Homework Help: Ball launching of tray connected to spring
Tags:
  1. Apr 6, 2017 #1
    A 1.50-kg, horizontal, uniform tray is attached to a vertical ideal spring of force constant 185 N/m and a 275-g metal ball is in the tray. The spring is below the tray, so it can oscillate up and down. The tray is then pushed down to point A, which is 15.0 cm below the equilibrium point, and released from rest. (a) How high above point A will the tray be when the metal ball leaves the tray?
    mt =1.5 kg
    mb = 0.275 kg
    k = 185 N/m
    A = -0.15 m
    2. Relevant equations
    F = -kx
    F = ma
    3. The attempt at a solution
    My attempt:
    The maximum downward acceleration of the ball is -g = -9.8 so the ball should leave the tray when the acceleration of the tray is also -g.
    F = -kx = mta = -mtg
    x = mtg/k = 0.0795 m
    Δx = x - A = 0.229 m
    This is wrong and I would have gotten the right answer if I used mt + mb instead of just mt in the above equations but I can't understand why. When the ball leaves the tray the weight of the ball on the tray should be zero (because they're not in contact anymore) combined with the acceleration of the tray being -g should give the equation x = mtg/k. But apparently this logic is flawed since the right answer is given by x = (mt + mb)g/k
    Please tell me what's wrong with my logic.
  3. Apr 6, 2017 #2
    Can you clarify for me what is the condition of the spring when the acceleration of the tray is -g?
    Edit: You said that the weight of the ball on the tray is 0 and the acceleration of the tray is -g right at the point where separation occurs. Here is another question: What is it that actually causes the separation - a gap to appear between the ball and the tray. Since the acceleration of the ball at the point of, and after separation, is -g, what could cause a separation - an actual gap to appear between the ball and tray? What has to be true about the acceleration of the tray for an actual gap to appear between the ball and tray?
  4. Apr 6, 2017 #3
    ehild
    Ask the question in the way "where is the tray just before the ball leaves?".
  5. Apr 6, 2017 #4
    Oh, now I get it. According to my calculations the tray is 0.0795 m above the equilibrium height of the spring and tray system. While A = -0.15 is how far below the equilibrium height it is for the spring, tray and ball system. I get the correct answer now, thanks!
  6. Apr 6, 2017 #5
    ehild
    Well done!
Have something to add?
Draft saved Draft deleted
