Homework Help: Ball rotates in a rough bowl
  1. Aug 14, 2016 #1
    The ball of mass m and radius r is released from horizontal position, the edge of the bowl.
    What are the tangential and radial accelerations at angle θ and what is the velocity.
    What should be the minimal friction coefficient at angle θ so that the ball won't slip
    2. Relevant equations
    Radial acceleration: ##a_r=\frac{v^2}{r}##
    3. The attempt at a solution
    Conservation of energy: ##mgh=\frac{1}{2}mv^2~~\rightarrow~~mg(R-r)\sin\theta=\frac{1}{2}mv^2##
    $$v^2=2g(R-r)\sin\theta$$
    $$a_t=\frac{mg\cos\theta}{m}=g\cos\theta$$
    $$a_r=\frac{v^2}{r}=\frac{2g(R-r)\sin\theta}{R}$$
    In order not to slip the tangential forces of friction and the component of gravity must cancel:
    $$mg\mu=mg\cos\theta~~\rightarrow~~\mu=\cos\theta$$
  3. Aug 14, 2016 #2
    haruspex
    What about rotational KE?
  4. Aug 15, 2016 #3
    $$mgh=\frac{1}{2}I_A\omega^2~~\rightarrow~~mg(R-r)\sin\theta=\frac{1}{2}m(k+1)r^2\omega$$
    $$\rightarrow~~\omega=\frac{2g(R-r)\sin\theta}{(k+1)r^2},~~v=\omega r$$
    $$a_t=\frac{F_t}{m}=\frac{mg\cos\theta}{m}=g\cos\theta$$
    $$a_r=\frac{v^2}{R-r}$$
    The condition for minimum μ remains the same:
  5. Aug 15, 2016 #4
    haruspex
    What about friction?
  6. Aug 15, 2016 #5
    At going up and also down the friction acts against gravity's component:
    $$F_t-f=mg~~\rightarrow~~mg(\cos\theta-\mu\sin\theta)=ma_t$$
  7. Aug 15, 2016 #6
    I was also trying this.
    OP: what is R?
    And I think the other poster is saying you have to set gravitational potential energy = translational ke and rotational ke. For both radial and translational acceleration. We know translational acceleration will be smaller than if the ball was purely sliding.
  8. Aug 15, 2016 #7
    $$M=I_A\alpha~~\rightarrow~~mrg\cos\theta=mr^2(k+1)\alpha$$
    $$\alpha=\frac{g\cos\theta}{(k+1)r},~~v=\omega r$$
    R is the bowl's radius.
    $$a_t=\alpha r=\left( \frac{\cos\theta}{k+1} \right)g,~~a_r=\frac{v^2}{R}$$
  9. Aug 15, 2016 #8
    Can't you just set mgh = both types of kinetic energy and solve for v?
    This will then give you radial acceleration. v^2/R
    Then use kinematics to figure out tangential acceleration
  10. Aug 15, 2016 #9
    $$EK_{(rot)}=\frac{1}{2}I_c\omega^2=\frac{1}{2}I_c\frac{v^2}{r^2}=\frac{1}{2}kmv^2$$
    $$mgh=\frac{1}{2}mv^2+\frac{1}{2}I_c\omega^2=\frac{1}{2}mv^2+\frac{1}{2}kmv^2=\frac{1}{2}mv^2(k+1)$$
    $$mg(R-r)\sin\theta=\frac{1}{2}mv^2(k+1)~~\rightarrow~~v^2=\frac{2(R-r)\sin\theta}{k+1}$$
    $$a_r=\frac{v^2}{R-r}=\left( \frac{2\sin\theta}{k+1} \right)g$$
    How do i use kinematics to find tangential acceleration? Isn't tangential acceleration only a function of the forces (gravity and friction) acting on the ball?
    Kinematics deals with velocities, accelerations and distances, not forces. the tangential acceleration acts on the center, right?
    The forces depend on the angle, so i can't use constant acceleration formulas.
  11. Aug 15, 2016 #10
    So to start with your diagram does not have R as a given, only h. Hopefully you were given R as it would make finding centripetal acceleration a lot easier. I also hope the question meant to say a ball of mass m WITH a radius of r? I am having some R, r confusion.
    What is your answer for v at the h vertical level? All you need is conservation of energy, no forces or angles required IMO. This v is really just speed in variable form. You can convert omega to v. (omega x r = v) The parenthetical is a key part of your mess up I believe.
    And I think if you do know v at h, tangential acceleration is easy at h below the starting vertical level. ( I am assuming the ball starts from rest) You just use the instantaneous speed you found using conservation of energy kinematically. Again, no forces or angles required. Now the last part is gonna require forces.
  12. Aug 16, 2016 #11
    haruspex
    The question asks for accelerations, though. I suppose you could use a = v dv/dx, but the direct approach using forces and moments looks easier to me.
