Homework Help: Ball Pendulum Problem
  1. Nov 2, 2008 #1
    A heavy ball swings on a string in a circular
    arc of radius 2 m.
    The two highest points of the ball’s trajec-
    tory are Q and Q′; at these points the string is
    ±28◦ from the vertical. Point P is the lowest
    point of the ball’s trajectory where the string
    hangs vertically down.
    The acceleration of gravity is 9.8 m/s2.
    What is the magnitude of the ball’s acceler-
    ation at the point Q? Answer in units of
    m/s2.
    3. The attempt at a solution
    Wouldn't the acceleration at Q be 0 because there is no velocity at that point.
  3. Nov 2, 2008 #2
    Doc Al
    Staff: Mentor
    The centripetal acceleration will be zero, but what about the tangential acceleration?
  4. Nov 2, 2008 #3
    Ah, there would be tangential acceleration. How would you go about finding it? The initial steps.
  5. Nov 2, 2008 #4
    Doc Al
    Staff: Mentor
    Apply Newton's 2nd law. What forces act on the ball? What are their tangential components?
  6. Nov 2, 2008 #5
    The forces acting on the ball are the tension and the mg.
    TcosO=mg+ma. Since I do not know the tension, how can I solve for tangential acceleration?
  7. Nov 2, 2008 #6
    Doc Al
    Staff: Mentor
    Does the tension have a tangential component?
  8. Nov 2, 2008 #7
    T=mg
    mgcos0=ma
    a=gcos0?
  9. Nov 2, 2008 #8
    I did TcosO-mg=ma
    T=mg+ma/cos0
    but there is no mass given in the problem
  10. Nov 2, 2008 #9
    Doc Al
    Staff: Mentor
    Do this. Draw a careful diagram of the ball and string showing all forces acting on the ball. (There are only two.) Then find the tangential component of each force. (Tangential, in this case, is perpendicular to the string.)
    You won't need the mass to find the tangential acceleration. Just call it "m"--it will drop out when you apply Newton's 2nd law.
  11. Nov 2, 2008 #10
    oh ok i did the process and i got a=gtan0.
    If the string broke at point Q, would it undergo projectile motion with a horizontal initial velocity?
  12. Nov 3, 2008 #11
    Doc Al
    Staff: Mentor
    That is not correct.
    What's the speed of the ball at point Q?
  13. Nov 3, 2008 #12
    there is the tension and its components and mg as the forces on the ball. The component TsinO would be the tangential force. Tcos0=mg. T=mg/cos0 Tsin0=ma (mg/cos0)(sin0)=ma
    Where did I misinterpret the problem?
    The velocity at point Q is 0m/s
  14. Nov 3, 2008 #13
    Doc Al
    Staff: Mentor
    Right. String tension and mg are the only forces on the ball.
    No, Tsinθ is the horizontal component of the tension.
    No, Tcosθ (the vertical component of tension) does not equal mg. It would if the ball were in equilibrium, but it's not.
    Find the tangential components of the force on the ball.
    Right. So if the ball were let go at that point (the string was cut), what would its motion look like?
  15. Nov 4, 2008 #14
    ok i got gsin0 and it was correct.
    Thanks
Loading...
