the x correctly. So with that said, what do you think.
    Also in the Y part, there is no velocity for the Ball, Ma.
  5. Jul 8, 2012 #4
    cepheid
    Staff Emeritus
    See the edits to my above post. Also, I do not get the same answer for the x-component of the velocity. Can you show your computational steps?
  6. Jul 8, 2012 #5
    Sorry, I just noticed the v of the ball is 6, not 6.9 . But my calculation was this:
    2.5 x 6 + 4.5 x 4 cos 120 = Vfx x 7
    =.85
    Is this the right angle? Because when I do the calculation for the Y, I get this:
    Y = 4.5 x 4 cos 120 = Vfx x 7
    = -1.28
    This would mean that the velocity is negative.
  7. Jul 8, 2012 #6
    cepheid
    Staff Emeritus
    Okay, the x-equation looks fine. For the y-equation: why are you using cosine for the y-component of the velocity?
    You know that this answer cannot be right, because the vertical momentum is conserved, and the initial vertical momentum is all upward, which means that the final vertical momentum must also be upward (draw a picture).
  8. Jul 8, 2012 #7
    Ok I now get Y = 4.5 x 4 sin 120 = Vfx x 7
    Which comes out to 2.22 and a total v of 3.07. This seems correct. Thanks for your help.
  9. Jul 8, 2012 #8
    cepheid
    Staff Emeritus
    I agree with your y-component of the final velocity, but NOT with your total magnitude. Bear in mind that you compute the total velocity by taking a *vector sum* of the x and y-components, and that these are *perpendicular* to each other.
  10. Jul 8, 2012 #9
    I see, I forgot about that.
    I got 2.39 after taking the square root of both of them squared.
  11. Jul 8, 2012 #10
    cepheid
    Staff Emeritus
    Seems right to me. Always draw a diagram when doing these problems. It helps immensely, esp when it comes to avoiding errors like these.
