Ball and string
  1. Feb 20, 2008 #1
    I asked my Physics teacher about this and he was stumped. He went to ask the other AP Physics teacher, and he too had no clue. So if you guys know how to do this, feel proud. You're smarter than my teachers anyway....
    Imagine that there's a ball attached with a string, as shown in attachment. there is no initial tension in the string. assume that the string does not "give"; it does not stretch. one end is the ball, initially at rest; the other end of the string is at a fixed point (0,12). The larger semicircle is the path the ball will follow once it falls far enough. (I figured out the length of the string in my question using some calculus and simply drew a circle centered at (0,12) with that radius.)
    We've only learned when the ball always follows a perfect circular path, but in this scenario, it starts falling completely vertically until it is caught by the string.
    How do calculations with this work? How high does it go after falling and being caught by the string? what speed is it going at the instant tension becomes present in the string? what is the speed at the lowest portion of the arc?
    If you need some values, assume that the ball is only a point with mass of 1 kg. It starts 12 m above the ground (x axis).
    the length of the string is approximately 9.29357m.
    |g|=10 m/s/s
    i have studied energy including PE=mgh and KE=.5mv^2. but that's the extent of my knowledge on that topic.
    Thanks in advance.
  3. Feb 20, 2008 #2
    rcgldr
    Take the case where the ball is dropped from directly under the support. It follows the normal laws of free fall until the string stops it, and now collision like physics takes over. If the string is elastic, then the ball "bounces" back upwards. If the string is not elastic, then the ball basically stops.
    As the initial point of release is moved horizontally from the support, the collision effects are reduced, and the ball will have more horizontal velocity.
  4. Feb 20, 2008 #3
    russ_watters
    Staff: Mentor
    Because of the instant acceleration, the string can't not stretch, but if it could be, KE+PE=Const applies and the ball follows the arc all the way up to the top. Conservation of Energy.
  5. Feb 21, 2008 #4
    so in this case the initial mechanical energy is solely potential energy, mgh=(1)(10)(12)=120J. this is partially converted into kinetic energy (partially because it doesn't go completely to the ground), but this kinetic energy's v value is vertical, meaning that the velocity isn't tangential to the new circular path at the instant the string receives tension due to the ball. how could you figure out the tangential velocity at that point? is it just the same magnitude as the instant before when it was dropping solely vertically?
  6. Feb 21, 2008 #5
    rcgldr
    I'm not sure about at that point, but the tangental velocity would be due to the downward pull of gravity versus the tension in the string, and the position of the ball when the string tightens up.
    If the string were an elastic rubber band or spring, the resultant motion would be a bouncing of the ball up and down while it swung side to side.
  7. Feb 21, 2008 #6
    russ_watters
    Staff: Mentor
    No, you find it the same way you do with a pendulum: By solving for V in the kinetic energy equation.
  8. Feb 21, 2008 #7
    Ben Niehoff
    The ball will fall straight down until it reaches the circle you've drawn that represents the string's length. Assuming an ideal, massless, unstretchable, perfectly elastic string:
    At the instant the ball reaches that circle, it will experience an impulse (i.e., an instantaneous change in momentum) directed along the length of the string (i.e., back toward the point (0,12)). This impulse will behave exactly like the impulse from a collision with an immovable wall; i.e., a pure reflection as though from an immovable wall tangent to the circle.
    After this instant, the ball's new momentum can be used as the initial condition for simple projectile motion: it will follow a parabolic arc upwards and to the right. When it reaches the circle again, it will again reflect, and follow a new parabolic arc, etc.
    In essence, you can calculate everything as though that big circle you've drawn is a perfectly rigid, spherical shell. The ball will just bounce around inside.
    Note that the ball will not bounce as high as the starting point on its first bounce, because it will hit the imaginary "spherical shell" at a glancing angle; while energy will be conserved, the ball's momentum is redirected, so part of the energy is devoted to horizontal motion.
    If the ball ever happens to bounce in such a way that will send it back straight up (not very likely; this is a chaotic system), then it will bounce up to its original height (i.e., 12 m). In all other cases, it will always be lower.
    Note that in reality, strings can stretch slightly (like springs), and that balls have non-zero spatial extent, and are therefore able to spin and turn. So if you actually conducted this experiment, both of these effects would sap energy out of the system, and redirect it into other forms. In the absence of friction, we would expect total energy to be conserved, but thermodynamics tells us that on average, the energy would be equally divided between all the various forms available: translation in x, y, and z, rotation of the ball around its three axes, and stretching of the spring. This gives 7 degrees of freedom, of which 3 are translational, so in reality, you would expect the translational motion of the ball to be as though the ball had 3/7 as much energy as in the ideal case, on average.
    And of course, once you add friction to the system, the ball will eventually come to rest at the bottom of the circle.
  9. Feb 22, 2008 #8
    tiny-tim
    Ignore the string!
    Ignore the string.
    If I understand you correctly, you are saying that the ball will fall vertically until it reaches the circle, and then, without bouncing away from the circle, will follow the circle up and down, up and down …
    Physically, then, the situation is the same as if, without any string, there is a semi-circular slide and the ball is assumed to move along it, without bouncing, once it hits it.
    The string, and any forces in it, are irrelevant. :smile:
  10. Feb 22, 2008 #9
    rcgldr
    Ben stated the situation correctly. Unless the collision with the arc (or string) is totally inelastic, the ball will bounce away from the circle, not slide along it.
  11. Feb 23, 2008 #10
    tiny-tim
    … let's agree on the question first …
    Well, that's what I said - and also how pchalla defined the problem:
    Isn't it? :smile:
  12. Feb 23, 2008 #11
    russ_watters
    Staff: Mentor
    It's what I said too. [i have some bad grammar in there, though]
  13. Feb 23, 2008 #12
    Can you explain the "7 Degrees of Freedom"? I have no clue what that's about.... or where you got the number "7"...
