Ball swinging around a post
  • Thread starter jjd101
A ball on a 6.5 m long string swings down and wraps around a post that is 4.0 m below the post the string is attached to. If the ball is released level with the post to which it is attached, what will be the velocity of the ball when it is at its highest point over the lower post?
circular momentum? Inertia of a ball on a string
I really have no idea where to start on this problem, i was thinking you start with the initial acceleration of 9.8 due to gravity but that doesnt translate to an initial angular velocity.
Answers and Replies
gneill
Mentor
20,945
2,886
Use conservation of energy! What forms of energy are involved here? Where's the energy coming from to give the ball motion?
gravitiational potential energy and kinetic energy??
gneill
Mentor
20,945
2,886
Yes. So determine the change in energies for the various locations.
??? do i split it up into sections like pie to 3pie/2, 3pie/2 to 2pie, 2pie to pie/2?
gneill
Mentor
20,945
2,886
You can split it up any way you like, as long as you get the information you need in order to find the kinetic and potential energies at the various locations. Personally, since gravitational potential energy is involved, I'd be more concerned about the change in heights of the object at the various points, rather than any angle. Why not draw a picture of the situation at each critical point and see if you can label the changes in height.
the change in height goes from 4m above the post to 2.5m above the post, aka 1.5m lesss than the drop point, but i dont know how to do this energy problem without mass?
gneill
Mentor
20,945
2,886
Leave it in as a variable if you wish; you'll find that it cancels out anyways.
i left m in as a variable and ended up with velocity is equal to 5.42m/s. Is this correct?
gneill
Mentor
20,945
2,886
It looks fine.
thanks
Related Threads on Ball swinging around a post
  • Last Post
  • Last Post
  • Last Post
E
  • Last Post
  • Last Post
  • Last Post