  13. Aug 16, 2016 #12
    ehild
    The ball starts from the edge of the bowl, with zero speed. What is the normal force and friction at the uppermost position of the ball? Can the ball roll from the beginning? What makes the ball roll ?
    If it is not pure rolling, the ball skids at the beginning part of its track, and you can not apply conservation of energy.
  14. Aug 16, 2016 #13
    From post #9:
    $$mgh=\frac{1}{2}mv^2+\frac{1}{2}I_c\omega^2=\frac{1}{2}mv^2+\frac{1}{2}kmv^2~~\rightarrow~~v^2=\frac{2(R-r)\sin\theta}{k+1}$$
    $$a_t=\dot{v}=\frac{(R-r)\cos\theta}{(k+1)\sqrt{\frac{2(R-r)}{k+1}\sin\theta}}$$
    Do you mean what i wrote in post #7:
    $$M=I_A\alpha~~\rightarrow~~\alpha=\frac{g\cos\theta}{(k+1)r},~~\omega=\int \alpha$$
    For that i need ##\theta(t)=?##
    The normal force at the beginning is zero and the ball cannot roll. the friction makes it roll.
  15. Aug 16, 2016 #14
    ehild
    Then it slides at some part of its track. Can you derive the speed from conservation of energy?
  16. Aug 16, 2016 #15
    haruspex
    If work is conserved (see below) you can get the velocities in terms of theta from that, then use the velocities and moments etc. to find acceleration, again as a function of theta. You are not asked to find anything as a function of time, and indeed that might be much harder.
    If there is no normal force, how can there be friction? Yet you need angular acceleration to match the linear acceleration to roll.
  17. Aug 16, 2016 #16
    But immediately after the beginning there is normal force and it starts rolling, so what i did is correct:
    $$mgh=\frac{1}{2}I_A\omega^2~~\rightarrow~~\omega=\frac{2g(R-r)\sin\theta}{(k+1)r^2},~~v=\omega r$$
  18. Aug 16, 2016 #17
    haruspex
    There is linear acceleration right from the start, so for rolling contact there should be rotational acceleration from the start. But since there is no normal force then there is no frictional torque to provide it. In order to make the later transition to rolling contact, it will then have to go through a sliding phase, in which kinetic friction brings it up to rotational speed.
  19. Aug 16, 2016 #18
    Sliding makes things worse since i have to add friction losses which i don't know:
    $$mgh=\frac{1}{2}I_A\omega^2+E_f$$
  20. Aug 16, 2016 #19
    Holy cow I never took that into account. The last part of the question now makes a lot more sense. It's a rolling and slipping problem. I should have known from the last question.
    Thanks.
    Very sorry Karol.
    I will just observe.
  21. Aug 16, 2016 #20
    Thanks for this addition also.
    Sorry Karol.
  22. Aug 16, 2016 #21
    To find where pure rolling starts:
    $$M=I_A\alpha~~\rightarrow~~\alpha=\frac{g\cos\theta}{(k+1)r},~~\omega=\int_0^{\theta} \alpha=\left( -\frac{g\mu}{kr^2} \right)\cos\theta$$
    $$F_t-f=ma_t:~~mg\cos\theta-mg\mu\sin\theta=ma_t$$
    $$\rightarrow~~v=\int\frac{F_t}{m}=g\int_0^{\theta}(\cos\theta-\mu\sin\theta)=-g(\sin\theta+\mu\cos\theta)$$
    The dimensions aren't correct, and what does the minus sign mean in ω and v?
  23. Aug 16, 2016 #22
    haruspex
    @ehild, can you see a way to solve the first part? Eliminating time, I get an equation of the form ##yy'+ky^2=A\cos(x)-B\sin(x)##. The equation with time has ##\theta, \dot\theta, \ddot\theta## in it, so there seems to be no way to find the accelerations without solving it.
  24. Aug 16, 2016 #23
    haruspex
    I don't understand the bit after ##\int_0^{\theta}\alpha##. How are you integrating that with respect to time without knowing alpha as a function of time?
  25. Aug 16, 2016 #24
    I don't know if i integrate with respect to time or θ. i hoped that if α=α(θ) then i need to integrate with respect to θ.
    @haruspex, how did you get ##yy'+ky^2=A\cos(x)-B\sin(x)## and what is x, is it the angle θ?
  26. Aug 16, 2016 #25
    ehild
    During the sliding part of the motion, the accelerations a and α can be expressed with the forces:
    ma=mgcos(θ) - μN
    kmr2α=rμN.
    Knowing N(θ), we know the accelerations.
    Solving the equation ##yy'+ky^2=A\cos(x)-B\sin(x)## for y=(dθ/dt) in terms of x=theta, we find N=mv2 /(R-r) + mg sin(θ).
Have something to add?
Draft saved Draft deleted