    Other than that, everything else was very very clear and understandable.
    thanks to everyone that replied.
  14. Feb 24, 2008 #13
    tiny-tim
    Ben must mean:
    3 of translation (that's straight movement)
    3 of rotation (pitch roll and yaw)
    1 of tension in the string​
    But Ben's rule is totally contrary to experience: if you drop a ball (no string) on a flat horizontal surface, it does lose some energy, but it doesn't move sideways, and it doesn't rotate! It has 6 degrees of freedom (no string), but it only uses one of them. The lost energy goes into heat and noise, not into thew other 5 degrres of freedom.
    Similarly, if you drop a ball on a string, vertically below the support of the string, it only uses 3 degrees: vertical movement, vertical rotation, and tension in the string.
    If the ball bounces, then you can't really answer the question, since different things (tennis balls, golf balls, balls of wool …) lose different amounts of energy on bouncing!
    Assuming it doesn't bounce: I said earlier "ignore the string", but I didn't say what you should do.
    I assume from your original question that you know how to work out the speed, u, of the ball just before the string goes tight, and how to work out the motion along the semi-circle if you know the speed, v, along the semi-circle just after the ball joins it.
    So all you don't know is how to calculate v from u.
    Just use Newton's third law.
    Force in any direction = change in momentum in that direction.
    Can you see a direction in which there is no force?
    Well, the momentum along that direction must be the same for u as for v! :smile:
  15. Feb 26, 2008 #14
    Unless i misunderstood you (a very good probability that I did), it's easier to answer the question "Can you see a direction in which there IS a force?"
    The instant before the string catches the ball, the only force that is exerted on the ball is gravity (that i see, anyhow). After the string catches the ball, it will swing in a perfect pendulum forever (neglecting air resistance). Then the forces acting on the ball are the weight of the ball (aka gravity) and the tension in the string.
    Can you please explain again?
  16. Feb 26, 2008 #15
    There are 2 cases here: perfectly elastic and perfectly non-elastic (and anything in between is also possible) The elastic case was described by Ben Niehoff. In the inelastic case the ball will indeed swing forever, but a lot of the energy will be lost when the string becomes tight for the first time.
    If the speed of the ball at this point is v, then you can use conservation of angular momentum to figure out that the tangential speed = [tex] v sin(\theta)[/tex]
    where [tex]\theta[/tex] is the angle that the rope makes with the vertical
    If the length of the string is r and the ball is released a distance d horizontally from the other end of the string, the ball will fall a distance [tex] \sqrt {r^2-d^2}[/tex] it's kinetic energy will be [tex] m g \sqrt {r^2-d^2}[/tex].
    after the collision only [tex]m g \frac{d^2}{r^2}\sqrt {r^2-d^2}[/tex] of this remains, so the ball will only go up a distance of [tex] \frac{d^2}{r^2}\sqrt {r^2-d^2} [/tex] above this point. This is a distance of [tex] r - \sqrt {r^2-d^2} + \frac{d^2}{r^2}\sqrt {r^2-d^2} [/tex] above the bottom of the swing
    if r = 12 and d = 6 the ball will only come 4.2 cm above the bottom point, and the angle with the vertical of the pendulum will then be 49.6 degrees.
  17. Feb 26, 2008 #16
    tiny-tim
    oops!
    oops! I forgot about gravity! sorry! :redface:
    I should have said "Can you see a direction in which there is no instantaneous force (impulse)?"
    When the string goes tight, the ball receives an impulse (an instantaneous force) from the string.
    It instantaneously changes the momentum from vertical to perpendicular-to-the-string.
    Gravity is an ordinary gradual force, not an impulse, and instantaneously has zero effect.
    From Newton's second law (it's not the third law - I got that wrong:redface:), the change in momentum is proportional to the force producing it.
    The only force producing this instantaneous change in momentum is along the string.
    So perpendicular to the string, there's no force and so the change in momentum in that direction is zero, and we have an equation for which we don't need the value of the force! (this is the point of the exercise - to avoid calculating the force - ignore anyone who ways you should!)
    And that equation is: the momentum in that direction before equals the momentum in that direction after. :smile:
  18. Feb 28, 2008 #17
    so the momentum before the string goes taught is equal to the momentum when the string has tension.
    so MV(v)=MV(t)
    (v) is vertical
    (t) is tangential.
    so mass cancels out, and then V(v)=V(t)
    just clarifying that i understood you properly.
  19. Feb 28, 2008 #18
    I don't understand any of the other math that you did kamerling, so can you explain how you got that conclusion?
    also, shouldn't the Mechanical energy be [tex](1/2) mv^2 + m g (12- \sqrt {r^2-d^2} )[/tex]
  20. Feb 28, 2008 #19
    tiny-tim
    The mass does indeed cancel out! :smile:
    I'm not sure whether you've completely got it or not, since I'm not sure what you mean by V(v)=V(t).
    Assuming that the string is at an angle [tex]\theta[/tex] to the vertical just before it goes taut, can you write it out in full, using [tex]\theta[/tex], so we can check? :smile:
  21. Feb 28, 2008 #20
    what i meant was that the magnitudes of the velocities are equal just before and just after the impulse (not the direction).
    so immediately before the ball is caught by the string it is traveling at V @ 270 degrees
    immediately after the ball is caught by the string it is traveling at V @ -theta degrees (cartesian not navigational)
    i think i might have a calculation error in there somewhere
    but it is traveling at V perpendicular to the circle at that point.
Loading...
